Other Parts Discussed in Thread: CC2510, CC2540
在cc2541上存储图片,如果是存在ram区域,显示正常,加了关键字CODE后存在了flash区,显示不正常,是什么原因,需要怎样配置才可以?
同样的代码,用CC2510就没有问题。
const unsigned char CODE gImage_njzy[12500] = {
0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0X7F,0XFF,0XFF,0XFF,0XFF,
添加了关键字“CODE”,貌似没有存进flash里面去
已将您的问题升级到E2E英文论坛,一旦得到回复会立刻回复给您
您能否具体说明 CODE 宏定义的内容?我不确定此关键字的作用。这是您实施的自定义宏吗?
我很高兴听到问题已解决。我建议彻底测试以确保解决方案稳定并适用于不同的数据字符串。感谢您与E2E中文论坛分享您的解决方案!
