Part Number: CC2640R2F
Other Parts Discussed in Thread: CC2642R
"C:/ti/simplelink_cc2640r2_sdk_5_10_00_02/source/ti/ble5stack/common/cc26xx/ccs/cc26xx_app.cmd", line 277: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section ".cinit" size 0x1053. Available memory ranges:
FLASH size: 0x1f000 unused: 0x1267 max hole: 0x1000
FLASH_LAST_PAGE size: 0x1000 unused: 0xfa8 max hole: 0xfa8
请问大佬这是什么意思?应该怎么修改?谢谢~
