CC2640R2F 的CCFG.c有么有说明文件呢?
* Filename: ccfg.c
* Revised: $Date: 2017-02-09 13:34:22 +0100 (to, 09 feb 2017) $
* Revision: $Revision: 17663 $
* Description: Customer Configuration for CC26xx device family (HW rev 2).
* Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#ifndef __CCFC_C__
#define __CCFC_C__
#include <stdint.h>
#include "../inc/hw_types.h"
#include "../inc/hw_ccfg.h"
#include "../inc/hw_ccfg_simple_struct.h"
// Introduction
// This file contains fields used by Boot ROM, startup code, and SW radio
// stacks to configure chip behavior.
// Fields are documented in more details in hw_ccfg.h and CCFG.html in
// DriverLib documentation (doc_overview.html -> CPU Domain Memory Map -> CCFG).
// PLEASE NOTE:
// It is not recommended to do modifications inside this file.
// This file is part of the CoreSDK release and future releases may have
// important modifications and new fields added without notice.
// The recommended method to do customer modifications to the CCFG settings
// is to have your own <customer_ccfg_file>.c file that defines specific
// CCFG values to override and then includes the ccfg.c file.
// Example:
// #define SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE 0xC5 // Enable ROM boot loader
// #define SET_CCFG_MODE_CONF_SCLK_LF_OPTION 0x3 // LF RCOSC
// //---- Use default values for all others ----
// #include "<project-path>/source/ti/devices/<device>/startup_files/ccfg.c"
// Set the values of the individual bit fields.
// Alternative DC/DC settings
#ifndef SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING
#define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING 0x0 // Alternative DC/DC setting enabled
// #define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING 0x1 // Alternative DC/DC setting disabled
#endif
#ifndef SET_CCFG_MODE_CONF_1_ALT_DCDC_VMIN
#define SET_CCFG_MODE_CONF_1_ALT_DCDC_VMIN 0x8 // 2.25V
#endif
#ifndef SET_CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN
#define SET_CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN 0x0 // Disable
// #define SET_CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN 0x1 // Enable
#endif
#ifndef SET_CCFG_MODE_CONF_1_ALT_DCDC_IPEAK
#define SET_CCFG_MODE_CONF_1_ALT_DCDC_IPEAK 0x2 // 39mA
#endif
// XOSC override settings
#ifndef SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR
// #define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR 0x0 // Enable override
#define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR 0x1 // Disable override
#endif
#ifndef SET_CCFG_MODE_CONF_1_DELTA_IBIAS_INIT
#define SET_CCFG_MODE_CONF_1_DELTA_IBIAS_INIT 0x0 // Delta = 0
#endif
#ifndef SET_CCFG_MODE_CONF_1_DELTA_IBIAS_OFFSET
#define SET_CCFG_MODE_CONF_1_DELTA_IBIAS_OFFSET 0x0 // Delta = 0
#endif
#ifndef SET_CCFG_MODE_CONF_1_XOSC_MAX_START
#define SET_CCFG_MODE_CONF_1_XOSC_MAX_START 0x10 // 1600us
#endif
// Power settings
#ifndef SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_DELTA
#define SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_DELTA 0xF // Signed delta value +1 to apply to the VDDR_TRIM_SLEEP target (0xF=-1=default=no compensation)
#endif
#ifndef SET_CCFG_MODE_CONF_DCDC_RECHARGE
#define SET_CCFG_MODE_CONF_DCDC_RECHARGE 0x0 // Use the DC/DC during recharge in powerdown
// #define SET_CCFG_MODE_CONF_DCDC_RECHARGE 0x1 // Do not use the DC/DC during recharge in powerdown
#endif
#ifndef SET_CCFG_MODE_CONF_DCDC_ACTIVE
#define SET_CCFG_MODE_CONF_DCDC_ACTIVE 0x0 // Use the DC/DC during active mode
// #define SET_CCFG_MODE_CONF_DCDC_ACTIVE 0x1 // Do not use the DC/DC during active mode
#endif
#ifndef SET_CCFG_MODE_CONF_VDDS_BOD_LEVEL
// #define SET_CCFG_MODE_CONF_VDDS_BOD_LEVEL 0x0 // VDDS BOD level is 2.0V
#define SET_CCFG_MODE_CONF_VDDS_BOD_LEVEL 0x1 // VDDS BOD level is 1.8V (or 1.65V for external regulator mode)
#endif
#ifndef SET_CCFG_MODE_CONF_VDDR_CAP
#define SET_CCFG_MODE_CONF_VDDR_CAP 0x64//0x3A // Unsigned 8-bit integer representing the min. decoupling capacitance on VDDR in units of 100nF
#endif
#ifndef SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC
#define SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC 0x1 // Temperature compensation on VDDR sleep trim disabled (default)
// #define SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC 0x0 // Temperature compensation on VDDR sleep trim enabled
#endif
// Clock settings
#ifndef SET_CCFG_MODE_CONF_SCLK_LF_OPTION
// #define SET_CCFG_MODE_CONF_SCLK_LF_OPTION 0x0 // LF clock derived from High Frequency XOSC
// #define SET_CCFG_MODE_CONF_SCLK_LF_OPTION 0x1 // External LF clock
//#define SET_CCFG_MODE_CONF_SCLK_LF_OPTION 0x2 // LF XOSC
#endif
#ifndef SET_CCFG_MODE_CONF_XOSC_CAP_MOD
// #define SET_CCFG_MODE_CONF_XOSC_CAP_MOD 0x0 // Apply cap-array delta
#define SET_CCFG_MODE_CONF_XOSC_CAP_MOD 0x1 // Don't apply cap-array delta
#endif
#ifndef SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA
#define SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA 0xFF // Signed 8-bit value, directly modifying trimmed XOSC cap-array value
#endif
#ifndef SET_CCFG_EXT_LF_CLK_DIO
#define SET_CCFG_EXT_LF_CLK_DIO 0x01 // DIO number if using external LF clock
#endif
#ifndef SET_CCFG_EXT_LF_CLK_RTC_INCREMENT
#define SET_CCFG_EXT_LF_CLK_RTC_INCREMENT 0x800000 // RTC increment representing the external LF clock frequency
#endif
// Special HF clock source setting
#ifndef SET_CCFG_MODE_CONF_XOSC_FREQ
// #define SET_CCFG_MODE_CONF_XOSC_FREQ 0x1 // Use HPOSC as HF source (if executing on a HPOSC chip, otherwise using default (=0x3))
// #define SET_CCFG_MODE_CONF_XOSC_FREQ 0x2 // HF source is a 48 MHz xtal
#define SET_CCFG_MODE_CONF_XOSC_FREQ 0x3 // HF source is a 24 MHz xtal (default)
#endif
// Bootloader settings
#ifndef SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE
#define SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE 0x00 // Disable ROM boot loader
#endif
#ifndef SET_CCFG_BL_CONFIG_BL_LEVEL
// #define SET_CCFG_BL_CONFIG_BL_LEVEL 0x0 // Active low to open boot loader backdoor
#define SET_CCFG_BL_CONFIG_BL_LEVEL 0x1 // Active high to open boot loader backdoor
#endif
#ifndef SET_CCFG_BL_CONFIG_BL_PIN_NUMBER
#define SET_CCFG_BL_CONFIG_BL_PIN_NUMBER 0xFF // DIO number for boot loader backdoor
#endif
#ifndef SET_CCFG_BL_CONFIG_BL_ENABLE
// #define SET_CCFG_BL_CONFIG_BL_ENABLE 0xC5 // Enabled boot loader backdoor
#define SET_CCFG_BL_CONFIG_BL_ENABLE 0xFF // Disabled boot loader backdoor
#endif
// Debug access settings
#ifndef SET_CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE
#define SET_CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE 0x00 // Disable unlocking of TI FA option.
// #define SET_CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE 0xC5 // Enable unlocking of TI FA option with the unlock code
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE
// #define SET_CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE 0x00 // Access disabled
#define SET_CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE
#define SET_CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE 0x00 // Access disabled
// #define SET_CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE
// #define SET_CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE 0x00 // Access disabled
#define SET_CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE
#define SET_CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE 0x00 // Access disabled
// #define SET_CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE
#define SET_CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE 0x00 // Access disabled
// #define SET_CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
#ifndef SET_CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE
#define SET_CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE 0x00 // Access disabled
// #define SET_CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE 0xC5 // Access enabled if also enabled in FCFG
#endif
// Alternative IEEE 802.15.4 MAC address
#ifndef SET_CCFG_IEEE_MAC_0
#define SET_CCFG_IEEE_MAC_0 0xFFFFFFFF // Bits [31:0]
#endif
#ifndef SET_CCFG_IEEE_MAC_1
#define SET_CCFG_IEEE_MAC_1 0xFFFFFFFF // Bits [63:32]
#endif
// Alternative BLE address
#ifndef SET_CCFG_IEEE_BLE_0
#define SET_CCFG_IEEE_BLE_0 0xFFFFFFFF // Bits [31:0]
#endif
#ifndef SET_CCFG_IEEE_BLE_1
#define SET_CCFG_IEEE_BLE_1 0xFFFFFFFF // Bits [63:32]
#endif
// Flash erase settings
#ifndef SET_CCFG_ERASE_CONF_CHIP_ERASE_DIS_N
// #define SET_CCFG_ERASE_CONF_CHIP_ERASE_DIS_N 0x0 // Any chip erase request detected during boot will be ignored
#define SET_CCFG_ERASE_CONF_CHIP_ERASE_DIS_N 0x1 // Any chip erase request detected during boot will be performed by the boot FW
#endif
#ifndef SET_CCFG_ERASE_CONF_BANK_ERASE_DIS_N
// #define SET_CCFG_ERASE_CONF_BANK_ERASE_DIS_N 0x0 // Disable the boot loader bank erase function
#define SET_CCFG_ERASE_CONF_BANK_ERASE_DIS_N 0x1 // Enable the boot loader bank erase function
#endif
// Flash image valid
#ifndef SET_CCFG_IMAGE_VALID_CONF_IMAGE_VALID
#define SET_CCFG_IMAGE_VALID_CONF_IMAGE_VALID 0x00000000 // Flash image is valid
// #define SET_CCFG_IMAGE_VALID_CONF_IMAGE_VALID <non-zero> // Flash image is invalid, call bootloader
#endif
// Flash sector write protection
#ifndef SET_CCFG_CCFG_PROT_31_0
#define SET_CCFG_CCFG_PROT_31_0 0xFFFFFFFF
#endif
#ifndef SET_CCFG_CCFG_PROT_63_32
#define SET_CCFG_CCFG_PROT_63_32 0xFFFFFFFF
#endif
#ifndef SET_CCFG_CCFG_PROT_95_64
#define SET_CCFG_CCFG_PROT_95_64 0xFFFFFFFF
#endif
#ifndef SET_CCFG_CCFG_PROT_127_96
#define SET_CCFG_CCFG_PROT_127_96 0xFFFFFFFF
#endif
// Select between cache or GPRAM
#ifndef SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM
// #define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM 0x0 // Cache is disabled and GPRAM is available at 0x11000000-0x11001FFF
#define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM 0x1 // Cache is enabled and GPRAM is disabled (unavailable)
#endif
// Select TCXO
#ifndef SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO
#define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO 0x1 // Disable TCXO
// #define SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO 0x0 // Enable TXCO
#endif
// CCFG values that should not be modified.
#define SET_CCFG_SIZE_AND_DIS_FLAGS_SIZE_OF_CCFG 0x0058
#define SET_CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS (CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS_M >> CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS_S)
#define SET_CCFG_MODE_CONF_VDDR_EXT_LOAD 0x1
#define SET_CCFG_MODE_CONF_RTC_COMP 0x1
#define SET_CCFG_MODE_CONF_HF_COMP 0x1
#define SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP45 0xFF
#define SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP25 0xFF
#define SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP5 0xFF
#define SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TM15 0xFF
#define SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP125 0xFF
#define SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP105 0xFF
#define SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP85 0xFF
#define SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP65 0xFF
#define SET_CCFG_RTC_OFFSET_RTC_COMP_P0 0xFFFF
#define SET_CCFG_RTC_OFFSET_RTC_COMP_P1 0xFF
#define SET_CCFG_RTC_OFFSET_RTC_COMP_P2 0xFF
#define SET_CCFG_FREQ_OFFSET_HF_COMP_P0 0xFFFF
#define SET_CCFG_FREQ_OFFSET_HF_COMP_P1 0xFF
#define SET_CCFG_FREQ_OFFSET_HF_COMP_P2 0xFF
// Concatenate bit fields to words.
// DO NOT EDIT!
#define DEFAULT_CCFG_EXT_LF_CLK ( \
( ((uint32_t)( SET_CCFG_EXT_LF_CLK_DIO << CCFG_EXT_LF_CLK_DIO_S )) | ~CCFG_EXT_LF_CLK_DIO_M ) & \
( ((uint32_t)( SET_CCFG_EXT_LF_CLK_RTC_INCREMENT << CCFG_EXT_LF_CLK_RTC_INCREMENT_S )) | ~CCFG_EXT_LF_CLK_RTC_INCREMENT_M ) )
#define DEFAULT_CCFG_MODE_CONF_1 ( \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_ALT_DCDC_VMIN << CCFG_MODE_CONF_1_ALT_DCDC_VMIN_S )) | ~CCFG_MODE_CONF_1_ALT_DCDC_VMIN_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN << CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN_S )) | ~CCFG_MODE_CONF_1_ALT_DCDC_DITHER_EN_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_ALT_DCDC_IPEAK << CCFG_MODE_CONF_1_ALT_DCDC_IPEAK_S )) | ~CCFG_MODE_CONF_1_ALT_DCDC_IPEAK_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_DELTA_IBIAS_INIT << CCFG_MODE_CONF_1_DELTA_IBIAS_INIT_S )) | ~CCFG_MODE_CONF_1_DELTA_IBIAS_INIT_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_DELTA_IBIAS_OFFSET << CCFG_MODE_CONF_1_DELTA_IBIAS_OFFSET_S )) | ~CCFG_MODE_CONF_1_DELTA_IBIAS_OFFSET_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_1_XOSC_MAX_START << CCFG_MODE_CONF_1_XOSC_MAX_START_S )) | ~CCFG_MODE_CONF_1_XOSC_MAX_START_M ) )
#define DEFAULT_CCFG_SIZE_AND_DIS_FLAGS ( \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_SIZE_OF_CCFG << CCFG_SIZE_AND_DIS_FLAGS_SIZE_OF_CCFG_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_SIZE_OF_CCFG_M ) & \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS << CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_DISABLE_FLAGS_M ) & \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO << CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_DIS_TCXO_M ) & \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM << CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_DIS_GPRAM_M ) & \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING << CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_DIS_ALT_DCDC_SETTING_M ) & \
( ((uint32_t)( SET_CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR << CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR_S )) | ~CCFG_SIZE_AND_DIS_FLAGS_DIS_XOSC_OVR_M ) )
#define DEFAULT_CCFG_MODE_CONF ( \
( ((uint32_t)( SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_DELTA << CCFG_MODE_CONF_VDDR_TRIM_SLEEP_DELTA_S )) | ~CCFG_MODE_CONF_VDDR_TRIM_SLEEP_DELTA_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_DCDC_RECHARGE << CCFG_MODE_CONF_DCDC_RECHARGE_S )) | ~CCFG_MODE_CONF_DCDC_RECHARGE_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_DCDC_ACTIVE << CCFG_MODE_CONF_DCDC_ACTIVE_S )) | ~CCFG_MODE_CONF_DCDC_ACTIVE_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_VDDR_EXT_LOAD << CCFG_MODE_CONF_VDDR_EXT_LOAD_S )) | ~CCFG_MODE_CONF_VDDR_EXT_LOAD_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_VDDS_BOD_LEVEL << CCFG_MODE_CONF_VDDS_BOD_LEVEL_S )) | ~CCFG_MODE_CONF_VDDS_BOD_LEVEL_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_SCLK_LF_OPTION << CCFG_MODE_CONF_SCLK_LF_OPTION_S )) | ~CCFG_MODE_CONF_SCLK_LF_OPTION_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC << CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC_S )) | ~CCFG_MODE_CONF_VDDR_TRIM_SLEEP_TC_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_RTC_COMP << CCFG_MODE_CONF_RTC_COMP_S )) | ~CCFG_MODE_CONF_RTC_COMP_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_XOSC_FREQ << CCFG_MODE_CONF_XOSC_FREQ_S )) | ~CCFG_MODE_CONF_XOSC_FREQ_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_XOSC_CAP_MOD << CCFG_MODE_CONF_XOSC_CAP_MOD_S )) | ~CCFG_MODE_CONF_XOSC_CAP_MOD_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_HF_COMP << CCFG_MODE_CONF_HF_COMP_S )) | ~CCFG_MODE_CONF_HF_COMP_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA << CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA_S )) | ~CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA_M ) & \
( ((uint32_t)( SET_CCFG_MODE_CONF_VDDR_CAP << CCFG_MODE_CONF_VDDR_CAP_S )) | ~CCFG_MODE_CONF_VDDR_CAP_M ) )
#define DEFAULT_CCFG_VOLT_LOAD_0 ( \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP45 << CCFG_VOLT_LOAD_0_VDDR_EXT_TP45_S )) | ~CCFG_VOLT_LOAD_0_VDDR_EXT_TP45_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP25 << CCFG_VOLT_LOAD_0_VDDR_EXT_TP25_S )) | ~CCFG_VOLT_LOAD_0_VDDR_EXT_TP25_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TP5 << CCFG_VOLT_LOAD_0_VDDR_EXT_TP5_S )) | ~CCFG_VOLT_LOAD_0_VDDR_EXT_TP5_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_0_VDDR_EXT_TM15 << CCFG_VOLT_LOAD_0_VDDR_EXT_TM15_S )) | ~CCFG_VOLT_LOAD_0_VDDR_EXT_TM15_M ) )
#define DEFAULT_CCFG_VOLT_LOAD_1 ( \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP125 << CCFG_VOLT_LOAD_1_VDDR_EXT_TP125_S )) | ~CCFG_VOLT_LOAD_1_VDDR_EXT_TP125_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP105 << CCFG_VOLT_LOAD_1_VDDR_EXT_TP105_S )) | ~CCFG_VOLT_LOAD_1_VDDR_EXT_TP105_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP85 << CCFG_VOLT_LOAD_1_VDDR_EXT_TP85_S )) | ~CCFG_VOLT_LOAD_1_VDDR_EXT_TP85_M ) & \
( ((uint32_t)( SET_CCFG_VOLT_LOAD_1_VDDR_EXT_TP65 << CCFG_VOLT_LOAD_1_VDDR_EXT_TP65_S )) | ~CCFG_VOLT_LOAD_1_VDDR_EXT_TP65_M ) )
#define DEFAULT_CCFG_RTC_OFFSET ( \
( ((uint32_t)( SET_CCFG_RTC_OFFSET_RTC_COMP_P0 << CCFG_RTC_OFFSET_RTC_COMP_P0_S )) | ~CCFG_RTC_OFFSET_RTC_COMP_P0_M ) & \
( ((uint32_t)( SET_CCFG_RTC_OFFSET_RTC_COMP_P1 << CCFG_RTC_OFFSET_RTC_COMP_P1_S )) | ~CCFG_RTC_OFFSET_RTC_COMP_P1_M ) & \
( ((uint32_t)( SET_CCFG_RTC_OFFSET_RTC_COMP_P2 << CCFG_RTC_OFFSET_RTC_COMP_P2_S )) | ~CCFG_RTC_OFFSET_RTC_COMP_P2_M ) )
#define DEFAULT_CCFG_FREQ_OFFSET ( \
( ((uint32_t)( SET_CCFG_FREQ_OFFSET_HF_COMP_P0 << CCFG_FREQ_OFFSET_HF_COMP_P0_S )) | ~CCFG_FREQ_OFFSET_HF_COMP_P0_M ) & \
( ((uint32_t)( SET_CCFG_FREQ_OFFSET_HF_COMP_P1 << CCFG_FREQ_OFFSET_HF_COMP_P1_S )) | ~CCFG_FREQ_OFFSET_HF_COMP_P1_M ) & \
( ((uint32_t)( SET_CCFG_FREQ_OFFSET_HF_COMP_P2 << CCFG_FREQ_OFFSET_HF_COMP_P2_S )) | ~CCFG_FREQ_OFFSET_HF_COMP_P2_M ) )
#define DEFAULT_CCFG_IEEE_MAC_0 SET_CCFG_IEEE_MAC_0
#define DEFAULT_CCFG_IEEE_MAC_1 SET_CCFG_IEEE_MAC_1
#define DEFAULT_CCFG_IEEE_BLE_0 SET_CCFG_IEEE_BLE_0
#define DEFAULT_CCFG_IEEE_BLE_1 SET_CCFG_IEEE_BLE_1
#define DEFAULT_CCFG_BL_CONFIG ( \
( ((uint32_t)( SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE << CCFG_BL_CONFIG_BOOTLOADER_ENABLE_S )) | ~CCFG_BL_CONFIG_BOOTLOADER_ENABLE_M ) & \
( ((uint32_t)( SET_CCFG_BL_CONFIG_BL_LEVEL << CCFG_BL_CONFIG_BL_LEVEL_S )) | ~CCFG_BL_CONFIG_BL_LEVEL_M ) & \
( ((uint32_t)( SET_CCFG_BL_CONFIG_BL_PIN_NUMBER << CCFG_BL_CONFIG_BL_PIN_NUMBER_S )) | ~CCFG_BL_CONFIG_BL_PIN_NUMBER_M ) & \
( ((uint32_t)( SET_CCFG_BL_CONFIG_BL_ENABLE << CCFG_BL_CONFIG_BL_ENABLE_S )) | ~CCFG_BL_CONFIG_BL_ENABLE_M ) )
#define DEFAULT_CCFG_ERASE_CONF ( \
( ((uint32_t)( SET_CCFG_ERASE_CONF_CHIP_ERASE_DIS_N << CCFG_ERASE_CONF_CHIP_ERASE_DIS_N_S )) | ~CCFG_ERASE_CONF_CHIP_ERASE_DIS_N_M ) & \
( ((uint32_t)( SET_CCFG_ERASE_CONF_BANK_ERASE_DIS_N << CCFG_ERASE_CONF_BANK_ERASE_DIS_N_S )) | ~CCFG_ERASE_CONF_BANK_ERASE_DIS_N_M ) )
#define DEFAULT_CCFG_CCFG_TI_OPTIONS ( \
( ((uint32_t)( SET_CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE << CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE_S )) | ~CCFG_CCFG_TI_OPTIONS_TI_FA_ENABLE_M ) )
#define DEFAULT_CCFG_CCFG_TAP_DAP_0 ( \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE << CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_0_CPU_DAP_ENABLE_M ) & \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE << CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_0_PRCM_TAP_ENABLE_M ) & \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE << CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_0_TEST_TAP_ENABLE_M ) )
#define DEFAULT_CCFG_CCFG_TAP_DAP_1 ( \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE << CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_1_PBIST2_TAP_ENABLE_M ) & \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE << CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_1_PBIST1_TAP_ENABLE_M ) & \
( ((uint32_t)( SET_CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE << CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE_S )) | ~CCFG_CCFG_TAP_DAP_1_WUC_TAP_ENABLE_M ) )
#define DEFAULT_CCFG_IMAGE_VALID_CONF ( \
( ((uint32_t)( SET_CCFG_IMAGE_VALID_CONF_IMAGE_VALID << CCFG_IMAGE_VALID_CONF_IMAGE_VALID_S )) | ~CCFG_IMAGE_VALID_CONF_IMAGE_VALID_M ) )
#define DEFAULT_CCFG_CCFG_PROT_31_0 SET_CCFG_CCFG_PROT_31_0
#define DEFAULT_CCFG_CCFG_PROT_63_32 SET_CCFG_CCFG_PROT_63_32
#define DEFAULT_CCFG_CCFG_PROT_95_64 SET_CCFG_CCFG_PROT_95_64
#define DEFAULT_CCFG_CCFG_PROT_127_96 SET_CCFG_CCFG_PROT_127_96
// Customer Configuration Area in Lock Page
#if defined(__IAR_SYSTEMS_ICC__)
__root const ccfg_t __ccfg @ ".ccfg" =
#elif defined(__TI_COMPILER_VERSION__)
#pragma DATA_SECTION(__ccfg, ".ccfg")
#pragma RETAIN(__ccfg)
const ccfg_t __ccfg =
#else
const ccfg_t __ccfg __attribute__((section(".ccfg"))) __attribute__((used)) =
#endif
{ // Mapped to address
DEFAULT_CCFG_EXT_LF_CLK , // 0x50003FA8 (0x50003xxx maps to last
DEFAULT_CCFG_MODE_CONF_1 , // 0x50003FAC sector in FLASH.
DEFAULT_CCFG_SIZE_AND_DIS_FLAGS , // 0x50003FB0 Independent of FLASH size)
DEFAULT_CCFG_MODE_CONF , // 0x50003FB4
DEFAULT_CCFG_VOLT_LOAD_0 , // 0x50003FB8
DEFAULT_CCFG_VOLT_LOAD_1 , // 0x50003FBC
DEFAULT_CCFG_RTC_OFFSET , // 0x50003FC0
DEFAULT_CCFG_FREQ_OFFSET , // 0x50003FC4
DEFAULT_CCFG_IEEE_MAC_0 , // 0x50003FC8
DEFAULT_CCFG_IEEE_MAC_1 , // 0x50003FCC
DEFAULT_CCFG_IEEE_BLE_0 , // 0x50003FD0
DEFAULT_CCFG_IEEE_BLE_1 , // 0x50003FD4
DEFAULT_CCFG_BL_CONFIG , // 0x50003FD8
DEFAULT_CCFG_ERASE_CONF , // 0x50003FDC
DEFAULT_CCFG_CCFG_TI_OPTIONS , // 0x50003FE0
DEFAULT_CCFG_CCFG_TAP_DAP_0 , // 0x50003FE4
DEFAULT_CCFG_CCFG_TAP_DAP_1 , // 0x50003FE8
DEFAULT_CCFG_IMAGE_VALID_CONF , // 0x50003FEC
DEFAULT_CCFG_CCFG_PROT_31_0 , // 0x50003FF0
DEFAULT_CCFG_CCFG_PROT_63_32 , // 0x50003FF4
DEFAULT_CCFG_CCFG_PROT_95_64 , // 0x50003FF8
DEFAULT_CCFG_CCFG_PROT_127_96 , // 0x50003FFC
#endif // __CCFC_C__
有些宏定义不知道什么意思啊
