希望能解答的稍微具体一点,不要只是回答能和不能,如果能,我改怎么做哪个定时的任务,如果不能,有没有其它的方案,还是只能主机自动断开,或者连接超时自动断开
zhaowei,
please refer to http://www.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=swra347a.
there are detailed datas. and there is a table, you can calculate your battery life.
just curious, why you want to disconnect. you only have 1S interval.
BR. Albin
