求分享ti/drivers/watchdog/WatchdogCC26XX.h和WatchdogCC26XX.c文件。非常感谢
Other Parts Discussed in Thread: CC2630
  • 查看附件
     * Copyright (c) 2015-2017, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include <stdint.h>
    #include <stdlib.h>
    #include <ti/drivers/dpl/DebugP.h>
    #include <ti/drivers/dpl/HwiP.h>
    #include <ti/drivers/Power.h>
    #include <ti/drivers/power/PowerCC26XX.h>
    #include <ti/drivers/watchdog/WatchdogCC26XX.h>
    #include <ti/devices/DeviceFamily.h>
    #include DeviceFamily_constructPath(driverlib/watchdog.h)
    /* Function prototypes */
    void WatchdogCC26XX_clear(Watchdog_Handle handle);
    void WatchdogCC26XX_close(Watchdog_Handle handle);
    int_fast16_t  WatchdogCC26XX_control(Watchdog_Handle handle, uint_fast16_t cmd,
            void *arg);
    void WatchdogCC26XX_init(Watchdog_Handle handle);
    Watchdog_Handle WatchdogCC26XX_open(Watchdog_Handle handle, Watchdog_Params *params);
    int_fast16_t WatchdogCC26XX_setReload(Watchdog_Handle handle,
            uint32_t ticks);
    uint32_t WatchdogCC26XX_convertMsToTicks(Watchdog_Handle handle,
        uint32_t milliseconds);
    /* WatchdogCC26XX internal functions */
    static void WatchdogCC26XX_initHw(Watchdog_Handle handle);
    /* Watchdog function table for CC26XX implementation */
    const Watchdog_FxnTable WatchdogCC26XX_fxnTable = {
        WatchdogCC26XX_clear,
        WatchdogCC26XX_close,
        WatchdogCC26XX_control,
        WatchdogCC26XX_init,
        WatchdogCC26XX_open,
        WatchdogCC26XX_setReload,
    /* Maximum allowable setReload value */
    #define MAX_RELOAD_VALUE        0xFFFFFFFF
    #define WATCHDOG_DIV_RATIO      32            /* Watchdog division ratio */
    #define MS_RATIO                1000          /* millisecond to second ratio */
     *  ======== WatchdogCC26XX_clear ========
        WatchdogIntClear();
     *  ======== WatchdogCC26XX_close ========
         *  Not supported for CC26XX - Once the INTEN bit of the WDTCTL
         *  register has been set, it can only be cleared by a hardware
         *  reset.
        DebugP_assert(false);
     *  ======== WatchdogCC26XX_control ========
     *  @pre    Function assumes that the handle is not NULL
            void *arg)
        /* No implementation yet */
        return (Watchdog_STATUS_UNDEFINEDCMD);
     *  ======== Watchdog_init ========
        WatchdogCC26XX_Object *object = handle->object;
        object->isOpen = false;
     *  ======== WatchdogCC26XX_open ========
        unsigned int                   key;
        HwiP_Params                     hwiParams;
        WatchdogCC26XX_Object         *object;
        /* get the pointer to the object and hwAttrs */
        /* disable preemption while checking if the WatchDog is open. */
        key = HwiP_disable();
        /* Check if the Watchdog is open already with the HWAttrs */
        if (object->isOpen == true) {
            HwiP_restore(key);
            DebugP_log1("Watchdog: Handle %x already in use.", (uintptr_t)handle);
            return (NULL);
        object->isOpen = true;
        HwiP_restore(key);
        /* initialize the Watchdog object */
        object->debugStallMode = params->debugStallMode;
        object->resetMode      = params->resetMode;
        /* Construct Hwi object for Watchdog */
        HwiP_Params_init(&hwiParams);
        hwiParams.arg = (uintptr_t)handle;
        /* setup callback function if defined */
        if (params->callbackFxn != NULL) {
            HwiP_plug(INT_NMI_FAULT, (void *)params->callbackFxn);
        /* initialize the watchdog hardware */
        WatchdogCC26XX_initHw(handle);
        DebugP_log1("Watchdog: handle %x opened" ,(uintptr_t)handle);
        /* return handle of the Watchdog object */
        return (handle);
     *  ======== WatchdogCC26XX_setReload ========
    int_fast16_t WatchdogCC26XX_setReload(Watchdog_Handle handle, uint32_t ticks)
        unsigned int                   key;
        /* disable preemption while unlocking WatchDog registers */
        /* unlock the Watchdog configuration registers */
        WatchdogUnlock();
        /* make sure the Watchdog is unlocked before continuing */
        while(WatchdogLockState() == WATCHDOG_LOCK_LOCKED)
        /* update the reload value */
        WatchdogReloadSet(ticks);
        /* lock register access */
        WatchdogLock();
        HwiP_restore(key);
        DebugP_log2("Watchdog: WDT with handle 0x%x has been set to "
            "reload to 0x%x", (uintptr_t)handle, ticks);
        return (Watchdog_STATUS_SUCCESS);
     *  ======== WatchdogCC26XX_hwInit ========
     *  This function initializes the Watchdog hardware module.
     *  @pre    Function assumes that the Watchdog handle is pointing to a hardware
     *          module which has already been opened.
    static void WatchdogCC26XX_initHw(Watchdog_Handle handle) {
        unsigned int                   key;
        uint32_t                       tickValue;
        WatchdogCC26XX_HWAttrs const   *hwAttrs;
        hwAttrs = handle->hwAttrs;
        /* convert milliseconds to watchdog timer ticks */
        tickValue = WatchdogCC26XX_convertMsToTicks(handle, hwAttrs->reloadValue);
        WatchdogUnlock();
        WatchdogReloadSet(tickValue);
        /* set reset mode */
        if (object->resetMode == Watchdog_RESET_ON) {
            WatchdogResetEnable();
        else {
            WatchdogResetDisable();
        /* set debug stall mode */
        if (object->debugStallMode == Watchdog_DEBUG_STALL_ON) {
            WatchdogStallEnable();
        else {
            WatchdogStallDisable();
        /* enable the Watchdog interrupt as a non-maskable interrupt */
        WatchdogIntTypeSet(WATCHDOG_INT_TYPE_NMI);
        /* enable the Watchdog */
        WatchdogEnable();
        /* lock the Watchdog configuration registers */
        WatchdogLock();
        HwiP_restore(key);
     *  ======== WatchdogCC26XX_convertMsToTicks ========
     *  This function converts the input value from milliseconds to
     *  Watchdog clock ticks.
        uint32_t                       tickValue;
        uint32_t                       convertRatio;
        uint32_t                       maxConvertMs;
        ClockP_FreqHz                   freq;
        /* Determine milliseconds to clock ticks conversion ratio */
        /* Watchdog clock ticks/sec = CPU clock / WATCHDOG_DIV_RATIO */
        /* Watchdog clock ticks/ms = CPU clock / WATCHDOG_DIV_RATIO / 1000 */
        ClockP_getCpuFreq(&freq);
        convertRatio = freq.lo / WATCHDOG_DIV_RATIO / MS_RATIO;
        maxConvertMs = MAX_RELOAD_VALUE / convertRatio;
        /* check if value exceeds maximum */
        if (milliseconds > maxConvertMs) {
            tickValue = 0;  /* return zero to indicate overflow */
        else {
            tickValue = (uint32_t)(milliseconds * convertRatio);
        return(tickValue);
    WatchdogCC26XX.h
  • Thank you very much!!!谢谢大佬
  • 请问使用CC2630看门狗,实现代码以及相关配置操作和驱动,可以分享一下吗?我参考的这个例程,为什么执行到打开Watchdog_open(0, &params);会停止往下执行。
    Iwant use the CC2630 watchdog, implementation code and related configuration operations and drivers, can you share? I referenced following link, why the execution of Watchdog_open(0, &params) will stop execution.
    e2echina.ti.com/.../186035
  • CC2630看门狗的资料比较少,参考下这里:
     * are met:
     *  ======== Watchdog.c ========
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdlib.h>
    #include <ti/drivers/Watchdog.h>
    extern const Watchdog_Config Watchdog_config[];
    extern const uint_least8_t Watchdog_count;
    /* Default Watchdog parameters structure */
    const Watchdog_Params Watchdog_defaultParams = {
        NULL,                    /* callbackFxn */
        Watchdog_RESET_ON,       /* resetMode */
        Watchdog_DEBUG_STALL_ON, /* debugStallMode */
        NULL                     /* custom */
    static bool isInitialized = false;
     *  ======== Watchdog_clear ========
    void Watchdog_clear(Watchdog_Handle handle)
        handle->fxnTablePtr->watchdogClear(handle);
     *  ======== Watchdog_close ========
    void Watchdog_close(Watchdog_Handle handle)
        handle->fxnTablePtr->watchdogClose(handle);
     *  ======== Watchdog_control ========
    int_fast16_t Watchdog_control(Watchdog_Handle handle, uint_fast16_t cmd,
                                  void *arg)
        return (handle->fxnTablePtr->watchdogControl(handle, cmd, arg));
    void Watchdog_init(void)
        uint_least8_t i;
        uint_fast32_t key;
        if (!isInitialized) {
            isInitialized = (bool) true;
            /* Call each driver's init function */
            for (i = 0; i < Watchdog_count; i++) {
                Watchdog_config[i].fxnTablePtr->watchdogInit((Watchdog_Handle)&(Watchdog_config[i]));
        HwiP_restore(key);
     *  ======== Watchdog_open ========
    Watchdog_Handle Watchdog_open(uint_least8_t index, Watchdog_Params *params)
        Watchdog_Handle handle = NULL;
        /* Verify driver index and state */
        if (isInitialized && (index < Watchdog_count)) {
            /* If params are NULL use defaults */
            if (params == NULL) {
                params = (Watchdog_Params *) &Watchdog_defaultParams;
            handle = (Watchdog_Handle)&(Watchdog_config[index]);
            handle = handle->fxnTablePtr->watchdogOpen(handle, params);
        return (handle);
     *  ======== Watchdog_Params_init ========
    void Watchdog_Params_init(Watchdog_Params *params)
        *params = Watchdog_defaultParams;
     *  ======== Watchdog_setReload ========
    int_fast16_t Watchdog_setReload(Watchdog_Handle handle, uint32_t ticks)
        return (handle->fxnTablePtr->watchdogSetReload(handle, ticks));
     *  ======== Watchdog_convertMsToTicks ========
    uint32_t Watchdog_convertMsToTicks(Watchdog_Handle handle, uint32_t milliseconds)
        return (handle->fxnTablePtr->watchdogConvertMsToTicks(handle, milliseconds));
    Watchdog.h
