请问CC2540的8051内核如何访问控制内部的BLE无线电模块?是通过寄存器、DMA还是其他?命令写到那个地址去?
您可以参考http://www.ti.com.cn/cn/lit/ug/swru191f/swru191f.pdf 第275页
The CC2540 and CC2541 provide a Bluetooth low energy compliant radio transceiver. On the CC2540 and CC2541, radio operation is controlled by the Bluetooth low energy stack. The application is not allowed to access the radio directly. The application interacts with the radio by sending API commands to the stack.
是的,TI做好了BLE协议栈,可以直接下载到2540里,你自己做应用开发。自定义的话难度就颇大了,协议栈的稳定性是问题。CC2541也可以玩,用它的controller就好了。
