所有都是默认安装,打开工程编译提示信息如下:
Building configuration: cc2640r2lp_app - FlashROM_StackLibrary
Updating build tree...
Performing Pre-Build Action
Error while running "C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\..\xdctools_3_51_03_28_core\xs" --xdcpath="C:\ti\
simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages;C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source;C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\
ti\ble5stack" iar.tools.configuro -c "C:\Program Files\IAR Systems\Embedded Workbench 8.0\arm" --cc "C:\Program Files\IAR Systems\Embedded Workbench 8.0\arm\bin\iccarm.exe" --device "Default" --compileOptions "dummy.c -D
DeviceFamily_CC26X0R2 --diag_suppress Pa050 -o C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\FlashROM_StackLibrary\Obj --debug --endian=little
--cpu=Cortex-M3 -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\defines\cc2640r2lp_app_FlashROM_StackLibrary.opt -f C:\ti\
simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\config\build_components.opt -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\config\factory_config.opt -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\tirtos\build_config.opt -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\configPkg\compiler.opt.defs -e
--fpu=None --dlib_config \"C:\Program Files\IAR Systems\Embedded Workbench 8.0\arm\INC\c\DLib_Config_Normal.h\" -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\
tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\controller\cc26xx\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\inc\ -I
C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\common\cc26xx\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\src\app\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\
ble5stack\icall\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\profiles\dev_info\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\profiles\simple_profile\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\
source\ti\ble5stack\profiles\simple_profile\cc26xx\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\target\ -I C:\ti\
simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\hal\src\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\hal\src\target\_common\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\hal\src\target\_common\cc26xx\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\
..\..\source\ti\ble5stack\hal\src\target\cc2650\rom\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\heapmgr\ -I C:\ti\
simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\icall\src\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\osal\src\inc\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\
app\..\..\..\..\..\..\..\..\source\ti\ble5stack\services\src\saddr\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\services\src\
sdata\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\devices\cc26x0r2\ -I C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ -Ohz" --linkOptions "-o C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\
app\FlashROM_StackLibrary\Exe\ble5_simple_peripheral_cc2640r2lp_app_FlashROM_StackLibrary.out --config_def CC2650=2 --config_def FLASH_ROM_BUILD=2 --map C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\FlashROM_StackLibrary\List\ble5_simple_peripheral_cc2640r2lp_app_FlashROM_StackLibrary.map --config C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\ble5stack\common\cc26xx\iar\cc26xx_app_and_stack.icf --keep __vector_table -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\configPkg\linker.cmd -f C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\
lib_linker.cmd --semihosting C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\config\ble_r2.symbols C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\
rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\devices\cc26x0r2\driverlib\bin\iar\driverlib.lib C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\kernel\tirtos\packages\ti\dpl\lib\dpl_cc26x0r2.arm3 C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\
source\ti\drivers\lib\drivers_cc26x0r2.arm3 C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\drivers\rf\lib\rf_singleMode_cc26x0r2.arm3
C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\display\lib\display.arm3 C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\
CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\..\..\..\..\..\source\ti\grlib\lib\iar\m3\grlib.a --entry __iar_program_start --vfe --text_out locale" --profile release --projFile "C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\
examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\cc2640r2lp_app.ewp" --cfgArgs NO_ROM=0 -o C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\
simple_peripheral\tirtos\iar\app\..\config\configPkg C:\ti\simplelink_cc2640r2_sdk_3_20_00_21\examples\rtos\CC2640R2_LAUNCHXL\ble5stack\simple_peripheral\tirtos\iar\app\..\..\..\tirtos\app_ble.cfg
Total number of errors: 1
Total number of warnings: 0
