自制CC2652R1F 板,烧录不带蓝牙的实例正常,烧录ble5stack实例程序不能启动主板
自制CC2652R1F板:参照CC2652R1F LaunchPad官方的开发板原理图及PCB Layout设计,制作的主板
例程SDK: simplelink_cc13x2_26x2_sdk_4_30_00_54
使用例程:
1、simplelink_cc13x2_26x2_sdk_4_30_00_54\examples\rtos\CC26X2R1_LAUNCHXL\drivers\timerled
2、D:\ti\ccs1010\simplelink_cc13x2_26x2_sdk_4_30_00_54\examples\rtos\CC26X2R1_LAUNCHXL\ble5stack\simple_peripheral
问题描述:
               烧录例程1,板子可以正常运行,烧录例程2板子运行BIOS_start();时报错,错误信息log请参考附件
Cortex_M4_0: GEL Output: Memory Map Initialization Complete.
Cortex_M4_0: GEL Output: Board Reset Complete.
Cortex_M4_0: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.2.0.00002)
Cortex_M4_0: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.2.0.00002)
Cortex_M4_0: Unable to determine target status after 20 attempts
Cortex_M4_0: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
