CC1310Launchpad为什么用CCS烧不进ti154stack的程序?
Other Parts Discussed in Thread: CC1350, CC1310
TI工程师,
我用CCS烧ti154stack目录下的程序,比如sensor、collector都烧不进,而像easylink、drives下的都可以烧,提示错误
IcePick_C: Error connecting to the target: (Error -241 @ 0x0) A router subpath could not be accessed. A security error has probably occurred. Make sure your device is unlocked. (Emulation package 7.0.188.0)   ,但是用Flash Programmer就可以把相应的hex文件烧进去,我要用到TI15.4的,现在每次改完代码都要用Flash Programmer 烧感觉很麻烦,CCS和SDK都是最新版的,希望可以解决这个问题。
