蓝牙4.0增加绑定信息这个函数的参数都代表什么意思?
Other Parts Discussed in Thread: BLE-STACK
特别是uint32 signCounter这个参数,还有程序里面有个gapBondCharCfg_t charCfg[GAP_CHAR_CFG_MAX];最下面有个设置charCfg = 0xFF,这参数又代表什么意思?谢谢!
这些对于我们有什么用处吗?谢谢!
代码如下: static uint8 gapBondMgrAddBond( gapBondRec_t *pBondRec, gapBondLTK_t *pLocalLTK, gapBondLTK_t *pDevLTK, uint8 *pIRK, uint8 *pSRK, uint32 signCounter )
      // If available, save the connected device's Signature information
     if ( pSRK )
          VOID osal_snv_write( devCSRKNvID(idx), KEYLEN, pSRK );
          VOID osal_snv_write( devSignCounterNvID(idx), sizeof ( uint32 ), &signCounter ); }
         // Write out FF's over the charactersitic configuration entry, to overwrite
         // any previous bond data that may have been stored
         VOID osal_memset( charCfg, 0xFF, sizeof ( charCfg ) );
         VOID osal_snv_write( gattCfgNvID(idx), sizeof ( charCfg ), charCfg );
