Other Parts Discussed in Thread: OPT3001, SYSBIOS
void OPT3001CallbackFxn(PIN_Handle handle, PIN_Id pinId) {
switch (pinId) {
case OPT3001_INT:
PIN_setConfig(OPT3001_INT_PinHandle, PIN_BM_IRQ, OPT3001_INT | PIN_IRQ_DIS);
PIN_clrPendInterrupt(handle,pinId);
if(g_DoorStatus == DOOR_OPEN){
g_DoorStatus == DOOR_CLOSE;
Set_OPT3001_High_Limit( cfg_para_opt3001.lignt_limit_ths );
}else{
g_DoorStatus == DOOR_OPEN;
Set_OPT3001_Low_Limit( cfg_para_opt3001.lignt_limit_ths );
break;
