Part Number: LAUNCHXL-CC26X2R1
使用CCS V8 导入SDK4.2中的rtls_slave_CC26X2R1_LAUNCHXL_tirtos_ccs,编译报错如下,这是什么问题?
subdir_rules.mk:12: recipe for target 'build-2016580671-inproc' failed
Error: Unsupported configurable def
at Object.createConfigurableMgr (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\configurable.js:255:19)
at ModuleInstanceMgr.addConfigMembers._.map (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:29:80)
at arrayMap (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\lodash\lodash.js:660:23)
at Function.map (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\lodash\lodash.js:9571:14)
at new ModuleInstanceMgr (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:29:37)
at new StaticModuleInstanceMgr (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\staticModuleInstance.js:6:13)
at Function.create (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\staticModuleInstance.js:19:26)
at ModuleMgr.initStatic (C:\ti\ccsv8\utils\sysconfig\pinmux\services\instanceContainers\module.js:116:64)
at _.each (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:460:47)
at arrayEach (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\lodash\lodash.js:537:11)
at Function.forEach (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\lodash\lodash.js:9359:14)
at ModuleRequirements.resolve (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:446:15)
at ModuleRequirements.newRequirements (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:372:18)
at ModuleInstanceMgr.resolveRequirements (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:328:33)
at ModuleInstanceMgr.init (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:262:18)
at new ModuleInstanceMgr (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\moduleInstance.js:50:22)
at ModuleMgr.addInstance (C:\ti\ccsv8\utils\sysconfig\pinmux\services\instanceContainers\module.js:87:28)
at StaticModuleInstanceMgr.addFixedMember.scriptingGuard_1.guardScriptingFunction (C:\ti\ccsv8\utils\sysconfig\pinmux\services\objectManagers\staticModuleInstance.js:16:109)
at disableScriptingForCallback (C:\ti\ccsv8\utils\sysconfig\pinmux\services\scripting\scriptingGuard.js:31:54)
at disableScriptingForCallback (C:\ti\ccsv8\utils\sysconfig\pinmux\services\scripting\scriptingGuard.js:19:20)
at Proxy.args (C:\ti\ccsv8\utils\sysconfig\pinmux\services\scripting\scriptingGuard.js:31:20)
at C:\Users\13413\workspace_v8\rtls_slave_CC26X2R1_LAUNCHXL_tirtos_ccs\rtls_slave.syscfg:44:21
at configParmsPromise.then.then (C:\ti\ccsv8\utils\sysconfig\pinmux\services\scripting\runScript.js:35:25)
at _fulfilled (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:834:54)
at self.promiseDispatch.done (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:863:30)
at Promise.promise.promiseDispatch (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:796:13)
at C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:604:44
at runSingle (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:137:13)
at flush (C:\ti\ccsv8\utils\sysconfig\cli\node_modules\q\q.js:125:13)
at _combinedTickCallback (internal/process/next_tick.js:131:7)
at process._tickCallback (internal/process/next_tick.js:180:9)
gmake[1]: *** [build-2016580671-inproc] Error 1
gmake: *** [build-2016580671] Error 2
subdir_rules.mk:9: recipe for target 'build-2016580671' failed
gmake: Target 'all' not remade because of errors.
