NFC 和 RFID 参考设计 工程编译器问题
您好:我下载了官网上   NFC 和 RFID 超低功率卡存在检测参考设计   的CCS工程    用的CCS8.1.0 编译,编译错误显示
This project was created using a version of compiler that is not currently installed - 4.1.2 [MSP430]:
- See 'Help > Install New Software' and select 'Code Generation Tools Updates' to check if this compiler is available through a CCS update.
- Visit CCS App Center to get the latest compiler support.
- Or download and install the compiler [http://software-dl.ti.com/codegen/non-esd/downloads], then register it with CCS through 'Preferences > CCS > Build > Compilers'.
已经尝试通过CCS update解决,无效,且未在
 4.1.2 [MSP430]:这个版本的编译器在   [http://software-dl.ti.com/codegen/non-esd/downloads]里面没找到,怎么解决
