标亮的是烧录失败的工程,其他的是烧录运行成功的,这些工程来自simplelink_lowpower_f3_sdk_8_10_01_02\examples\rtos\LP_EM_CC2340R5\ble5stack和simplelink_lowpower_f3_sdk_8_10_01_02\examples\rtos\LP_EM_CC2340R5\drivers
console显示:
下面两行完整信息:
Cortex_M0P: JTAG Communication Error: (Error -615 @ 0x0) The target failed to see a correctly formatted SWD header. The connection to the target may be unreliable. Try lowering the TCLK setting before trying again. (Emulation package 12.7.0.00130)
Cortex_M0P: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
我的设备是xds110 debugger和cc2340r5开发板:
