Part Number: LP-EM-CC2745R10-Q1
我有2个 LP-EM-CC2745R10-Q1套件、想测试通道探测,并且烧录了sdk的版本是simplelink_lowpower_f3_sdk_9_10_00_83,我在选择输出raw_events时,输出了如下的data,我想知道这些data的结构是什么,以及如何从这些data获得IQdata。
烦请告知
Create a connection with [80, 129, 91, 85, 205, 120] as a central
00:00:00:00:00:00: scan disabled
Connection Data
Status: 0
Opcode: 5
Address Type: ADDRTYPE_PUBLIC_ID
Device Address: 78:CD:55:5B:81:50
Connection Handle: 0
Connection Role: 8
Connection Interval: 24
Connection Latency: 0
Connection Timeout: 2000
Clock Accuracy: 0
Didn't get NWP_PAIRING_STATE_COMPLETE, wait for NWP_PAIRING_STATE_ENCRYPTED in case we already bonded
Pairing Complete
State: 4
Status: 0
***** read local cap *****
***** read remote cap *****
Remote Capabilities
_io: []
event: 64
conn_handle: 0
status: 0
num_config: 4
max_procedures: 0
num_antennas: 1
max_ant_path: 4
role: 3
optional_modes: 1
rtt_cap: 0
rtt_aa_only_n: 255
rtt_sounding_n: 0
rtt_random_payload_n: 255
nadm_sounding: 0
nadm_random_seq: 0
optional_cs_sync_phy: 6
no_fae: 1
ch_sel_3c: 0
cs_based_ranging: 0
t_ip1_cap: 120
t_ip2_cap: 120
t_fcs_cap: 448
t_pm_csap: 0
t_sw_cap: 1
snr_tx_cap: 0
***** security enable *****
Security Enable
_io: []
event: 67
conn_handle: 0
status: 0
***** set default settings *****
***** create config *****
Create Config
_io: []
event: 65
conn_handle: 0
status: 0
config_id: 0
state: 1
main_mode: 2
sub_mode: 255
main_mode_min_steps: 0
main_mode_max_steps: 0
main_mode_repetition: 0
mode_zero_steps: 3
role: 0
rtt_type: 0
cs_sync_phy: 1
channel_map: [252, 255, 127, 252, 255, 255, 255, 255, 255, 31]
ch_m_repetition: 1
ch_sel: 0
ch3c_shape: 0
ch3c_jump: 0
rfu0: 0
t_ip1: 3
t_ip2: 3
t_fcs: 6
t_pm: 2
rfu: 0
***** procedure enable *****
Procedure Enable
_io: []
event: 68
status: 0
conn_handle: 0
config_id: 0
enable: 1
aci: 0
pwr_delta: 128
sub_event_len: 55000
sub_events_per_event: 1
sub_event_interval: 0
event_interval: 3
procedure_interval: 0
procedure_count: 1
Waiting for CS_SUBEVENT_RESULTS (local)
Subevent Results - local device
_io: []
event: 69
conn_handle: 0
config_id: 0
start_acl_connection_event: 289
procedure_counter: 0
frequency_compensation: 32338
reference_power_level: -45
procedure_done_status: 1
subevent_done_status: 1
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 20
data_len: 228
data: 00:33:05:00:CC:01:3B:7E:00:34:05:00:CC:01:3B:7E:00:2A:05:00:CF:01:5E:7E:02:28:09:00:A4:D1:71:08:02:F0:FF:58:02:3C:09:00:57:80:65:03:01:F0:FF:A6:02:23:09:00:3A:BA:C9:18:E1:3B:82:08:02:42:09:00:8A:33:71:03:00:00:00:FF:02:3F:09:00:DC:49:E1:11:00:F0:FF:96:02:1B:09:00:5F:17:F1:17:FF:FF:FF:96:02:13:09:00:28:06:60:0C:FF:FF:FF:FA:02:0D:09:00:3D:E3:97:18:00:F0:FF:36:02:3B:09:00:0F:DA:F8:06:82:DB:BF:0A:02:32:09:00:73:BE:3B:09:86:3C:22:04:02:11:09:00:AE:16:AA:09:28:D7:F9:15:02:0B:09:00:5A:26:D0:05:01:F0:FF:C8:02:07:09:00:D7:22:4A:05:FF:0F:00:64:02:4B:09:00:68:C5:4E:17:92:C2:8B:0A:02:0C:09:00:2D:C3:69:06:00:E0:FF:32:02:21:09:00:83:C5:6E:0D:03:D0:FF:34:02:1E:09:00:D5:DB:83:0B:00:00:00:6E
Waiting for CS_SUBEVENT_RESULTS (remote)
Subevent Results - remote device
_io: []
event: 69
conn_handle: 0
config_id: 0
frequency_compensation: -16384
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 21
data_len: 234
data: 00:33:03:00:CC:01:00:34:03:00:CC:01:00:2A:03:00:CF:01:02:28:09:00:F5:89:38:03:B8:5C:5F:0E:02:3C:09:00:DA:4E:63:09:02:10:00:7E:02:23:09:00:D4:02:7A:0F:70:15:6A:0D:02:42:09:00:52:41:7D:0F:FE:1F:00:6E:02:3F:09:00:C3:85:CF:05:2C:23:A1:08:02:1B:09:00:76:16:2C:17:5E:07:DF:10:02:13:09:00:8B:B5:75:09:6F:C6:3A:13:02:0D:09:00:97:7A:97:03:F8:1F:00:26:02:3B:09:00:91:E5:1B:06:70:85:E8:05:02:32:09:00:81:EE:39:04:F9:4F:FF:10:02:11:09:00:E2:28:3A:0F:80:AB:63:10:02:0B:09:00:B7:F9:BF:0A:FD:0F:00:C8:02:07:09:00:E5:DA:17:05:DB:DC:42:05:02:4B:09:00:A7:07:08:15:90:87:CA:0A:02:0C:09:00:F0:6D:69:11:C5:71:6E:14:02:21:09:00:E7:3C:85:11:FA:1F:00:2A:02:1E:09:00:B2:50:70:1C:A2:94:7D:0E:02:2B:09:00:E5:9D:57:05:FF:70:63:04
