Other Parts Discussed in Thread: CC2640R2F
Dear All
我用SDK simplelink_cc2640r2_sdk_4_20_00_04的Simple_Peripheral的工程,CC2640R2F烧录进去后可以用蓝牙助手连接,后自己修改了程序烧录进去连接不上,之后再重新把公版demo的固件烧录进去一样连接不上了,请教一下这是什么问题?
Dear All
Hi Kevin Qiu1
这是烧录cc2640r2lp_project_zero固件的打印信息
#000114 [ 135.104 ] [32;1mINFO:
[30;1m(project_zero.c:1085) [0mDevice Disconnected!
#000115 [ 135.105 ] [32;1mINFO: [30;1m(project_zero.c:1086) [0mNum Conns: 0
#000116 [ 135.105 ] [32
;1mINFO: [30;1m(project_zero.c:1099) [0mRestart Advertising, 1 possible connection remain
#00
0117 [ 135.115 ] [32;1mINFO: [30;1m(project_zero.c:1217) [0mAdv Set 0 Enabled
#000118 [ 136.159 ] [32;1mINFO:
[30;1m(project_zero.c:1222) [0mAdv Set 0 Disabled
#000119 [ 136.159 ] [32;1mINFO: [30;1m(project_zero.c:1242) [0mAdv Set 0 disabled after conn 0
#000120 [ 136.159 ] [32;1mINFO: [30;1
m(project_zero.c:1051) [0mLink establish event, status 0x00. Num Conns: 1
#000121 [ 136.159 ]
[32;1mINFO: [30;1m(project_zero.c:1064) [0mConnected. Peer address: [32m63:BB:54:C4:C2:CC[0
m
#000122 [ 136.160 ] [32;1mINFO: [30;1m(project_zero.c:1075) [0mMax Number of Connection reach: 1, Adv. will not be enable again
#000123 [ 136.363 ] [32;1mINFO:
#000124 [ 136.363 ] [32;1mINFO: [30;1m(project_zero.c:1086) [0mNum Conns: 0
#000125 [ 136.364 ] [32;1mINFO: [30;1m(project_zero.c:
#000126 [ 136.375 ] [32;1mINFO: [
这是烧录cc2640r2lp_simple_peripheral固件的打印信息
c[2J[10r[11;1H7[10r[8;0H
[2KE87[10r[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE
87[10r[3;0H[2KE[2KE87[10r[5;1H[2K===================
=87[10r[6;1H[2KInitialized8
7[10r[11;1H[2KDev Addr: 0x5893D851E61D8
7[10r[9;1H[2KAdv Set 0 Enabled8
7[10r[9;1H[2KAdv Set 1 Enabled8
7[10r[9;1H[2KAdv Set 0 Disab
led87[10r[9;1H[2KAdv Set 0 disabled after conn 087[10r[7;1H[2KNum Conns: 187[10r[6;1H[2KConnected to 0x6EA532630D
BB87[10r[8;0H[2KE87[10r[1;1H[2K*Simple Peripheral87
[10r[2;0H[2KE87[10r[3;2H[2K+Work with >87[10r[4;0H[2KE8
7[10r[6;1H[2KDevice Disconne
cted!87[10r[7;1H[2KNum Conns: 087[10r[8;0H[2KE87[10r[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE87[10r[3;
0H[2KE[2KE87[10r[8;0H[2KE8
led87[10r[9;1H[2KAdv Set 0 disabled after conn 087[10r[7;1H[2KNum Conns: 187[10r[6;1H[2KConnected to 0x6EA532630DBB87[10r[8;0H[2KE87[10r
[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE87[10r[3;2H[2K+Work with >87[10r[4;0H
[2KE8
cted!87[10r[7;1H[2KNum Conns: 087[10r[8;0H[2KE87[10r[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE87[10r[3;0H[2KE[2KE87[10r[8;0H[2KE8
7;1H[2KNum Conns: 187[10r[6;1H[2KConnected to 0x6EA532630DBB87[10r[8;0H[2KE87[10r[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE87[10r[3;2H[2K+Work with >87[10r[4;0H[2KE8
led87[10r[9;1H[2KAdv Set 0 disabled after conn 087[10r[7;1H[2KNum Conns: 187[10r[6;1H[2KConnected to 0x6EA532630DBB87[10r[8;0H[2KE87[10r[1;1H[2K*Simple Peripheral87[10r[2;0H[2KE87[10r[3;2H[2K+Work with >87[10r[4;0H[2KE8
ed8
KE8
请帮忙分析一下
