CC2560 例程在v6.1 IAR上报错
Other Parts Discussed in Thread: MSP430F5438A
我下的是CC256x MSP430 Bluetopia SDK V1.4 R1在V5.5的IAR上可以正常编译,但是在v6.1上  项目软件变为新版本后,编译就报错
报错信息如下:
Updating build tree...
BTPSKRNL.c
BTPSVEND.c
BTVS.c
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 167
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 429
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 643
Warning[Pe186]: pointless comparison of unsigned integer with zero C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Bluetopia\btvs\BTVS.c 729
HAL.c
HCITRANS.c
low_level_init.c
Main.c
SPPDemo.c
sprintf.c
Linking
Error[e46]: Undefined external "HCI_Send_Raw_Command" referred in BTVS ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Exp\Obj\BTVS.r43 )
Error[e46]: Undefined external "HCI_Reconfigure_Driver" referred in BTVS ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\BTVS.r43 )
Error[e46]: Undefined external "BSC_QueryStackIdle" referred in Main ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\Obj\
Main.r43 )
Error[e46]: Undefined external "BSC_Initialize" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\Obj\
SPPDemo.r43 )
Error[e46]: Undefined external "HCI_Version_Supported" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Exp\Obj\SPPDemo.r43 )
Error[e46]: Undefined external "GAP_Query_Local_BD_ADDR" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
MSP430F5438A Exp\Obj\SPPDemo.r43 )
Error[e46]: Undefined external "L2CA_Set_Link_Connection_Configuration" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug
- MSP430F5438A Exp\Obj\SPPDemo.r43 )
Error[e46]: Undefined external "HCI_Command_Supported" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "HCI_Write_Default_Link_Policy_Settings" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "BSC_Shutdown" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\Obj\
SPPDemo.r43 )
Error[e46]: Undefined external "GAP_Set_Discoverability_Mode" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Set_Connectability_Mode" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Set_Pairability_Mode" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Register_Remote_Authentication" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "HCI_Delete_Stored_Link_Key" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Perform_Inquiry" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Error[e46]: Undefined external "GAP_Initiate_Bonding" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Error[e46]: Undefined external "GAP_End_Bonding" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\SPPDemo.r43 )
Error[e46]: Undefined external "GAP_Authentication_Response" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Set_Local_Device_Name" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Query_Local_Device_Name" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Set_Class_Of_Device" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Query_Class_Of_Device" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Query_Remote_Device_Name" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "HCI_Sniff_Mode" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\SPPDemo.r43 )
Error[e46]: Undefined external "HCI_Exit_Sniff_Mode" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Error[e46]: Undefined external "SPP_Open_Server_Port" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A
Error[e46]: Undefined external "SPP_Register_Raw_SDP_Record" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Close_Server_Port" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SDP_Delete_Service_Record" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Open_Remote_Port" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Close_Port" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\SPPDemo.r43 )
Error[e46]: Undefined external "SPP_Data_Read" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\SPPDemo.r43 )
Error[e46]: Undefined external "SPP_Data_Write" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug - MSP430F5438A Exp\
Obj\SPPDemo.r43 )
Error[e46]: Undefined external "SPP_Get_Configuration_Parameters" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Set_Configuration_Parameters" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Get_Queuing_Parameters" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Set_Queuing_Parameters" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "GAP_Query_Connection_Handle" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "SPP_Respond_Port_Information" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error[e46]: Undefined external "HCI_Register_Event_Callback" referred in SPPDemo ( C:\ti\Connectivity\CC256X BT\CC256x MSP430 Bluetopia SDK\v1.4 R1\MSP430_Experimentor\Samples\SPPDemo\Projects\IAR\Debug -
Error while running Linker
Total number of errors: 41
Total number of warnings: 5
请问是不是linker需要重新设置呢。如果是请问要设置哪个地方呢
