CC113L: CC113L--Enabling Manchester decoding results in a decrease in reception success rate.
Part Number: CC113L
Hi
Configuration supplement:Base Frequency(433.00MHz)Deviation(39.6kHz)Data Rate(19.2 kbps--After encoding, 38.348.)Modulation Format(2-FSK)Encoding(Manchester)Preamble((0x5555 5555 5555))Sync Word(0x569A)
When I configured CC113L with the following parameters, the laboratory test showed that the reception rate was close to 100%.
NRZ code reception, reading data from the FIFO, Manchester decoding is processed by software.
   .Reg.B.IOCFG2 = 0x2E,         //GDO2 Output Pin Configuration
    .Reg.B.IOCFG1 = 0x2E,         //GDO1 Output Pin Configuration
    .Reg.B.IOCFG0 = 0x00,         //GDO0 Output Pin Configuration
    .Reg.B.FIFOTHR = 0x4F,        //RX FIFO Thresholds (64 bytes)
    .Reg.B.SYNC1 = 0x56,          //Sync Word, High Byte
    .Reg.B.SYNC0 = 0x9A,          //Sync Word, Low Byte
    .Reg.B.PKTLEN = 0x40,         //Packet Length, (64 bytes Manchester )
    .Reg.B.PKTCTRL1 = 0x04,       //Packet Automation Control - Auto RSSI
    .Reg.B.PKTCTRL0 = 0x00,       //Packet Automation Control
    .Reg.B.ADDR = 0x00,           //Device address
    .Reg.B.CHANNR = 0x00,         //Channel number
    .Reg.B.FSCTRL1 = 0x08,        //Frequency Synthesize
    .Reg.B.FSCTRL0 = 0x00,        //Frequency Synthesizer Control
    .Reg.B.FREQ2 = 0x10,          //Frequency Control Word, High Byte
    .Reg.B.FREQ1 = 0xA7,          //Frequency Control Word, Middle Byte    // 433.00MHz
    .Reg.B.FREQ0 = 0x62,          //Frequency Control Word, Low Byte
    .Reg.B.MDMCFG4 = 0x9A,        //Modem Configuration // Filter BW 162 kHz
    .Reg.B.MDMCFG3 = 0x83,        //Modem Configuration //38.3835 kbps
    .Reg.B.MDMCFG2 = 0x02,        //Modem Configuration    // 2-FSK , 16/16 SYNC,
    .Reg.B.MDMCFG1 = 0x02,        //Modem Configuration
    .Reg.B.MDMCFG0 = 0xF8,        //Modem Configuration
    .Reg.B.DEVIATN = 0x45,        //Modem Deviation Setting //45 = 41.259766kHz
    .Reg.B.MCSM2 = 0x07,          //Main Radio Control State Machine Configuration
    .Reg.B.MCSM1 = 0x30,          //Main Radio Control State Machine Configuration
    .Reg.B.MCSM0 = 0x38,          //Main Radio Control State Machine Configuration
    .Reg.B.FOCCFG = 0x1E,         //Frequency Offset Compensation Configuration //BW/4 = 40kHz
    .Reg.B.BSCFG = 0x1D,          //Bit Synchronization Configuration
    .Reg.B.AGCCTRL2 = 0xC7,       //AGC Control
    .Reg.B.AGCCTRL1 = 0x08,       //AGC Control
    .Reg.B.AGCCTRL0 = 0x32,       //AGC Control
    .Reg.B.NOTUSED_0x1E = 0x00,   //NOT USED
    .Reg.B.NOTUSED_0x1F = 0x00,   //NOT USED
    .Reg.B.RESERVED_0x20 = 0xFB,  //Use setting from SmartRF Studio
    .Reg.B.FREND1 = 0xB6,         //Front End RX Configuration
    .Reg.B.NOTUSED_0x22 = 0x00,   //NOT USED
    .Reg.B.FSCAL3 = 0xEA,         //Frequency Synthesizer Calibration
    .Reg.B.FSCAL2 = 0x2A,         //Frequency Synthesizer Calibration
    .Reg.B.FSCAL1 = 0x00,         //Frequency Synthesizer Calibration
    .Reg.B.FSCAL0 = 0x1F,         //Frequency Synthesizer Calibration
    .Reg.B.NOTUSED_0x27 = 0x00,   //NOT USED
    .Reg.B.NOTUSED_0x28 = 0x00,   //NOT
    .Reg.B.RESERVED_0x29 = 0x59,  //Use setting from SmartRF Studio
    .Reg.B.RESERVED_0x2A = 0x7F,  //Use setting from SmartRF Studio
    .Reg.B.RESERVED_0x2B = 0x3F,  //Use setting from SmartRF Studio
    .Reg.B.TEST2 = 0x81,          //Various Test Settings
    .Reg.B.TEST1 = 0x35,          //Various Test Settings
    .Reg.B.TEST0 = 0x09           //Various Test Settings
After enabling the Manchester decoding of CC113L, the reception rate is approximately 70%. The configuration is as follows.
Attempting to modify other configurations did not result in any significant improvement in the reception rate.
    .Reg.B.FIFOTHR = 0x47,        //RX FIFO Thresholds (32 bytes)
    .Reg.B.SYNC1 = 0x00,          //Sync Word, High Byte
    .Reg.B.SYNC0 = 0x1B,          //Sync Word, Low Byte
    .Reg.B.PKTLEN = 0x20,         //Packet Length, (32 bytes Manchester )
    .Reg.B.MDMCFG2 = 0x0A,        //Modem Configuration    // 2-FSK, Manchester Enable , 16/16 SYNC, //test
I hope somone help me solve the problem.
