Other Parts Discussed in Thread: CC2541, CC3200, CC2650, CC2640, CC2630, CC2538, CC2431, CC2430, CC2531, CC2530, CC2533, CC2520, CC2420, CC2511, CC2510, SIMPLICITI, MSP430FG4618, CC2540
我从TI网站上下载的IAR8.30软件,安装后不能正常编译,有谁可以给一个IAR8.30破解版的软件给我吗?
Building configuration: bloodpressure - CC2540DK-MINI Keyfob Slave
Updating build tree...
BloodPressure_Main.c
Fatal Error[LMS001]: License check failed. Use the IAR License Manager to resolve the problem.
No license found. [LicenseCheck:2.13.3.584, RMS:8.5.0.0021, Feature:8051.EW.COMPILER, Version:1.02]
Error while running C/C++ Compiler
OSAL.c
OSAL_BloodPressure.c
OSAL_ClockBLE.c
OSAL_Memory.c
OSAL_PwrMgr.c
OSAL_Timers.c
OnBoard.c
bloodPressure.c
bpservice.c
devinfoservice.c
gap.c
gapbondmgr.c
gatt_uuid.c
hal_adc.c
hal_aes.c
hal_dma.c
hal_drivers.c
hal_flash.c
hal_key.c
hal_lcd.c
hal_led.c
hal_sleep.c
hal_startup.c
hal_timer.c
hal_uart.c
npi.c
osal_bufmgr.c
osal_cbtimer.c
osal_snv.c
peripheral.c
你好,我用的破解版 ,在原版的基础上写入注册号。感觉最省事,最可靠的破解方法。具体方法,直接去IAR官网下载正版V8.30,安装完后打补丁,补丁见附件。选择8051的文件夹
wenzhong shen
你好,我按照你说的方式破解,用 8.30 打开 1.40协议栈的例程编译,出现如下问题:
打开 1.3.2 协议栈例程也是如此问题,但是 用8.10 就没有:
是什么原因?该如何解决呢?急需,谢谢!
Building configuration: SimpleBLEPeripheral - CC2541
Linking
Error[e16]: Segment ISTACK (size: 0xc0 align: 0) is too long for segment definition. At least 0xe more bytes needed. The problem occurred while processing the segment placement command
"-Z(IDATA)ISTACK+_IDATA_STACK_SIZE#08-_IDATA_END", where at the moment of placement the available memory ranges were "IDATA:4e-ff"
Reserved ranges relevant to this placement:
IDATA:8-1f VREG
IDATA:21-40 VREG
IDATA:41-42 XSP
IDATA:43-43 DATA_I
IDATA:44-4b DATA_Z
IDATA:4c-4d IDATA_Z
IDATA:4e-ff ISTACK
BIT:0-7 BREG
BIT:80-97 SFR_AN
BIT:a0-af SFR_AN
BIT:b8-c7 SFR_AN
BIT:e8-ef SFR_AN
BIT:f8-ff SFR_AN
Error while running Linker
Total number of errors: 1
Total number of warnings: 0
发现了同样的错误:
Linking
processing the segment placement command "-Z(IDATA)ISTACK+_IDATA_STACK_SIZE#_IDATA_BEG-_IDATA_END", where at the moment of
IDATA:a-1f VREG
IDATA:21-40 VREG
IDATA:41-42 XSP
IDATA:43-43 DATA_I
IDATA:44-4b DATA_Z
IDATA:4c-4d IDATA_Z
IDATA:4e-ff ISTACK
BIT:0-7 BREG
BIT:80-97 SFR_AN
BIT:a0-af SFR_AN
BIT:b8-c7 SFR_AN
BIT:f8-ff SFR_AN
您可以在IAR官网 https://www.iar.com/iar-embedded-workbench/texas-instruments/ti-wireless/ 下载,建议您下载最新版本
所有可以用于TI的版本在如下网站下载
https://www.iar.com/iar-embedded-workbench/partners/texas-instruments/ti-wireless/
IAR Embedded Workbench with its integrated IAR C/C++ Compiler and C-SPY Debugger is the natural choice for wireless applications. In addition, IAR Systems offers a complete solution of RTOS and middleware components such as TCP/IP and USB that can enhance your embedded design.
Regardless of your selected target microcontroller, IAR Embedded Workbench ensures low memory footprint as well as code portability.
| Device/Platform | Protocol stacks | Development tools |
| CC3200 | Wi-Fi | IAR Embedded Workbench for ARM |
| CC2650 (superset of CC26x0) | IAR Embedded Workbench for ARM | |
| CC2640 | Bluetooth® Smart Bluetooth low energy |
| CC2630 | IEEE 802.15.4 ZigBee 6LoWPAN RF4CE |
| CC2538 | IEEE 802.15.4 ZigBee 6LoWPAN |
| CC2430, CC2431, CC2530, CC2531, CC2533 | ZigBee® RF4CE IEEE 802.15.4 |
IAR Embedded Workbench for 8051 |
| CC2520/CC2420 + MSP430 |
ZigBee IEEE 802.15.4 |
IAR Embedded Workbench for MSP430 |
| CC1110/CC1111 and CC2510/CC2511 | SimpliciTI™ | IAR Embedded Workbench for 8051 |
| MSP430FG4618/F2013 Experimenter Board eZ430-RF2500 Development Tool |
IAR Embedded Workbench for MSP430 | |
| CC2540 CC2541 |
Bluetooth low energy | IAR Embedded Workbench for 8051 |
The following evaluation editions are available for Low Power Wireless solutions from Texas Instruments:
