CC2650 私有模式,如何设置到5Mbps? 所有的私有模式的例子只是在200kbps的速率。而RF的初始化有好多没有定义的常数,不知何用。
下载还没有release,可以通过下面的Link post一个请求,try try 非正式版
https://e2e.ti.com/support/wireless_connectivity/proprietary_2-4_ghz/f/964/p/524516/1910310#1910310
如果是基于BLE的,如下信息供参考
Bluetooth® 5 quadruples range, doubles speed, increases data broadcasting capacity by 800% : https://www.bluetooth.com/news/pressreleases/2016/06/16/-bluetooth5-quadruples-rangedoubles-speedincreases-data-broadcasting-capacity-by-800
Bluetooth® 5 will unlock the power of the SimpleLink™ CC2640 wireless MCU:https://e2e.ti.com/blogs_/b/connecting_wirelessly/archive/2016/06/22/bluetooth-5-will-unlock-the-power-of-the-simplelink-cc2640-wireless-mcu
What’s new with TI Bluetooth low energy? See it all at Bluetooth World 2016:https://e2e.ti.com/blogs_/b/connecting_wirelessly/archive/2016/03/10/software-launchpad-kit-and-module-it-39-s-all-new-at-bluetooth-world-2016
CC2640/CC2650 Getting Started and FAQ [Updated 2016 Sep 12] https://e2e.ti.com/support/wireless_connectivity/bluetooth_low_energy/f/538/t/404236 -> Q: Will CC2640 support Bluetooth 5?
1. 5.0标准没出前,就已经给了一个高速的例子,用两块2650对发,你可以测试看看,蓝牙5.0 也只是速度提到2Mbps,并可支持更长的包
https://github.com/ti-simplelink/ble_examples/blob/master/docs/throughput_example.md
2. 1350支持4Mbps是在868M下,2.4G HSM也没有正式release,有例子程序可以实测。看你怎么理解有效带宽。一种做法是通过观察发送状态下,PA开启关闭的时间来判断的。包和包之间会有一些间隔。我测过1.5Mbps, 能到1Mbps. 4Mbps没有测过,类比应该只能接近3Mbps
3. 关于高速的支持,会绑定在TI-RTOS里,建议关注最新的TI-RTOS更新。
