Hi.
當使用 Android 10 以上版本,同時使用設定/藍芽 進行配對,或需要輸入 Pin code 才能配對完成,要如何移除輸入 Pin code 步驟,直接配對完成?
Hi.
Thanks for reaching out. I am not sure I understand correctly. Do you want to disable the pin input from the central (phone)? I would suggest to take a look at this documentation (Table 17): https://software-dl.ti.com/simplelink/esd/simplelink_lowpower_f3_sdk/8.40.00.61/exports/docs/ble5stack/ble_user_guide/html/ble-stack-5.x/gapbondmngr-cc23xx.html
I would check the following modification in SysConfig:
