CC2640 - 送GATT notification msg 2字元會error
Other Parts Discussed in Thread: CC2640
您好
我想cc2640走BT透過SimpleProfile_SetParameter()送data到pc tool讀取,
但我發現當送2個字元時會失敗,而其它長度的值都成功,以下測試說明:
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR6, 1, "a");    // pc端能正常讀到"a"
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR6, 2, "ab");  // pc端讀不到
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR6, 3, "abc"); // pc端正常讀到"abc"
SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR6, 4, "abcd"); // pc端正常讀到"abcd"
一路往下追:
    --> GATTServApp_ProcessCharCfg() //simpleProfileChar6 have data "ab"
    --> gattServApp_SendNotiInd() //pAttr->pValue have data "ab"
    --> GATT_Notification() //&noti, noti.pValue have data "ab"
    --> gattIndNoti() //msg->pIndNoti->handleValueNoti.pValue = "ab"
    --> sendWaitMatchCS()// 無法往下追了
是否有idea??
  • SIMPLEPROFILE_CHAR6 你自己加的吧? 他的value指向的是一个数组吗?
  • 您好
    是的,simpleProfileChar6[20] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
             SIMPLEPROFILE_CHAR6_LEN = 20;
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR6, 2, "ab");會跑以下case
    static gattCharCfg_t *simpleProfileChar6Config;
    bStatus_t SimpleProfile_SetParameter( uint8 param, uint8 len, void *value )
       case SIMPLEPROFILE_CHAR6:
       if ( len <= SIMPLEPROFILE_CHAR6_LEN )  //len = 上面function帶的2
          notiChar6Len = len;
          VOID memcpy( simpleProfileChar6, value, len );
          // See if Notification has been enabled
          GATTServApp_ProcessCharCfg( simpleProfileChar6Config, simpleProfileChar6, FALSE,
          simpleProfileAttrTbl, GATT_NUM_ATTRS( simpleProfileAttrTbl ),
          INVALID_TASK_ID, simpleProfile_ReadAttrCB );
    搞不懂為何只有兩字元會失敗,也比較過送1字元/兩字元/三字元皆有送下去gattIndNoti()
