Other Parts Discussed in Thread: CC1312R, CC2652R7, CC1352R, CC1352P, CC2652P, CC2652R
下面提供了利用 CC2642R 的 DSP 功能运行 FFT 的指南。
注意:该指南同样适用于所有具有 Cortex M4F 的 CC13xx 和 CC26xx 器件,其中包括 CC1312R、CC1352R、CC1352P、CC1352R7、CC2642R、CC2652R、CC2652P、CC2652R7 等
- 下载 CMSIS-DSP 库文件https://github.com/ARM-software/CMSIS_5/blob/5.7.0/CMSIS/DSP/Lib/ARM/arm_cortexM4lf_math.lib
- 将该文件存储在 <SDK>\source\third_party\cmsis\lib 中
- 重命名文件lib
- 下载 https://github.com/ARM-software/CMSIS_5/tree/5.7.0/CMSIS/DSP/Include 中存储的头文件
a. 如果需要这里是我的 <SDK>\source\third_party\cmsis 文件夹cmsis.zip 的内容
- 将它们存储在 <SDK>\source\third_party\cmsis\include 中
- 打开 CCS,导入空示例
- 添加库:“Project”>“Properties”>“Build”>“Arm Linker”>“File Search Path”。添加 third_party/cmsis/lib/math.lib
- 在工程中新建一个名为 CMSIS 的文件夹,用于存储 CMSIS 库的头文件
- 将 <SDK>\source\third_party\cmsis\include 中存储的文件复制到此新文件夹中
- 将此文件夹添加到搜索路径:“Project”>“Properties”>“Build”>“Arm Compiler”>“Include Options”
我已使用 SDK 中提供的“empty”示例 (<SDK>\examples\rtos\<DEVICE>\drivers\empty) 对此进行了测试,并在其中添加了随库提供的示例。
以下是我的 empty.c 文件的修改内容:
/* * Copyright (c) 2015-2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED.IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== empty.c ======== */ /* For usleep() */ #include <unistd.h> #include <stdint.h> #include <stddef.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> // #include <ti/drivers/I2C.h> // #include <ti/drivers/SPI.h> // #include <ti/drivers/UART.h> // #include <ti/drivers/Watchdog.h> /* Driver configuration */ #include "ti_drivers_config.h" #include "arm_math.h" #include "arm_const_structs.h" #define TEST_LENGTH_SAMPLES 4096 /* ------------------------------------------------------------------- * This is a fix for undefined __hardfp_sqrtf and __hardfp_sqrt symbols * ------------------------------------------------------------------- */ int __hardfp_sqrt(int f){ return sqrt(f); } float32_t __hardfp_sqrtf(float32_t f){ return sqrt(f); } /* ------------------------------------------------------------------- * External Input and Output buffer Declarations for FFT Bin Example * ------------------------------------------------------------------- */ extern float32_t testInput_f32_10khz[TEST_LENGTH_SAMPLES]; static float32_t testOutput[TEST_LENGTH_SAMPLES/2]; /* ------------------------------------------------------------------ * Global variables for FFT Bin Example * ------------------------------------------------------------------- */ uint32_t fftSize = 2048; uint32_t ifftFlag = 0; uint32_t doBitReverse = 1; arm_cfft_instance_f32 varInstCfftF32; /* Reference index at which max energy of bin occurs */ uint32_t refIndex = 213, testIndex = 0; /* ---------------------------------------------------------------------- * Max magnitude FFT Bin test * ------------------------------------------------------------------- */ void MaxMagnitudeFFTBinTest(void) { arm_status status; float32_t maxValue; status = ARM_MATH_SUCCESS; status=arm_cfft_init_f32(&varInstCfftF32,fftSize); /* Process the data through the CFFT/CIFFT module */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_OFF); arm_cfft_f32(&varInstCfftF32, testInput_f32_10khz, ifftFlag, doBitReverse); // 2.587ms for 1024 points | 5.820ms for 2048 (280'411 clock cycles) GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_ON); /* Process the data through the Complex Magnitude Module for calculating the magnitude at each bin */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_OFF); arm_cmplx_mag_f32(testInput_f32_10khz, testOutput, fftSize); //22.020ms for 1024 points | 44.01 ms for 2048 points (2'128'459 clock cycles) GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_ON); /* Calculates maxValue and returns corresponding BIN value */ arm_max_f32(testOutput, fftSize, &maxValue, &testIndex); status = (testIndex != refIndex) ? ARM_MATH_TEST_FAILURE : ARM_MATH_SUCCESS; if (status != ARM_MATH_SUCCESS) { while (1); // something went wrong } else { // everything is working } } /* * ======== mainThread ======== */ void *mainThread(void *arg0) { /* Call driver init functions */ GPIO_init(); // I2C_init(); // SPI_init(); // UART_init(); // Watchdog_init(); /* Configure the LED pin */ GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW); GPIO_setConfig(CONFIG_GPIO_LED_1, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW); /* Turn on user LED */ MaxMagnitudeFFTBinTest(); // 24.77ms while (1) { } }
