CCS How to find source file.
CCS导入项目后如何看到源文件?
这个具体的定义在哪里
for instance, Where is the definition of the LL_Init
请参阅以下答复:
CCS has a backed in feature allowing to reach the declaration of the symbols. To use it, right click on the symbol > Open Declaration - you could also press F3. Please note other powerful search function are also available.
When it comes to the LL_init() function, we do not deliver the sources of this function within the stack (i.e. this symbol is in the library files). As a consequence you will not manage to find the definition of the symbol as indicated previously.
希望对您有所帮助。
