这个是什么问题???
Other Parts Discussed in Thread: CC2541
Warning[w28]: Parts of segment <XDATA_ROM_C> 1 are initialized (as in module
?FILLER_BYTES), parts not (as in module simpleBLECentral)
  • 您现在使用的是哪款芯片/开发板?SDK版本呢?编译的是例程还是您自己的程序?
  • CC2541,SDK1.4.2.2,例程中增加自己的程序
  • 那您看一下您现在 XDATA_ROM_C 的初始化定义是在哪里
  • 怎么查找看一下?????不清楚
  • 可以编译后看一下map文件
  • SimpleBLEPeripheral.zip-P(CONST)XDATA_ROM_C=0x8000-0xFFFF
  • 怎么确认位置???
  • 在您map文件的 SEGMENTS IN ADDRESS ORDER 看到
    <XDATA_ROM_C> 1 CONST 00008000 - 000085DB 5DC rel 2
    果然是如警告所示,只初始化了一部分
    您现在修改的代码能给出吗?
  • 还有啊,这个怎么处理一下???
      Filename:       simpleBLECentral.c
      Revised:        $Date: 2011-06-20 11:57:59 -0700 (Mon, 20 Jun 2011) $
      Revision:       $Revision: 28 $
      Description:    This file contains the Simple BLE Central sample application
                      for use with the CC2540 Bluetooth Low Energy Protocol Stack.
      Copyright 2010 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED �AS IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include "bcomdef.h"
    #include "OSAL.h"
    #include "OSAL_PwrMgr.h"
    #include "OnBoard.h"
    #include "hal_led.h"
    #include "hal_key.h"
    #include "hal_lcd.h"
    #include "gatt.h"
    #include "ll.h"
    #include "hci.h"
    #include "gapgattserver.h"
    #include "gattservapp.h"
    #include "central.h"
    #include "gapbondmgr.h"
    #include "simpleGATTprofile.h"
    #include "simpleBLECentral.h"
    #include "npi.h"
    #include "simpleble.h"
    #include "stdio.h"
    #include "simpleBLEPeripheral.h"
    #include "observer.h"
     * MACROS
    // Length of bd addr as a string
    #define B_ADDR_STR_LEN                        15
     * CONSTANTS
    // Maximum number of scan responses
    #define DEFAULT_MAX_SCAN_RES                  16
    // Scan duration in ms
    #define DEFAULT_SCAN_DURATION                 500//4000  Ĭ��ɨ��ʱ�� ms
    // Discovey mode (limited, general, all)
    #define DEFAULT_DISCOVERY_MODE                DEVDISC_MODE_ALL
    // TRUE to use active scan
    #define DEFAULT_DISCOVERY_ACTIVE_SCAN         TRUE
    // TRUE to use white list during discovery
    #define DEFAULT_DISCOVERY_WHITE_LIST          FALSE
    // TRUE to use high scan duty cycle when creating link
    #define DEFAULT_LINK_HIGH_DUTY_CYCLE          FALSE
    // TRUE to use white list when creating link
    #define DEFAULT_LINK_WHITE_LIST               FALSE
    // Default RSSI polling period in ms
    #define DEFAULT_RSSI_PERIOD                   200
    // Whether to enable automatic parameter update request when a connection is formed
    #define DEFAULT_ENABLE_UPDATE_REQUEST         FALSE
    // Minimum connection interval (units of 1.25ms) if automatic parameter update request is enabled
    #define DEFAULT_UPDATE_MIN_CONN_INTERVAL      8//400  ���Ӽ�������ݷ������йأ� ���Ӽ��Խ�̣� ��λʱ���ھ��ܷ���Խ�������
    // Maximum connection interval (units of 1.25ms) if automatic parameter update request is enabled
    #define DEFAULT_UPDATE_MAX_CONN_INTERVAL      8//800  ���Ӽ�������ݷ������йأ� ���Ӽ��Խ�̣� ��λʱ���ھ��ܷ���Խ�������
    // Slave latency to use if automatic parameter update request is enabled
    #define DEFAULT_UPDATE_SLAVE_LATENCY          0
    // Supervision timeout value (units of 10ms) if automatic parameter update request is enabled
    #define DEFAULT_UPDATE_CONN_TIMEOUT           100//600
    // Default passcode
    #define DEFAULT_PASSCODE                      12345
    // Default GAP pairing mode
    #define DEFAULT_PAIRING_MODE                  GAPBOND_PAIRING_MODE_WAIT_FOR_REQ
    // Default MITM mode (TRUE to require passcode or OOB when pairing)
    #define DEFAULT_MITM_MODE                     FALSE
    // Default bonding mode, TRUE to bond
    #define DEFAULT_BONDING_MODE                  TRUE
    // Default GAP bonding I/O capabilities
    #define DEFAULT_IO_CAPABILITIES               GAPBOND_IO_CAP_DISPLAY_ONLY
    // Default service discovery timer delay in ms
    #define DEFAULT_SVC_DISCOVERY_DELAY           1000
    // TRUE to filter discovery results on desired service UUID
    #define DEFAULT_DEV_DISC_BY_SVC_UUID          TRUE
    // Discovery states
    enum
      BLE_DISC_STATE_IDLE,                // Idle
      BLE_DISC_STATE_SVC,                 // Service discovery
      BLE_DISC_STATE_CHAR                 // Characteristic discovery
     * TYPEDEFS
     * GLOBAL VARIABLES
     * EXTERNAL VARIABLES
     * EXTERNAL FUNCTIONS
     * LOCAL VARIABLES
    // Task ID for internal task/event processing
    uint8 simpleBLETaskId;
    // GAP GATT Attributes
    static const uint8 simpleBLEDeviceName[GAP_DEVICE_NAME_LEN] = "Simple BLE Central";
    // Number of scan results and scan result index
    uint8 simpleBLEScanRes;  //ɨ����
    //static uint8 simpleBLEScanIdx;
    // Scan result list
    static gapDevRec_t simpleBLEDevList[DEFAULT_MAX_SCAN_RES];
    //debug
    //uint8 gapDevRec_tp[12][40];
    //int8 gapDevRec_rssi[12];
    Central_ibeType tagCibe={0};
    // Scanning state
    uint8 simpleBLEScanning = FALSE;
    // RSSI polling state
    uint8 simpleBLERssi = FALSE;
    // Connection handle of current connection
    static uint16 simpleBLEConnHandle = GAP_CONNHANDLE_INIT;
    // Application state
    uint8 simpleBLEState = BLE_STATE_IDLE;
    // Discovery state
    static uint8 simpleBLEDiscState = BLE_DISC_STATE_IDLE;
    // Discovered service start and end handle
    static uint16 simpleBLESvcStartHdl = 0;
    static uint16 simpleBLESvcEndHdl = 0;
    // Discovered characteristic handle
    uint16 simpleBLECharHdl = 0;
    uint16 simpleBLECharHd6 = 0;
    bool simpleBLEChar6DoWrite = TRUE;
    bool simpleBLECentralCanSend = FALSE;          //  �����ɷ�������
    //uint8 strTp[400];
    // Value to write
    //static uint8 simpleBLECharVal = 0;
    // Value read/write toggle
    //static bool simpleBLEDoWrite = FALSE;
    // GATT read/write procedure state
    //static bool simpleBLEProcedureInProgress = FALSE;
     * LOCAL FUNCTIONS
    static void simpleBLECentralProcessGATTMsg( gattMsgEvent_t *pMsg );
    static void simpleBLECentralRssiCB( uint16 connHandle, int8  rssi );
    static uint8 simpleBLECentralEventCB( gapCentralRoleEvent_t *pEvent );
    //static void simpleBLECentralPasscodeCB( uint8 *deviceAddr, uint16 connectionHandle,
    //                                        uint8 uiInputs, uint8 uiOutputs );
    //static void simpleBLECentralPairStateCB( uint16 connHandle, uint8 state, uint8 status );
    static void simpleBLECentral_HandleKeys( uint8 shift, uint8 keys );
    static void simpleBLECentral_ProcessOSALMsg( osal_event_hdr_t *pMsg );
    static void simpleBLEGATTDiscoveryEvent( gattMsgEvent_t *pMsg );
    static void simpleBLECentralStartDiscovery( void );
    //static bool simpleBLEFindSvcUuid( uint16 uuid, uint8 *pData, uint8 dataLen );
    //static void simpleBLEAddDeviceInfo( uint8 *pAddr, uint8 addrType );
    void simpleBLECentralDisp(void);
    static void simpleBLEAddDeviceInfo_1(uint8 *pAddr, uint8 addrType,uint8 *pd, uint8 len,int8 rssi);
     * PROFILE CALLBACKS
    // GAP Role Callbacks
    static const gapCentralRoleCB_t simpleBLERoleCB =
      simpleBLECentralRssiCB,       // RSSI callback
      simpleBLECentralEventCB       // Event callback
    // Bond Manager Callbacks
    /*static const gapBondCBs_t simpleBLEBondCB =
      simpleBLECentralPasscodeCB,
     * PUBLIC FUNCTIONS
     * @fn      SimpleBLECentral_Init
     * @brief   Initialization function for the Simple BLE Central App Task.
     *          This is called during initialization and should contain
     *          any application specific initialization (ie. hardware
     *          initialization/setup, table initialization, power up
     *          notification).
     * @param   task_id - the ID assigned by OSAL.  This ID should be
     *                    used to send messages and set timers.
     * @return  none
    void SimpleBLECentral_Init( uint8 task_id )
      simpleBLETaskId = task_id;
      // Setup Central Profile
        uint8 scanRes = DEFAULT_MAX_SCAN_RES;
        GAPCentralRole_SetParameter ( GAPCENTRALROLE_MAX_SCAN_RES, sizeof( uint8 ), &scanRes );
        GAPObserverRole_SetParameter ( GAPOBSERVERROLE_MAX_SCAN_RES, sizeof( uint8 ), &scanRes );
      // Setup GAP
      GAP_SetParamValue( TGAP_GEN_DISC_SCAN, DEFAULT_SCAN_DURATION );
      GAP_SetParamValue( TGAP_LIM_DISC_SCAN, DEFAULT_SCAN_DURATION );
      GGS_SetParameter( GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, (uint8 *) simpleBLEDeviceName );
      // Setup the GAP Bond Manager
    #if 0
        uint32 passkey = DEFAULT_PASSCODE;
        uint8 pairMode = DEFAULT_PAIRING_MODE;
        uint8 mitm = DEFAULT_MITM_MODE;
        uint8 ioCap = DEFAULT_IO_CAPABILITIES;
        uint8 bonding = DEFAULT_BONDING_MODE;
        GAPBondMgr_SetParameter( GAPBOND_DEFAULT_PASSCODE, sizeof( uint32 ), &passkey );
        GAPBondMgr_SetParameter( GAPBOND_PAIRING_MODE, sizeof( uint8 ), &pairMode );
        GAPBondMgr_SetParameter( GAPBOND_MITM_PROTECTION, sizeof( uint8 ), &mitm );
        GAPBondMgr_SetParameter( GAPBOND_IO_CAPABILITIES, sizeof( uint8 ), &ioCap );
        GAPBondMgr_SetParameter( GAPBOND_BONDING_ENABLED, sizeof( uint8 ), &bonding );
    #endif
      // Initialize GATT Client
      VOID GATT_InitClient();
      // Register to receive incoming ATT Indications/Notifications
      GATT_RegisterForInd( simpleBLETaskId );
      // Initialize GATT attributes
      GGS_AddService( GATT_ALL_SERVICES );         // GAP
      GATTServApp_AddService( GATT_ALL_SERVICES ); // GATT attributes
      // Register for all key events - This app will handle all key events
      RegisterForKeys( simpleBLETaskId );
      // makes sure LEDs are off
      //HalLedSet( (HAL_LED_1 | HAL_LED_2), HAL_LED_MODE_OFF );
      // Setup a delayed profile startup
      osal_set_event( simpleBLETaskId, START_DEVICE_EVT );
    void simpleBLEStartScan()
          LCD_WRITE_STRING( "--simpleBLEStartScan", HAL_LCD_LINE_2 );
          //Serial_Delay(10);
        //����������Ͻ��У��Զ���ʼ����
        if ( (!simpleBLEScanning ) && (tagCen.disi_start == 1) && (sys_config.workMode == 1) /*&& (tagCen.start == 1)*/)
          simpleBLEScanning = TRUE;
          simpleBLEScanRes = 0;
          tagCen.disi_start = 0;
    /*      GAPCentralRole_StartDiscovery( DEFAULT_DISCOVERY_MODE,
                                         DEFAULT_DISCOVERY_ACTIVE_SCAN,
                                         DEFAULT_DISCOVERY_WHITE_LIST );
          LCD_WRITE_STRING( "Scanning...", HAL_LCD_LINE_1 );
          GAPObserverRole_StartDiscovery( DEFAULT_DISCOVERY_MODE,
          NPI_WriteTransport("Scanning...\r\n",13);
          //GAPCentralRole_StartRssi( simpleBLEConnHandle, DEFAULT_RSSI_PERIOD );
        else
          LCD_WRITE_STRING( "No Scan", HAL_LCD_LINE_1 );
          //NPI_WriteTransport("No Scan\r\n",9);
     * @fn      SimpleBLECentral_ProcessEvent
     * @brief   Simple BLE Central Application Task event processor.  This function
     *          is called to process all events for the task.  Events
     *          include timers, messages and any other user defined events.
     * @param   task_id  - The OSAL assigned task ID.
     * @param   events - events to process.  This is a bit map and can
     *                   contain more than one event.
     * @return  events not processed
    uint16 SimpleBLECentral_ProcessEvent( uint8 task_id, uint16 events )
      VOID task_id; // OSAL required parameter that isn't used in this function
      if ( events & SYS_EVENT_MSG )
        uint8 *pMsg;
        if ( (pMsg = osal_msg_receive( simpleBLETaskId )) != NULL )
          simpleBLECentral_ProcessOSALMsg( (osal_event_hdr_t *)pMsg );
          // Release the OSAL message
          VOID osal_msg_deallocate( pMsg );
        // return unprocessed events
        return (events ^ SYS_EVENT_MSG);
      if ( events & START_DEVICE_EVT )
        // Start the Device
       // VOID GAPCentralRole_StartDevice( (gapCentralRoleCB_t *) &simpleBLERoleCB );
        // Register with bond manager after starting device
       // GAPBondMgr_Register( (gapBondCBs_t *) &simpleBLEBondCB );
        //simpleBLEStartScan();
        // Start the Device
        VOID GAPObserverRole_StartDevice( (gapObserverRoleCB_t *) &simpleBLERoleCB );
        osal_start_timerEx( simpleBLETaskId, Cen_PERIODIC_EVT, SBP_PERIODIC_EVT_PERIOD );
    //    CheckKeyForSetAllParaDefault(); //��������3�룬 �ظ���������
        return ( events ^ START_DEVICE_EVT );
      if ( events & Cen_PERIODIC_EVT )
        // Restart timer
        if ( SBP_PERIODIC_EVT_PERIOD )
        // Perform periodic application task
    //    performPeriodicTask();
        if ( simpleBLEState == BLE_STATE_CONNECTED )
          if ( !simpleBLERssi )
            simpleBLERssi = TRUE;
            LCD_WRITE_STRING( "RSSI Start...", HAL_LCD_LINE_1 );
            NPI_WriteTransport("RSSI Start...\r\n",15);
        else
            if(simpleBLERssi)
                GAPCentralRole_CancelRssi( simpleBLEConnHandle );
                LCD_WRITE_STRING( "RSSI Cancelled", HAL_LCD_LINE_1 );
                NPI_WriteTransport("RSSI Cancelled\r\n",16);
            else
        return (events ^ Cen_PERIODIC_EVT);
      if ( events & START_DISCOVERY_EVT )
        simpleBLECentralStartDiscovery( );
        return ( events ^ START_DISCOVERY_EVT );
      if(events & Centrl_SCANIB_EVT )
        simpleBLECentralDisp();
        return ( events ^ Centrl_SCANIB_EVT );
      //�����λ
       if ( events & SBP_RESET_EVT )
        //delay
        uint32 i=0;
        for(i=100000;i>0;i--){
              asm("nop");
        SystemReset();
    //   return (events ^ SBP_RESET_EVT);
       // Discard unknown events
      return 0;
     * @fn      simpleBLECentral_ProcessOSALMsg
     * @brief   Process an incoming task message.
     * @param   pMsg - message to process
     * @return  none
      switch ( pMsg->event )
        case KEY_CHANGE:
          simpleBLECentral_HandleKeys( ((keyChange_t *)pMsg)->state, ((keyChange_t *)pMsg)->keys );
          break;
        case GATT_MSG_EVENT:
          simpleBLECentralProcessGATTMsg( (gattMsgEvent_t *) pMsg );
          break;
     * @fn      simpleBLECentral_HandleKeys
     * @brief   Handles all key events for this device.
     * @param   shift - true if in shift/alt.
     * @param   keys - bit field for key events. Valid entries:
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
    uint8 gStatus;
      (void)shift;  // Intentionally unreferenced parameter
    #if 0
      if ( keys & HAL_KEY_UP )
        LCD_WRITE_STRING( "HAL_KEY_UP", HAL_LCD_LINE_7 );
        // Start or stop discovery
        if ( simpleBLEState != BLE_STATE_CONNECTED )
          if ( !simpleBLEScanning )
            LCD_WRITE_STRING( "Discovering...", HAL_LCD_LINE_1 );
            LCD_WRITE_STRING( "", HAL_LCD_LINE_2 );
          else
            GAPCentralRole_CancelDiscovery();
        else if ( simpleBLEState == BLE_STATE_CONNECTED &&
                  simpleBLECharHdl != 0 &&
                  simpleBLEProcedureInProgress == FALSE )
          uint8 status;
          // Do a read or write as long as no other read or write is in progress
          if ( simpleBLEDoWrite )
            // Do a write
            attWriteReq_t req;
            req.pValue = GATT_bm_alloc( simpleBLEConnHandle, ATT_WRITE_REQ, 1, NULL );
            req.handle = simpleBLECharHdl;
            req.len = 1;
            req.pValue[0] = simpleBLECharVal;
            req.sig = 0;
            req.cmd = 0;
            status = GATT_WriteCharValue( simpleBLEConnHandle, &req, simpleBLETaskId );
              if ( status != SUCCESS )
                GATT_bm_free( (gattMsg_t *)&req, ATT_WRITE_REQ );
          else
            // Do a read
            attReadReq_t req;
            status = GATT_ReadCharValue( simpleBLEConnHandle, &req, simpleBLETaskId );
          if ( status == SUCCESS )
            simpleBLEProcedureInProgress = TRUE;
            simpleBLEDoWrite = !simpleBLEDoWrite;
      if ( keys & HAL_KEY_LEFT )
        LCD_WRITE_STRING( "HAL_KEY_LEFT", HAL_LCD_LINE_7 );
        // Display discovery results
        if ( !simpleBLEScanning && simpleBLEScanRes > 0 )
            // Increment index of current result (with wraparound)
            simpleBLEScanIdx++;
            if ( simpleBLEScanIdx >= simpleBLEScanRes )
              simpleBLEScanIdx = 0;
            LCD_WRITE_STRING_VALUE( "Device", simpleBLEScanIdx + 1,
                                    10, HAL_LCD_LINE_1 );
            LCD_WRITE_STRING( bdAddr2Str( simpleBLEDevList[simpleBLEScanIdx].addr ),
                              HAL_LCD_LINE_2 );
      if ( keys & HAL_KEY_RIGHT )
        LCD_WRITE_STRING( "HAL_KEY_RIGHT", HAL_LCD_LINE_7 );
        // Connection update
          GAPCentralRole_UpdateLink( simpleBLEConnHandle,
                                     DEFAULT_UPDATE_MIN_CONN_INTERVAL,
                                     DEFAULT_UPDATE_MAX_CONN_INTERVAL,
                                     DEFAULT_UPDATE_SLAVE_LATENCY,
                                     DEFAULT_UPDATE_CONN_TIMEOUT );
      if ( keys & HAL_KEY_CENTER )
        uint8 addrType;
        uint8 *peerAddr;
        LCD_WRITE_STRING( "HAL_KEY_CENTER", HAL_LCD_LINE_7 );
        // Connect or disconnect
        if ( simpleBLEState == BLE_STATE_IDLE )
          // if there is a scan result
          if ( simpleBLEScanRes > 0 )
            // connect to current device in scan result
            peerAddr = simpleBLEDevList[simpleBLEScanIdx].addr;
            addrType = simpleBLEDevList[simpleBLEScanIdx].addrType;
            simpleBLEState = BLE_STATE_CONNECTING;
            GAPCentralRole_EstablishLink( DEFAULT_LINK_HIGH_DUTY_CYCLE,
                                          DEFAULT_LINK_WHITE_LIST,
                                          addrType, peerAddr );
            LCD_WRITE_STRING( "Connecting", HAL_LCD_LINE_1 );
            LCD_WRITE_STRING( bdAddr2Str( peerAddr ), HAL_LCD_LINE_2 );
        else if ( simpleBLEState == BLE_STATE_CONNECTING ||
          // disconnect
          simpleBLEState = BLE_STATE_DISCONNECTING;
          gStatus = GAPCentralRole_TerminateLink( simpleBLEConnHandle );
          LCD_WRITE_STRING( "Disconnecting", HAL_LCD_LINE_1 );
      if ( keys & HAL_KEY_DOWN )
        LCD_WRITE_STRING( "HAL_KEY_DOWN", HAL_LCD_LINE_7 );
        // Start or cancel RSSI polling
          else
    #endif
     * @fn      simpleBLECentralProcessGATTMsg
     * @brief   Process GATT messages
     * @return  none
        // In case a GATT message came after a connection has dropped,
        // ignore the message
        return;
      if ( ( pMsg->method == ATT_READ_RSP ) ||
           ( ( pMsg->method == ATT_ERROR_RSP ) &&
             ( pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ ) ) )
        if ( pMsg->method == ATT_ERROR_RSP )
    //      uint8 status = pMsg->msg.errorRsp.errCode;
    //      LCD_WRITE_STRING_VALUE( "Read Error", status, 10, HAL_LCD_LINE_1 );
        else
          // After a successful read, display the read value
    //      uint8 valueRead = pMsg->msg.readRsp.pValue[0];
    //      LCD_WRITE_STRING_VALUE( "Read rsp:", valueRead, 10, HAL_LCD_LINE_1 );
        //simpleBLEProcedureInProgress = FALSE;
      else if ( ( pMsg->method == ATT_WRITE_RSP ) ||
             ( pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ ) ) )
        if ( pMsg->method == ATT_ERROR_RSP == ATT_ERROR_RSP )
    //      LCD_WRITE_STRING_VALUE( "Write Error", status, 10, HAL_LCD_LINE_1 );
        else
          // After a succesful write, display the value that was written and increment value
          //LCD_WRITE_STRING_VALUE( "Write sent:", simpleBLECharVal++, 10, HAL_LCD_LINE_1 );
          // ����������ڱ�����һ��д���ݵ��ӻ��Ѿ��ɹ��� �������ж�д����ʱ���жϣ� ��ȷ�����ݵ�������
      else if ( simpleBLEDiscState != BLE_DISC_STATE_IDLE )
        simpleBLEGATTDiscoveryEvent( pMsg );
      else if ( ( pMsg->method == ATT_HANDLE_VALUE_NOTI ) )   //֪ͨ
        if( pMsg->msg.handleValueNoti.handle == 0x0035)   //CHAR6��֪ͨ  ���ڴ�ӡ
            NPI_WriteTransport(pMsg->msg.handleValueNoti.pValue, pMsg->msg.handleValueNoti.len );
     * @fn      simpleBLECentralRssiCB
     * @brief   RSSI callback.
     * @param   connHandle - connection handle
     * @param   rssi - RSSI
     * @return  none
        char strTp[64];
        LCD_WRITE_STRING_VALUE( "RSSI -dB:", (uint8) (-rssi), 10, HAL_LCD_LINE_1 );
        simpleBle_SetRssi(rssi);
        sprintf(strTp, "RSSI -dB:%d\r\n", (uint8)(-sys_config.rssi));
        NPI_WriteTransport((uint8*)strTp, osal_strlen(strTp));
     * @fn      simpleBLECentralEventCB
     * @brief   Central event callback function.
     * @param   pEvent - pointer to event structure
     * @return  none
    //  gapCentralRoleEvent_t *pTp;
      switch ( pEvent->gap.opcode )
        case GAP_DEVICE_INIT_DONE_EVENT:
            LCD_WRITE_STRING( "BLE Central", HAL_LCD_LINE_1 );
            LCD_WRITE_STRING( bdAddr2Str( pEvent->initDone.devAddr ),  HAL_LCD_LINE_2 );
            NPI_WriteTransport("BLE Central\r\n",13);
          break;
        case GAP_DEVICE_INFO_EVENT:
            // if filtering device discovery results based on service UUID
            if ( DEFAULT_DEV_DISC_BY_SVC_UUID == TRUE )
    /*          if ( simpleBLEFindSvcUuid( SIMPLEPROFILE_SERV_UUID,
                                         pEvent->deviceInfo.pEvtData,
                                         pEvent->deviceInfo.dataLen ) )*/
    //            pTp = pEvent;
    //            simpleBLEAddDeviceInfo( pEvent->deviceInfo.addr, pEvent->deviceInfo.addrType );
            simpleBLEAddDeviceInfo_1(pEvent->deviceInfo.addr, pEvent->deviceInfo.addrType,pEvent->deviceInfo.pEvtData,pEvent->deviceInfo.dataLen,pEvent->deviceInfo.rssi);
          break;
        case GAP_DEVICE_DISCOVERY_EVENT:
            // discovery complete
            // if not filtering device discovery results based on service UUID
            if ( DEFAULT_DEV_DISC_BY_SVC_UUID == FALSE )
              // Copy results
              simpleBLEScanRes = pEvent->discCmpl.numDevs;
              osal_memcpy( simpleBLEDevList, pEvent->discCmpl.pDevList,
                           (sizeof( gapDevRec_t ) * pEvent->discCmpl.numDevs) );
            LCD_WRITE_STRING_VALUE( "Devices Found", simpleBLEScanRes,
                LCD_WRITE_STRING( "<- To Select", HAL_LCD_LINE_2 );
                //������Ծ������ӵ�������������һ���ӻ��� ������Խ��дӻ���ַ����жϣ� ���磬 �������ӵ����һ�����ӳɹ���mac��ַ�Ĵӻ�
                //HalLedSet(HAL_LED_3, HAL_LED_MODE_ON );   //��LED3
               if ( (simpleBLEState == BLE_STATE_IDLE) ||(simpleBLEState == BLE_STATE_DISCONNECTING) )
                 //  uint8 addrType;
                 // uint8 *peerAddr;
                  uint8 i;
                  //uint8 Addr[MAC_ADDR_CHAR_LEN];
                  uint8 strTp[81];
                  char strUUID1[17];
                  char strUUID2[17];
                  char strmaj[11];
                  char strVendor[9];
                  //bool ret = FALSE;;
                  //bool ifDoConnect = FALSE;
                  for(i = 0; i < simpleBLEScanRes; i++)
                      LCD_WRITE_STRING_VALUE( "--->peerAddr ", i, 10, HAL_LCD_LINE_2 );
                      //Serial_Delay(1);
                      LCD_WRITE_STRING( bdAddr2Str( simpleBLEDevList[i].addr ), HAL_LCD_LINE_2 );
                      //Serial_Delay(1);
     /*                 sprintf((char *)&strTp, "OK+DISC:%.8s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[5],4));
                      NPI_WriteTransport((uint8 *)strTp, osal_strlen((char *)strTp));
                      //Serial_Delay(10);
                      //sprintf((char *)&strTp[16], ":%.32s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[9],16));
                      sprintf((char *)strTp, ":%.16s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[9],8));
                      sprintf((char *)strTp, "%.16s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[17],8));
                      //Serial_Delay(10);
                      //sprintf((char *)&strTp[49], ":%.10s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[25],5));
                      sprintf((char *)strTp, ":%.10s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[25],5));
                      //Serial_Delay(10);
                      //sprintf((char *)&strTp[60], ":%.12s:-%0.3d\r\n", bdAddr2Str( simpleBLEDevList[i].addr ),tagCibe.gapDevRec_rssi[i]);
                      sprintf((char *)strTp, ":%.12s:-%0.3d\r\n", bdAddr2Str( simpleBLEDevList[i].addr ),tagCibe.gapDevRec_rssi[i]);
                      sprintf((char *)strVendor, "%.9s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[5],4));
                      sprintf((char *)strUUID1, "%.17s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[9],8));
                      sprintf((char *)strUUID2, "%.17s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[17],8));
                      sprintf((char *)strmaj, "%.11s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[25],5));
                      if(osal_memcmp(&tagCibe.gapDevRec_tp[i].data[5], "\x4C\x00\x02\x15" , 4 ) == 0)
                        osal_memset(strUUID1,'0',17);
                        osal_memset(strUUID2,'0',17);
                        osal_memset(strmaj,'0',11);
                        osal_memset(strVendor,'0',9);
                      sprintf((char *)strTp, "OK+DISC:%.8s:%.16s%.16s:%.10s:%.12s:-%0.3d\r\n",strVendor,strUUID1,strUUID2,strmaj, bdAddr2Str( simpleBLEDevList[i].addr ),tagCibe.gapDevRec_rssi[i]);
                  Serial_Delay(2);
                  //debug
             // osal_set_event(simpleBLETaskId, Centrl_SCANIB_EVT);
             /*     NPI_WriteTransport((uint8 *)strTp, 96);
                  NPI_WriteTransport((uint8 *)&strTp[96], 96);
                  NPI_WriteTransport((uint8 *)&strTp[192], 96);
                  NPI_WriteTransport((uint8 *)&strTp[288], 96);*/
                  NPI_WriteTransport("OK+DISCE", osal_strlen("OK+DISCE"));
                 // GAPCentralRole_CancelRssi( simpleBLEConnHandle );
                  //Serial_Delay(10);
                  //Serial_Delay(1);
    #if 0//�Զ����ӷ��ֵĵ�һ�����豸
                  ret = simpleBLE_GetPeripheralMacAddr(Addr);
                  //LCD_WRITE_STRING_VALUE( "--->ret ", ret, 10, HAL_LCD_LINE_2 );
                  //Serial_Delay(1);
                  //simpleBLEScanIdx = 0;
                      LCD_WRITE_STRING_VALUE( "peerAddr ", i, 10, HAL_LCD_LINE_2 );
                      peerAddr = simpleBLEDevList[i].addr;
                      addrType = simpleBLEDevList[i].addrType;
                      if(ret == FALSE) //���û�м�¼��ַ�� ���¼��ַ�� �����ӵ�һ�����豸
                        simpleBLE_SetPeripheralMacAddr((uint8*)bdAddr2Str( simpleBLEDevList[i].addr )+2);
                        simpleBLE_SaveAllDataToFlash();
                        //simpleBLEScanIdx = i;
                        ifDoConnect = TRUE;
                        break;
                      else
                          //ָ������ij�豸, ����ô�ɨ��û��֮ǰ���ӹ��ĵ�ַ�� �򲻽�������
                          if(osal_memcmp(Addr, bdAddr2Str( simpleBLEDevList[i].addr )+2, MAC_ADDR_CHAR_LEN))
                            ifDoConnect = TRUE;
                            break;
    #endif
    #if 0// ����ָ��MAC��ַ�Ĵ��豸
                if(simpleBLE_GetToConnectFlag(Addr))
                  // ����ָ����mac ��ַ�Ĵӻ��豸
                        ifDoConnect = TRUE;
                        break;
    #endif
    /*              if(ifDoConnect)
                     LCD_WRITE_STRING( bdAddr2Str( pEvent->linkCmpl.devAddr ), HAL_LCD_LINE_2 );
                     //sprintf(strTp, "establishlink:%s\r\n", bdAddr2Str( peerAddr ));
                     //NPI_WriteTransport((uint8*)strTp, osal_strlen(strTp));
                  else     */
                    //LCD_WRITE_STRING( "Continue scanning", HAL_LCD_LINE_1 );
                    //NPI_WriteTransport("Scanning...", 11);
                    // ����ɨ��
    //                simpleBLEScanRes = 0;
    //                simpleBLERssi = 0;
    //                simpleBLEStartScan();
                //HalLedSet(HAL_LED_3, HAL_LED_MODE_OFF );
                // initialize scan index to last device
                //simpleBLEScanIdx = simpleBLEScanRes;
            else
                simpleBLERssi = 0;
          break;
        case GAP_LINK_ESTABLISHED_EVENT:
            if ( pEvent->gap.hdr.status == SUCCESS )
              simpleBLEState = BLE_STATE_CONNECTED;
              simpleBLEConnHandle = pEvent->linkCmpl.connectionHandle;
              //simpleBLEProcedureInProgress = TRUE;
              // If service discovery not performed initiate service discovery
              if ( simpleBLECharHdl == 0 )
                osal_start_timerEx( simpleBLETaskId, START_DISCOVERY_EVT, DEFAULT_SVC_DISCOVERY_DELAY );
              LCD_WRITE_STRING( "Connected", HAL_LCD_LINE_1 );
             // HalLedSet(HAL_LED_3, HAL_LED_MODE_OFF );
            else
              //simpleBLERssi = FALSE;
              LCD_WRITE_STRING( "Connect Failed", HAL_LCD_LINE_1 );
              LCD_WRITE_STRING_VALUE( "Reason:", pEvent->gap.hdr.status, 10, HAL_LCD_LINE_2 );
              //HalLedSet(HAL_LED_3, HAL_LED_MODE_OFF );   //��LED3
          break;
        case GAP_LINK_TERMINATED_EVENT:
            LCD_WRITE_STRING( "Disconnected", HAL_LCD_LINE_1 );
            LCD_WRITE_STRING_VALUE( "Reason:", pEvent->linkTerminate.reason,
            //��������ʧ�ܺ� ���Գ���ִ��������߼���ɨ��ӻ�
            LCD_WRITE_STRING_VALUE( "simpleBLEScanning=", simpleBLEScanning, 10, HAL_LCD_LINE_1 );
            LCD_WRITE_STRING_VALUE( "simpleBLEScanRes=", simpleBLEScanRes, 10, HAL_LCD_LINE_1 );
            simpleBLEScanning = 0;
          break;
        case GAP_LINK_PARAM_UPDATE_EVENT:
            attWriteReq_t AttReq;
            uint8 ValueBuf[2];
            LCD_WRITE_STRING( "Param Update", HAL_LCD_LINE_1);
            AttReq.handle = 0x0036;
            AttReq.len = 2;
            AttReq.sig = 0;
            AttReq.cmd = 0;
            ValueBuf[0] = 0x01;
            ValueBuf[1] = 0x00;
            osal_memcpy(AttReq.pValue,ValueBuf,2);
            GATT_WriteCharValue( 0, &AttReq, simpleBLETaskId );
            LCD_WRITE_STRING( "Enable Notice\n", HAL_LCD_LINE_1);
            simpleBLECentralCanSend = TRUE;
            NPI_WriteTransport("Connected\r\n", 11);
          break;
        default:
          break;
       return ( TRUE );
     * @fn      pairStateCB
     * @brief   Pairing state callback.
     * @return  none
    /*static void simpleBLECentralPairStateCB( uint16 connHandle, uint8 state, uint8 status )
      if ( state == GAPBOND_PAIRING_STATE_STARTED )
        LCD_WRITE_STRING( "Pairing started", HAL_LCD_LINE_1 );
      else if ( state == GAPBOND_PAIRING_STATE_COMPLETE )
          LCD_WRITE_STRING( "Pairing success", HAL_LCD_LINE_1 );
        else
          LCD_WRITE_STRING_VALUE( "Pairing fail", status, 10, HAL_LCD_LINE_1 );
      else if ( state == GAPBOND_PAIRING_STATE_BONDED )
          LCD_WRITE_STRING( "Bonding success", HAL_LCD_LINE_1 );
     * @fn      simpleBLECentralPasscodeCB
     * @brief   Passcode callback.
     * @return  none
    /*static void simpleBLECentralPasscodeCB( uint8 *deviceAddr, uint16 connectionHandle,
    #if (HAL_LCD == TRUE)
      uint32  passcode;
      uint8   str[7];
      // Create random passcode
      LL_Rand( ((uint8 *) &passcode), sizeof( uint32 ));
      passcode %= 1000000;
      // Display passcode to user
      if ( uiOutputs != 0 )
        LCD_WRITE_STRING( "Passcode:",  HAL_LCD_LINE_1 );
        LCD_WRITE_STRING( (char *) _ltoa(passcode, str, 10),  HAL_LCD_LINE_2 );
      // Send passcode response
      GAPBondMgr_PasscodeRsp( connectionHandle, SUCCESS, passcode );
    #endif
     * @fn      simpleBLECentralStartDiscovery
     * @brief   Start service discovery.
     * @return  none
      uint8 uuid[ATT_BT_UUID_SIZE] = { LO_UINT16(SIMPLEPROFILE_SERV_UUID),
                                       HI_UINT16(SIMPLEPROFILE_SERV_UUID) };
      // Initialize cached handles
      simpleBLESvcStartHdl = simpleBLESvcEndHdl = simpleBLECharHdl = 0;
      simpleBLEDiscState = BLE_DISC_STATE_SVC;
      // Discovery simple BLE service
      GATT_DiscPrimaryServiceByUUID( simpleBLEConnHandle,
                                     uuid,
                                     ATT_BT_UUID_SIZE,
                                     simpleBLETaskId );
     * @fn      simpleBLEGATTDiscoveryEvent
     * @brief   Process GATT discovery event
     * @return  none
      attReadByTypeReq_t req;
      if ( simpleBLEDiscState == BLE_DISC_STATE_SVC )
        // Service found, store handles
        if ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&
             pMsg->msg.findByTypeValueRsp.numInfo > 0 )
          simpleBLESvcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
          simpleBLESvcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
        // If procedure complete
        if ( ( pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP  &&
               pMsg->hdr.status == bleProcedureComplete ) ||
             ( pMsg->method == ATT_ERROR_RSP ) )
          if ( simpleBLESvcStartHdl != 0 )
            // Discover characteristic
            simpleBLEDiscState = BLE_DISC_STATE_CHAR;
            req.startHandle = simpleBLESvcStartHdl;
            req.endHandle = simpleBLESvcEndHdl;
            req.type.len = ATT_BT_UUID_SIZE;
            req.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR4_UUID);
            req.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR4_UUID);
            GATT_ReadUsingCharUUID( simpleBLEConnHandle, &req, simpleBLETaskId );
      else if ( simpleBLEDiscState == BLE_DISC_STATE_CHAR )
        // Characteristic found, store handle
        if ( pMsg->method == ATT_READ_BY_TYPE_RSP &&
             pMsg->msg.readByTypeRsp.numPairs > 0 )
          simpleBLECharHd6 = BUILD_UINT16( pMsg->msg.readByTypeRsp.pDataList[0],
                                           pMsg->msg.readByTypeRsp.pDataList[1] );
          LCD_WRITE_STRING( "Simple Svc Found", HAL_LCD_LINE_1 );
     * @fn      simpleBLEFindSvcUuid
     * @brief   Find a given UUID in an advertiser's service UUID list.
     * @return  TRUE if service UUID found
    /*static bool simpleBLEFindSvcUuid( uint16 uuid, uint8 *pData, uint8 dataLen )
      uint8 adLen;
      uint8 adType;
      uint8 *pEnd;
      pEnd = pData + dataLen - 1;
      // While end of data not reached
      while ( pData < pEnd )
        // Get length of next AD item
        adLen = *pData++;
        if ( adLen > 0 )
          adType = *pData;
          // If AD type is for 16-bit service UUID
          if ( adType == GAP_ADTYPE_16BIT_MORE || adType == GAP_ADTYPE_16BIT_COMPLETE )
            pData++;
            adLen--;
            // For each UUID in list
            while ( adLen >= 2 && pData < pEnd )
              // Check for match
              if ( pData[0] == LO_UINT16(uuid) && pData[1] == HI_UINT16(uuid) )
                // Match found
                return TRUE;
              // Go to next
              pData += 2;
              adLen -= 2;
            // Handle possible erroneous extra byte in UUID list
            if ( adLen == 1 )
              pData++;
          else
            // Go to next item
            pData += adLen;
      // Match not found
      return FALSE;
     * @fn      simpleBLEAddDeviceInfo
     * @brief   Add a device to the device discovery result list
     * @return  none
    /*static void simpleBLEAddDeviceInfo( uint8 *pAddr, uint8 addrType)
      uint8 i;
      // If result count not at max
      if ( simpleBLEScanRes < DEFAULT_MAX_SCAN_RES )
        // Check if device is already in scan results
        for ( i = 0; i < simpleBLEScanRes; i++ )
          if ( osal_memcmp( pAddr, simpleBLEDevList[i].addr , B_ADDR_LEN ) )
            return;
        // Add addr to scan result list
        osal_memcpy( simpleBLEDevList[simpleBLEScanRes].addr, pAddr, B_ADDR_LEN );
        simpleBLEDevList[simpleBLEScanRes].addrType = addrType;
        // Increment scan result count
        simpleBLEScanRes++;
       uint8 i;
            return;
        osal_memcpy(&tagCibe.gapDevRec_tp[simpleBLEScanRes],pd,len);
        tagCibe.gapDevRec_rssi[simpleBLEScanRes] = 256 - (uint8)rssi;
        simpleBLEScanRes++;
    //xianshifunction
                  uint8 i;
                  uint8 strTp[80];
                      sprintf((char *)&strTp, "OK+DISC:%s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[5],4));
                      sprintf((char *)&strTp[16], ":%s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[9],16));
                      sprintf((char *)&strTp[49], ":%s",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[25],5));
                      sprintf((char *)&strTp[60], ":%s:-%0.3d\r\n", bdAddr2Str( simpleBLEDevList[i].addr ),tagCibe.gapDevRec_rssi[i]);
                      //sprintf((char *)&strTp[0], "OK+DISC:%s:%s:%s:%s:-%d\r\n",bdhex2Str(&tagCibe.gapDevRec_tp[i].data[5],4),bdhex2Str(&tagCibe.gapDevRec_tp[i].data[9],16),bdhex2Str(&tagCibe.gapDevRec_tp[i].data[25],5), bdAddr2Str( simpleBLEDevList[i].addr ),tagCibe.gapDevRec_rssi[i]);
  • 这个是新增的源文件
  • 有结果么???????怎么解决这个问题哦??????
