CC2541 的GATT_Notification
在SerialApp这个例程中,里面封装了一个函数
 * Send GATT Notification
 * - Called from timer
 * - Try send 4 packets
 * - On fail set flag to not deQueue until sent successfully
void sappSendNotification()
    uint8 i = 0;
    static attHandleValueNoti_t *pReport= NULL;
    static uint16 counterOut=0;
    if ( pReport == NULL)
       pReport = packetDequeue();
       if ( pReport == NULL )
         return;
    //try 3 packets per connection event
    for ( i = 0; i<3 ; i++)
      if ( GATT_Notification( 0, pReport, FALSE )==SUCCESS)
        //counterOut++;
        LCD_WRITE_STRING_VALUE( "DOUT ", ++counterOut, 10,2 );
        //get next
          i=3;
      else
        pReport = NULL;
        i=3;
请问GATT_Notification()这个函数用来发送数据,数据还是存放在Characteristic里面么?
请问在Android上如何访问这些数据呢?
