AOA函数
RTLSMaster_enableAoaReq();这个函数是对slave发送CTE数据包请求命令吗,slave接到cte包后,马上向master发送CTE数据,以来获得I/Q信号值来计算角度吗
  • 是的,具体怎么发送根据设置的参数
    typedef struct __attribute__((packed))
    uint16_t connHandle; // Connection handle
    uint8_t enableAoa; // Enable or disable AoA
    uint16_t cteInterval; // 0 = run once, > 0 = sample CTE every cteInterval until told otherwise
    uint8_t cteLength; // Length of the tone (2 - 20), used for AoA receiver
    } rtlsAoaEnableReq_t;
