根据一下属性表及gattAttribute_t结构体中的定义,对应的handle都是0,这个时为什么呢?
typedef struct attAttribute_t
gattAttrType_t type; //!< Attribute type (2 or 16 octet UUIDs)
uint8 permissions; //!< Attribute permissions
uint16 handle; //!< Attribute handle - assigned internally by attribute server
uint8* const pValue; //!< Attribute value - encoding of the octet array is defined in
//!< the applicable profile. The maximum length of an attribute
//!< value shall be 512 octets.
} gattAttribute_t;
static gattAttribute_t simpleProfileAttrTbl[SERVAPP_NUM_ATTR_SUPPORTED] =
// Simple Profile Service
{ ATT_BT_UUID_SIZE, primaryServiceUUID }, /* type */
GATT_PERMIT_READ, /* permissions */
0, /* handle */
(uint8 *)&simpleProfileService /* pValue */
// Characteristic 1 Declaration
{ ATT_BT_UUID_SIZE, characterUUID },
GATT_PERMIT_READ,
0,
&simpleProfileChar1Props
// Characteristic Value 1
{ ATT_BT_UUID_SIZE, simpleProfilechar1UUID },
GATT_PERMIT_READ | GATT_PERMIT_WRITE,
0,
&simpleProfileChar1
// Characteristic 1 User Description
{ ATT_BT_UUID_SIZE, charUserDescUUID },
GATT_PERMIT_READ,
0,
simpleProfileChar1UserDesp
// Characteristic 2 Declaration
GATT_PERMIT_READ,
0,
&simpleProfileChar2Props
// Characteristic Value 2
{ ATT_BT_UUID_SIZE, simpleProfilechar2UUID },
GATT_PERMIT_READ,
0,
&simpleProfileChar2
// Characteristic 2 User Description
GATT_PERMIT_READ,
0,
simpleProfileChar2UserDesp
// Characteristic 3 Declaration
GATT_PERMIT_READ,
0,
&simpleProfileChar3Props
// Characteristic Value 3
{ ATT_BT_UUID_SIZE, simpleProfilechar3UUID },
GATT_PERMIT_WRITE,
0,
&simpleProfileChar3
// Characteristic 3 User Description
GATT_PERMIT_READ,
0,
simpleProfileChar3UserDesp
// Characteristic 4 Declaration
GATT_PERMIT_READ,
0,
&simpleProfileChar4Props
// Characteristic Value 4
{ ATT_BT_UUID_SIZE, simpleProfilechar4UUID },
0,
0,
&simpleProfileChar4
// Characteristic 4 configuration
{ ATT_BT_UUID_SIZE, clientCharCfgUUID },
0,
(uint8 *)simpleProfileChar4Config
// Characteristic 4 User Description
GATT_PERMIT_READ,
0,
simpleProfileChar4UserDesp
// Characteristic 5 Declaration
GATT_PERMIT_READ,
0,
&simpleProfileChar5Props
// Characteristic Value 5
{ ATT_BT_UUID_SIZE, simpleProfilechar5UUID },
GATT_PERMIT_AUTHEN_READ,
0,
simpleProfileChar5
// Characteristic 5 User Description
GATT_PERMIT_READ,
0,
simpleProfileChar5UserDesp
Yan:
谢谢你的解答,看资料中的描述,特征值的handle是确定的(比如UUID位0xFFF1的特征值的handle),是这样吗?底层的GATT分配是不是只要属性表确定后handle就会是确定的呢?另外,还想跟您请教一下,程序中需要得到某些特征值的handle的时候应该如何获取呢?感谢!
