CC2745R10-Q1: channel sounding信道探测Subevent Results数据解析
Part Number: CC2745R10-Q1
您好,我选用的sdk是最新的channel sounding推出的simplelink_lowpower_f3_sdk_9_12_00_19 我现在想知道的是我选择输出raw_events之后,得到了如帖子中展示的local设备和remote设备的一组data,这些data显示出有15和21个step,这可以得到每个step有12长度的数据,我想知道这些16进制每12个数据包的data的数据分别代表了什么,以及这些data能不能获取到IQ值用于后续获得相位和频率呢?烦请告知
Waiting for CS_SUBEVENT_RESULTS_CONTINUE
Subevent Results Continue - local device
_io: []
event: 70
conn_handle: 0
config_id: 0
procedure_done_status: 0
subevent_done_status: 0
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 15
data_len: 180
data: 02:2B:09:00:F7:8D:F1:14:FF:FF:FF:FF:02:06:09:00:C9:31:DE:0C:00:00:00:FF:02:13:09:00:2B:52:E6:04:42:12:07:0C:02:34:09:00:EE:01:0F:10:FF:FF:FF:FF:02:36:09:00:D9:4D:FD:13:A7:0E:E1:0A:02:43:09:00:95:6F:DB:04:FF:FF:FF:FF:02:29:09:00:55:E1:23:06:FF:FF:FF:FF:02:09:09:00:16:32:E2:03:57:62:01:11:02:4A:09:00:CD:BF:20:0A:00:00:00:FF:02:32:09:00:C5:3D:0E:05:FF:FF:FF:FF:02:03:09:00:8E:8F:D9:13:FF:0F:00:21:02:1F:09:00:BD:FD:03:16:5B:9E:E0:07:02:4C:09:00:F8:11:04:0A:FE:EF:FF:0A:02:3D:09:00:FE:AE:1E:0D:B5:8D:0C:02:02:3E:09:00:A6:21:17:14:FF:FF:FF:FF
Waiting for remote CS_SUBEVENT_RESULTS
Subevent Results - remote device
_io: []
event: 69
conn_handle: 0
config_id: 0
start_acl_connection_event: 236
procedure_counter: 0
frequency_compensation: -16384
reference_power_level: -21
procedure_done_status: 1
subevent_done_status: 1
abort_reason: 0
num_antenna_path: 1
num_steps_reported: 21
data_len: 234
data: 00:08:03:00:DF:01:00:34:03:00:DE:01:00:12:03:00:DF:01:02:11:09:00:E0:BD:F3:15:FF:FF:FF:FF:02:49:09:00:18:9E:02:05:B1:AE:15:09:02:24:09:00:16:52:ED:03:79:00:DF:0D:02:2A:09:00:6C:81:E4:10:8E:CF:DA:12:02:35:09:00:F1:ED:08:05:00:F0:FF:FF:02:0D:09:00:EF:7D:E9:11:FF:FF:FF:FF:02:0C:09:00:1F:C2:11:12:27:12:F0:0F:02:44:09:00:A6:0F:DC:07:00:00:00:FF:02:45:09:00:FD:6D:01:0A:9E:CE:16:0E:02:0A:09:00:F6:40:DE:15:FF:FF:FF:FF:02:3A:09:00:14:7F:DC:04:3B:5E:EF:15:02:05:09:00:2C:A1:DD:10:00:00:00:FF:02:41:09:00:F2:21:08:0F:00:F0:FF:FF:02:21:09:00:8F:60:24:18:AC:A1:1D:08:02:40:09:00:EA:F1:09:0C:EB:21:F1:02:02:04:09:00:D5:BD:E4:0A:C0:BD:08:15:02:20:09:00:1C:0E:17:01:00:00:00:FF:02:3B:09:00:F1:B1:EF:01:00:00:00:FF
