Part Number: CC2745R10-Q1
您好,我选用的sdk是最新的channel sounding推出的simplelink_lowpower_f3_sdk_9_12_00_19 我现在想知道的是我选择输出raw_events之后,得到了如帖子中展示的local设备和remote设备的一组data,这些data显示出有15和21个step,这可以得到每个step有12长度的数据,我想知道这些16进制每12场电影的data的数据分别代表了什么,以及这些data能不能获取到IQ值用于后续获得相位和频率呢?烦请告知
Waiting for CS_SUBEVENT_RESULTS_CONTINUE
Subevent Results Continue - local device
_io: []
event: 70
conn_handle: 0
config_id: 0
procedure_done_status: 0
subevent_done_status: 0
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 15
data_len: 180
data: 02:08:09:00:69:32:E5:07:00:00:00:FF:02:12:09:00:96:E2:E7:08:59:E2:13:19:02:1E:09:00:4E:12:10:18:00:00:00:FF:02:14:09:00:6E:7D:13:0C:C6:ED:E5:18:02:2C:09:00:32:FF:24:10:5C:2D:15:05:02:48:09:00:D4:00:2F:02:8C:7E:20:12:02:29:09:00:8F:A2:E6:03:69:12:07:11:02:47:09:00:09:8E:1B:1A:00:F0:FF:FF:02:39:09:00:7F:EE:1F:18:41:BD:0D:06:02:30:09:00:07:10:D7:19:67:B2:E5:0E:02:3F:09:00:6E:9F:D3:07:AD:21:E2:14:02:0D:09:00:5B:61:DA:1B:8B:C2:E8:0A:02:04:09:00:6D:0E:25:0F:9E:4D:12:13:02:0C:09:00:C2:00:D9:13:77:E2:E2:04:02:34:09:00:C9:10:DB:12:00:00:00:FF
Waiting for remote CS_SUBEVENT_RESULTS
Subevent Results - remote device
_io: []
event: 69
conn_handle: 0
config_id: 0
start_acl_connection_event: 348
procedure_counter: 0
frequency_compensation: -16384
reference_power_level: -21
procedure_done_status: 1
subevent_done_status: 1
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 21
data_len: 234
data: 00:1C:03:00:E0:01:00:1F:03:00:E0:01:00:30:03:00:E0:01:02:24:09:00:B3:4D:FB:13:A5:FD:17:01:02:13:09:00:43:62:E2:00:FF:FF:FF:FF:02:4C:09:00:B4:A2:F4:05:00:00:00:FF:02:45:09:00:F8:F1:12:10:A0:E2:F3:03:02:1C:09:00:25:5E:DB:04:00:00:00:C8:02:15:09:00:4B:52:0B:1A:00:00:00:FF:02:1F:09:00:6D:60:27:1A:FF:FF:FF:FF:02:2E:09:00:17:1E:E7:18:FF:0F:00:A8:02:27:09:00:75:62:F5:0E:00:00:00:FF:02:42:09:00:36:41:28:04:27:E2:0B:11:02:32:09:00:E7:3E:D5:07:2C:8E:E4:0F:02:0A:09:00:66:EF:24:11:B4:41:26:0A:02:3B:09:00:12:DF:D4:03:00:00:00:FF:02:33:09:00:64:FE:DC:0A:A7:CD:FD:12:02:09:09:00:AE:8D:13:0F:FF:FF:FF:FF:02:4B:09:00:6C:5E:E1:17:6A:7D:01:13:02:41:09:00:FB:5E:20:0D:FF:FF:FF:FF:02:11:09:00:F9:DE:23:17:56:01:28:0D
