在《TI BLE5-Stack User’s Guide》里的“GAP Constraints”章节里有说到:
The data length of the advertising data and the scan response data for Extended Advertising is limited to 1650 bytes. The connectable undirected advertising data is limited to 212 bytes. The connectable directed advertising data is limited to 206 bytes.
该怎么把 adv data 或 scan rsp data 扩展到 31 byte 以上?目前我好像只能使用 31 byte 的长度。
