rfWsnNodeExtFlashOadClient-CC310_LAUNCHXL_tirtos 支持CC1190
Other Parts Discussed in Thread: CC1190, SYSCONFIG, SYSBIOS, CC1352P, CC2650, CC1350, CC1310, CC1350STK
我用的 sdk 为 simplelink_cc13x0_sdk_2_40_00_20,在这个rfWsnNodeExtFlashOadClient-CC310_LAUNCHXL_tirtos例子上增加pa (CC1190)的功能。现场测试效果不怎么好,请帮我看一下我的代码。
修改的文件为 EasyLink.c
 * Copyright (c) 2015-2018, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***** Includes *****/
#include "EasyLink.h"
#include "easylink_config.h"
#include <stdbool.h>
#include <stdint.h>
#include <stddef.h>
#include <limits.h>
#include <ti/drivers/PIN.h>
#ifndef USE_DMM
#include <ti/drivers/rf/RF.h>
#else
#include <dmm/dmm_rfmap.h>
#endif //USE_DMM
#include "Board.h"
/* TI Drivers */
#ifdef Board_SYSCONFIG_PREVIEW
#include <smartrf_settings/smartrf_settings.h>
#else
#include <smartrf_settings/smartrf_settings_predefined.h>
#endif
/* BIOS Header files */
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
/* XDCtools Header files */
#include <xdc/runtime/Error.h>
#include <ti/devices/DeviceFamily.h>
#include DeviceFamily_constructPath(driverlib/rf_data_entry.h)
#include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h)
#include DeviceFamily_constructPath(driverlib/rf_prop_cmd.h)
#include DeviceFamily_constructPath(driverlib/chipinfo.h)
#include DeviceFamily_constructPath(inc/hw_memmap.h)
#include DeviceFamily_constructPath(inc/hw_fcfg1.h)
#include DeviceFamily_constructPath(inc/hw_ccfg.h)
#include DeviceFamily_constructPath(inc/hw_ccfg_simple_struct.h)
union setupCmd_t{
#if (defined Board_CC1352P1_LAUNCHXL)  || (defined Board_CC1352P_2_LAUNCHXL)  || \
    (defined Board_CC1352P_4_LAUNCHXL)
    rfc_CMD_PROP_RADIO_DIV_SETUP_PA_t divSetup;
#else
    rfc_CMD_PROP_RADIO_DIV_SETUP_t divSetup;
#endif
    rfc_CMD_PROP_RADIO_SETUP_t setup;
//Primary IEEE address location
#define EASYLINK_PRIMARY_IEEE_ADDR_LOCATION   (FCFG1_BASE + FCFG1_O_MAC_15_4_0)
//Secondary IEEE address location
#define EASYLINK_SECONDARY_IEEE_ADDR_LOCATION (CCFG_BASE  + CCFG_O_IEEE_MAC_0)
#define EASYLINK_RF_EVENT_MASK  ( RF_EventLastCmdDone | \
             RF_EventCmdAborted | RF_EventCmdStopped | RF_EventCmdCancelled | \
             RF_EventCmdPreempted )
#define EASYLINK_RF_CMD_HANDLE_INVALID -1
#define EasyLink_CmdHandle_isValid(handle) (handle >= 0)
/* EasyLink Proprietary Header Configuration */
#define EASYLINK_PROP_TRX_SYNC_WORD     0x930B51DE
#define EASYLINK_PROP_HDR_NBITS         8U
#define EASYLINK_PROP_LEN_OFFSET        0U
/* IEEE 802.15.4g Header Configuration
 * _S indicates the shift for a given bit field
 * _M indicates the mask required to isolate a given bit field
#define EASYLINK_IEEE_TRX_SYNC_WORD     0x0055904E
#define EASYLINK_IEEE_HDR_NBITS         16U
#define EASYLINK_IEEE_LEN_OFFSET        0xFC
#define EASYLINK_IEEE_HDR_LEN_S         0U
#define EASYLINK_IEEE_HDR_LEN_M         0x00FFU
#define EASYLINK_IEEE_HDR_CRC_S         12U
#define EASYLINK_IEEE_HDR_CRC_M         0x1000U
#define EASYLINK_IEEE_HDR_WHTNG_S       11U
#define EASYLINK_IEEE_HDR_WHTNG_M       0x0800U
#define EASYLINK_IEEE_HDR_CRC_2BYTE     1U
#define EASYLINK_IEEE_HDR_CRC_4BYTE     0U
#define EASYLINK_IEEE_HDR_WHTNG_EN      1U
#define EASYLINK_IEEE_HDR_WHTNG_DIS     0U
#define EASYLINK_IEEE_HDR_CREATE(crc, whitening, length) {                         \
    ((crc << EASYLINK_IEEE_HDR_CRC_S) | (whitening << EASYLINK_IEEE_HDR_WHTNG_S) | \
    ((length << EASYLINK_IEEE_HDR_LEN_S) & EASYLINK_IEEE_HDR_LEN_M))               \
/* Common Configuration (Prop and IEEE) */
#define EASYLINK_HDR_LEN_NBITS          8U
/* Return the size of the header rounded up to
 * the nearest integer number of bytes
#define EASYLINK_HDR_SIZE_NBYTES(x) (((x) >> 3U) + (((x) & 0x03) ? 1U : 0U))
/***** Prototypes *****/
static EasyLink_TxDoneCb txCb;
static EasyLink_ReceiveCb rxCb;
#if (defined(DeviceFamily_CC13X0) || defined(DeviceFamily_CC13X2))
static EasyLink_GetRandomNumber getRN;
#endif // (defined(DeviceFamily_CC13X0) || defined(DeviceFamily_CC13X2))
/***** Variable declarations *****/
static RF_Object rfObject;
static RF_Handle rfHandle;
//Rx buffer includes data entry structure, hdr (len=1byte), dst addr (max of 8 bytes) and data
//which must be aligned to 4B
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN (rxBuffer, 4);
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment = 4
#elif defined(__GNUC__)
__attribute__((aligned(4)))
#else
#error This compiler is not supported.
#endif
static uint8_t rxBuffer[sizeof(rfc_dataEntryGeneral_t) + 1 +
                        EASYLINK_MAX_ADDR_SIZE +
                        EASYLINK_MAX_DATA_LENGTH];
static dataQueue_t dataQueue;
static rfc_propRxOutput_t rxStatistics;
//Tx buffer includes hdr (len=1 or 2 bytes), dst addr (max of 8 bytes) and data
static uint8_t txBuffer[2U + EASYLINK_MAX_ADDR_SIZE + EASYLINK_MAX_DATA_LENGTH];
// Addr size for Filter and Tx/Rx operations
// Set default to 1 byte addr to work with SmartRF studio default settings
// NOTE that it can take on values 0, 1, 2, 4 or 8
static uint8_t addrSize = EASYLINK_ADDR_SIZE;
// Header Size (in bytes) for Advanced Tx operations. For IEEE 802.15.4g modes
// it is 2 bytes, 1 for the rest
static uint8_t hdrSize = EASYLINK_HDR_SIZE_NBYTES(EASYLINK_PROP_HDR_NBITS);
//Indicating that the API is initialized
static uint8_t configured = 0;
//Indicating that the API suspended
static uint8_t suspended = 0;
//Use an IEEE header for the Tx/Rx command
static bool useIeeeHeader = 0;
//RF Params allowing configuration of the inactivity timeout, which is the time
//it takes for the radio to shut down when there are no commands in the queue
static RF_Params rfParams;
static bool rfParamsConfigured = 0;
//Flag used to indicate the multi client operation is enabled
static bool rfModeMultiClient = EASYLINK_ENABLE_MULTI_CLIENT;
//Async Rx timeout value
static uint32_t asyncRxTimeOut = EASYLINK_ASYNC_RX_TIMEOUT;
//local commands, contents will be defined by modulation type
static union setupCmd_t EasyLink_cmdPropRadioSetup;
static rfc_CMD_FS_t EasyLink_cmdFs;
static RF_Mode EasyLink_RF_prop;
static rfc_CMD_PROP_TX_ADV_t EasyLink_cmdPropTxAdv;
static rfc_CMD_PROP_RX_ADV_t EasyLink_cmdPropRxAdv;
static rfc_CMD_PROP_CS_t EasyLink_cmdPropCs;
// The table for setting the Rx Address Filters
#pragma DATA_ALIGN (addrFilterTable, 4);
#endif
static uint8_t addrFilterTable[EASYLINK_MAX_ADDR_FILTERS * EASYLINK_MAX_ADDR_SIZE] = EASYLINK_ADDR_FILTER_TABLE;
// Used as a pointer to an entry in the EasyLink_rfSettings array
static EasyLink_RfSetting *rfSetting = 0;
// Default inactivity timeout of 1 ms
static uint32_t inactivityTimeout = EASYLINK_IDLE_TIMEOUT;
//Mutex for locking the RF driver resource
static Semaphore_Handle busyMutex;
//Handle for last Async command, which is needed by EasyLink_abort
static RF_CmdHandle asyncCmdHndl = EASYLINK_RF_CMD_HANDLE_INVALID;
/* Set Default parameters structure */
static const EasyLink_Params EasyLink_defaultParams = EASYLINK_PARAM_CONFIG;
static EasyLink_Params EasyLink_params;
static PIN_Handle paPinHandle;
static PIN_State paPinState;
PIN_Config paPinTable[] = {
    Board_PALNA_HGM | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_PALNA_LNA | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_PALNA_PA | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    PIN_TERMINATE
/* Check the address size (in bytes) is either 0 or a power of 2, and less than
 * the maximum allowed size
static bool isAddrSizeValid(uint8_t ui8AddrSize)
    return((ui8AddrSize == 0) || (!(ui8AddrSize & (ui8AddrSize - 1)) && \
           (ui8AddrSize <= EASYLINK_MAX_ADDR_SIZE)));
void EasyLink_Params_init(EasyLink_Params *params)
    *params = EasyLink_defaultParams;
//Create an Advanced Tx command from a Tx Command
void createTxAdvFromTx(rfc_CMD_PROP_TX_ADV_t *dst, rfc_CMD_PROP_TX_t *src)
    memset(dst, 0 , sizeof(rfc_CMD_PROP_TX_ADV_t));
    dst->commandNo = CMD_PROP_TX_ADV;
    memcpy(&(dst->status), &(src->status), offsetof(rfc_CMD_PROP_TX_ADV_t, pktConf) -
           offsetof(rfc_CMD_PROP_TX_ADV_t, status));
    dst->pktConf.bFsOff = src->pktConf.bFsOff;
    dst->pktConf.bUseCrc = src->pktConf.bUseCrc;
    dst->pktLen = src->pktLen;
    dst->syncWord = src->syncWord;
//Callback for Async Tx complete
static void txDoneCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e)
    EasyLink_Status status;
    //Release now so user callback can call EasyLink API's
    Semaphore_post(busyMutex);
    if (e & RF_EventLastCmdDone)
        status = EasyLink_Status_Success;
    else if ( (e & RF_EventCmdAborted) || (e & RF_EventCmdCancelled) || (e & RF_EventCmdPreempted) )
        status = EasyLink_Status_Aborted;
    else
        status = EasyLink_Status_Tx_Error;
    if (txCb != NULL)
        txCb(status);
//Callback for Clear Channel Assessment Done
static void ccaDoneCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e)
    RF_ScheduleCmdParams schParams_prop;
    EasyLink_Status status        = EasyLink_Status_Tx_Error;
    RF_Op* pCmd                   = RF_getCmdOp(h, ch);
    bool bCcaRunAgain             = false;
    static uint8_t be             = EASYLINK_MIN_CCA_BACKOFF_WINDOW;
    static uint32_t backOffTime;
        if(pCmd->status ==  PROP_DONE_IDLE)
            // Carrier Sense operation ended with an idle channel,
            // and the next op (TX) should have already taken place
            // Failure to transmit is reflected in the default status,
            // EasyLink_Status_Tx_Error, being set
            if(pCmd->pNextOp->status == PROP_DONE_OK)
                // Reset the number of retries
        else if(pCmd->status == PROP_DONE_BUSY)
            if(be > EASYLINK_MAX_CCA_BACKOFF_WINDOW)
                // CCA failed max number of retries
                status = EasyLink_Status_Busy_Error;
            else
                // The back-off time is a random number chosen from 0 to 2^be,
                // where 'be' goes from EASYLINK_MIN_CCA_BACKOFF_WINDOW
                // to EASYLINK_MAX_CCA_BACKOFF_WINDOW. This number is then converted
                // into EASYLINK_CCA_BACKOFF_TIMEUNITS units, and subsequently used to
                // schedule the next CCA sequence. The variable 'be' is incremented each
                // time, up to a pre-configured maximum, the back-off algorithm is run.
                backOffTime = (getRN() & ((1 << be++)-1)) *
                        EasyLink_us_To_RadioTime(EASYLINK_CCA_BACKOFF_TIMEUNITS);
                // running CCA again
                bCcaRunAgain = true;
                // The random number generator function returns a value in the range
                // 0 to 2^15 - 1 and we choose the 'be' most significant bits as our
                // back-off time in milliseconds (converted to RAT ticks)
                pCmd->startTime = RF_getCurrentTime() + backOffTime;
                // post the chained CS+TX command again while checking
                // for a clear channel (CCA) before sending a packet
                if(rfModeMultiClient)
                    schParams_prop.priority = RF_PriorityHigh;
                    asyncCmdHndl = RF_scheduleCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropCs,
                                                  &schParams_prop, ccaDoneCallback, EASYLINK_RF_EVENT_MASK);
                else
                    asyncCmdHndl = RF_postCmd(h, (RF_Op*)&EasyLink_cmdPropCs,
                        RF_PriorityHigh, ccaDoneCallback, EASYLINK_RF_EVENT_MASK);
        else
            // The CS command status should be either IDLE or BUSY,
            // all other status codes can be considered errors
            // Status is set to the default, EasyLink_Status_Tx_Error
    else if ( (e & RF_EventCmdAborted) || (e & RF_EventCmdCancelled ) || (e & RF_EventCmdPreempted ) )
    else
    if ((txCb != NULL) && (!bCcaRunAgain))
        txCb(status);
//Callback for Async Rx complete
static void rxDoneCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e)
    EasyLink_Status status = EasyLink_Status_Rx_Error;
    //create rxPacket as a static so that the large payload buffer it is not
    //allocated from the stack
    static EasyLink_RxPacket rxPacket;
    rfc_dataEntryGeneral_t *pDataEntry;
    pDataEntry = (rfc_dataEntryGeneral_t*) rxBuffer;
        //Check command status
        if (EasyLink_cmdPropRxAdv.status == PROP_DONE_OK)
            //Check that data entry status indicates it is finished with
            if (pDataEntry->status != DATA_ENTRY_FINISHED)
            else if ( (rxStatistics.nRxOk == 1) ||
                    //or filer disabled and ignore due to addr mistmatch
                    ((EasyLink_cmdPropRxAdv.pktConf.filterOp == 1) &&
                     (rxStatistics.nRxIgnored == 1)) )
                //copy length from pDataEntry
                rxPacket.len = *(uint8_t*)(&pDataEntry->data) - addrSize;
                if(useIeeeHeader)
                    hdrSize = EASYLINK_HDR_SIZE_NBYTES(EASYLINK_IEEE_HDR_NBITS);
                else
                //copy address from packet payload (as it is not in hdr)
                memcpy(&rxPacket.dstAddr, (&pDataEntry->data + hdrSize), addrSize);
                //copy payload
                memcpy(&rxPacket.payload, (&pDataEntry->data + hdrSize + addrSize), rxPacket.len);
                rxPacket.rssi = rxStatistics.lastRssi;
                rxPacket.absTime = rxStatistics.timeStamp;
            else if ( rxStatistics.nRxBufFull == 1)
                status = EasyLink_Status_Rx_Buffer_Error;
            else if ( rxStatistics.nRxStopped == 1)
            else
        else if ( EasyLink_cmdPropRxAdv.status == PROP_DONE_RXTIMEOUT)
            status = EasyLink_Status_Rx_Timeout;
        else
    else if (e & (RF_EventCmdCancelled | RF_EventCmdAborted | RF_EventCmdPreempted | RF_EventCmdStopped))
    if (rxCb != NULL)
           PIN_setOutputValue(paPinHandle, Board_PALNA_PA,  0);
           PIN_setOutputValue(paPinHandle, Board_PALNA_LNA, 0);
           PIN_setOutputValue(paPinHandle, Board_PALNA_LNA, 1);
        rxCb(&rxPacket, status);
//Callback for Async TX Test mode
static void asyncCmdCallback(RF_Handle h, RF_CmdHandle ch, RF_EventMask e)
static EasyLink_Status enableTestMode(EasyLink_CtrlOption mode)
    EasyLink_Status status = EasyLink_Status_Cmd_Error;
    //This needs to be static as it is used by the RF driver and Modem after
    //this function exits
    static rfc_CMD_TX_TEST_t txTestCmd = {0};
    static rfc_CMD_RX_TEST_t rxTestCmd = {0};
    if((!configured) || suspended)
        return EasyLink_Status_Config_Error;
    if((mode != EasyLink_Ctrl_Test_Tone)    &&
       (mode != EasyLink_Ctrl_Test_Signal)  &&
       (mode != EasyLink_Ctrl_Rx_Test_Tone))
        return EasyLink_Status_Param_Error;
    if (EasyLink_CmdHandle_isValid(asyncCmdHndl))
        return EasyLink_Status_Busy_Error;
    //Check and take the busyMutex
    if (Semaphore_pend(busyMutex, 0) == false)
    if((mode == EasyLink_Ctrl_Test_Tone) || (mode == EasyLink_Ctrl_Test_Signal))
        txTestCmd.commandNo = CMD_TX_TEST;
        txTestCmd.startTrigger.triggerType = TRIG_NOW;
        txTestCmd.startTrigger.pastTrig = 1;
        txTestCmd.startTime = 0;
        txTestCmd.config.bFsOff = 1;
        txTestCmd.syncWord = EasyLink_cmdPropTxAdv.syncWord;
        /* WhitenMode
         * 0: No whitening
         * 1: Default whitening
         * 2: PRBS-15
         * 3: PRBS-32
        txTestCmd.config.whitenMode = EASYLINK_WHITENING_MODE;
        //set tone (unmodulated) or signal (modulated)
        if (mode == EasyLink_Ctrl_Test_Tone)
            txTestCmd.txWord = 0xFFFF;
            txTestCmd.config.bUseCw = 1;
        else
            txTestCmd.txWord = 0xAAAA;
            txTestCmd.config.bUseCw = 0;
        //generate continuous test signal
        txTestCmd.endTrigger.triggerType = TRIG_NEVER;
        /* Post command and store Cmd Handle for future abort */
        asyncCmdHndl = RF_postCmd(rfHandle, (RF_Op*)&txTestCmd,
                                  RF_PriorityNormal, asyncCmdCallback,
        /* Has command completed? */
        uint16_t count = 0;
        while (txTestCmd.status != ACTIVE)
            //The command did not complete as fast as expected, sleep for 10ms
            Task_sleep(10000 / Clock_tickPeriod);
            if (count++ > 500)
                //Should not get here, if we did Something went wrong with the
                //the RF Driver, get out of here and return an error.
                //The next command will likely lock up.
                break;
        if (txTestCmd.status == ACTIVE)
    else // mode is EasyLink_Ctrl_Rx_Test_Tone
        rxTestCmd.commandNo = CMD_RX_TEST;
        rxTestCmd.startTrigger.triggerType = TRIG_NOW;
        rxTestCmd.startTrigger.pastTrig = 1;
        rxTestCmd.startTime = 0;
        rxTestCmd.config.bFsOff = 1;
        // Correlation threshold set to max to prevent sync, as RSSI values
        // are locked after sync
        rxTestCmd.config.bNoSync = 1;
        rxTestCmd.syncWord = EasyLink_cmdPropRxAdv.syncWord0;
        //detect test signal continuously
        rxTestCmd.endTrigger.triggerType = TRIG_NEVER;
        asyncCmdHndl = RF_postCmd(rfHandle, (RF_Op*)&rxTestCmd,
        if(EasyLink_CmdHandle_isValid(asyncCmdHndl))
        else
    return status;
EasyLink_Status EasyLink_init(EasyLink_Params *params)
    /* Open pa pins */
     paPinHandle = PIN_open(&paPinState, paPinTable);
     if (!paPinHandle)
       //  System_abort("Error initializing board 3.3V domain pins\n");
    if (params == NULL)
        EasyLink_Params_init(&EasyLink_params);
    } else
        memcpy(&EasyLink_params, params, sizeof(EasyLink_params));
    if (configured)
        //Already configure, check and take the busyMutex
        RF_close(rfHandle);
    if (!rfParamsConfigured)
        RF_Params_init(&rfParams);
        //set default InactivityTimeout to 1000us
        rfParams.nInactivityTimeout = inactivityTimeout;
        //configure event callback
        if(EasyLink_params.pClientEventCb != NULL && EasyLink_params.nClientEventMask != 0){
            rfParams.pClientEventCb = EasyLink_params.pClientEventCb;
            rfParams.nClientEventMask = EasyLink_params.nClientEventMask;
        rfParamsConfigured = 1;
    // Assign the random number generator function pointer to the global
    // handle, if it is NULL any function that employs it will return a
    // configuration error
    getRN = EasyLink_params.pGrnFxn;
    // Configure the EasyLink Carrier Sense Command
    memset(&EasyLink_cmdPropCs, 0, sizeof(rfc_CMD_PROP_CS_t));
    EasyLink_cmdPropCs.commandNo                = CMD_PROP_CS;
    EasyLink_cmdPropCs.rssiThr                  = EASYLINK_CS_RSSI_THRESHOLD_DBM;
    EasyLink_cmdPropCs.startTrigger.triggerType = TRIG_NOW;
    EasyLink_cmdPropCs.condition.rule           = COND_STOP_ON_TRUE;  // Stop next command if this command returned TRUE,
                                                            // End causes for the CMD_PROP_CS command:
                                                            // Observed channel state Busy with csConf.busyOp = 1:                            PROP_DONE_BUSY        TRUE
                                                            // 0bserved channel state Idle with csConf.idleOp = 1:                            PROP_DONE_IDLE        FALSE
                                                            // Timeout trigger observed with channel state Busy:                              PROP_DONE_BUSY        TRUE
                                                            // Timeout trigger observed with channel state Idle:                              PROP_DONE_IDLE        FALSE
                                                            // Timeout trigger observed with channel state Invalid and csConf.timeoutRes = 0: PROP_DONE_BUSYTIMEOUT TRUE
                                                            // Timeout trigger observed with channel state Invalid and csConf.timeoutRes = 1: PROP_DONE_IDLETIMEOUT FALSE
                                                            // Received CMD_STOP after command started:                                       PROP_DONE_STOPPED     FALSE
    EasyLink_cmdPropCs.csConf.bEnaRssi          = 0x1; // Enable RSSI as a criterion
    EasyLink_cmdPropCs.csConf.busyOp            = 0x1; // End carrier sense on channel Busy
    EasyLink_cmdPropCs.csConf.idleOp            = 0x0; // Continue carrier sense on channel Idle
    EasyLink_cmdPropCs.csEndTrigger.triggerType = TRIG_REL_START; // Ends at a time relative to the command started
    EasyLink_cmdPropCs.csEndTime                = EasyLink_us_To_RadioTime(EASYLINK_CHANNEL_IDLE_TIME_US);
#endif //(defined(DeviceFamily_CC13X0) || defined(DeviceFamily_CC13X2))
#if (defined(FEATURE_OAD_ONCHIP))
    EasyLink_params.ui32ModType = EasyLink_Phy_Custom;
#endif
    bool useDivRadioSetup = true;
    bool rfConfigOk = false;
    bool createCmdTxAdvFromTx = true;
    useIeeeHeader = false;
    // Check if the PHY setting is compatible with the current device
    switch(EasyLink_params.ui32ModType)
        case EasyLink_Phy_Custom:
            if((ChipInfo_ChipFamilyIs_CC26x0()) || (ChipInfo_ChipFamilyIs_CC26x0R2()))
                useDivRadioSetup= false;
            rfConfigOk = true;
        break;
        case EasyLink_Phy_50kbps2gfsk:
            if(!(ChipInfo_ChipFamilyIs_CC26x0()) && !(ChipInfo_ChipFamilyIs_CC26x0R2()))
                useDivRadioSetup= true;
                rfConfigOk = true;
        break;
        case EasyLink_Phy_625bpsLrm:
                && !(ChipInfo_ChipFamilyIs_CC13x2_CC26x2()))
                rfConfigOk = true;
        break;
        case EasyLink_Phy_2_4_100kbps2gfsk:
            if((ChipInfo_GetChipType() == CHIP_TYPE_CC2640R2))
                rfConfigOk = true;
        break;
        case EasyLink_Phy_2_4_200kbps2gfsk:
            if((ChipInfo_GetChipType() == CHIP_TYPE_CC2650))
                rfConfigOk = true;
        break;
        case EasyLink_Phy_2_4_250kbps2gfsk:
                rfConfigOk = true;
        break;
        case EasyLink_Phy_5kbpsSlLr:
                rfConfigOk = true;
#if (defined Board_CC1352P_4_LAUNCHXL)
                // CC1352P-4 SLR operates at 433.92 MHz
                EasyLink_cmdFs.frequency = 0x01B1;
                EasyLink_cmdFs.fractFreq = 0xEB9A;
#endif
        break;
        case EasyLink_Phy_200kbps2gfsk:
            if((ChipInfo_GetChipType() == CHIP_TYPE_CC1312) || (ChipInfo_GetChipType() == CHIP_TYPE_CC1352) ||
               (ChipInfo_GetChipType() == CHIP_TYPE_CC1352P))
#if !defined(Board_CC1352P_4_LAUNCHXL)
                // This mode is not supported in the 433 MHz band
                rfConfigOk = true;
                createCmdTxAdvFromTx = false;
                useIeeeHeader = true;
#endif
            break;
        default:  // Invalid PHY setting
            rfConfigOk = false;
        break;
    // Return an error if the PHY setting is incompatible with the current device
    if(!rfConfigOk)
        if (busyMutex != NULL)
    // Loop through the EasyLink_supportedPhys array looking for the PHY
    uint8_t i = 0;
    while(i < EasyLink_numSupportedPhys)
        if(EasyLink_supportedPhys[i].EasyLink_phyType == EasyLink_params.ui32ModType)
            rfSetting = &EasyLink_supportedPhys[i];
            break;
        i++;
    // Return an error if the PHY isn't in the supported settings list
    if(rfSetting == 0)
    // Copy the PHY settings to the EasyLink PHY variable
    if(useDivRadioSetup)
        memcpy(&EasyLink_cmdPropRadioSetup.divSetup, (rfSetting->RF_uCmdPropRadio.RF_pCmdPropRadioDivSetup), sizeof(rfc_CMD_PROP_RADIO_DIV_SETUP_PA_t));
#else
        memcpy(&EasyLink_cmdPropRadioSetup.divSetup, (rfSetting->RF_uCmdPropRadio.RF_pCmdPropRadioDivSetup), sizeof(rfc_CMD_PROP_RADIO_DIV_SETUP_t));
#endif
    else
        memcpy(&EasyLink_cmdPropRadioSetup.setup, (rfSetting->RF_uCmdPropRadio.RF_pCmdPropRadioSetup), sizeof(rfc_CMD_PROP_RADIO_SETUP_t));
    memcpy(&EasyLink_cmdFs, (rfSetting->RF_pCmdFs), sizeof(rfc_CMD_FS_t));
    memcpy(&EasyLink_RF_prop, (rfSetting->RF_pProp), sizeof(RF_Mode));
    memcpy(&EasyLink_cmdPropRxAdv,(rfSetting->RF_pCmdPropRxAdv), sizeof(rfc_CMD_PROP_RX_ADV_t));
    if(createCmdTxAdvFromTx)
        createTxAdvFromTx(&EasyLink_cmdPropTxAdv, (rfSetting->RF_pCmdPropTx));
    else
        memcpy(&EasyLink_cmdPropTxAdv, (rfSetting->RF_pCmdPropTxAdv), sizeof(rfc_CMD_PROP_TX_ADV_t));
#if !(defined(DeviceFamily_CC26X0R2))
    if (rfModeMultiClient)
        EasyLink_RF_prop.rfMode = RF_MODE_MULTIPLE;
#endif //defined(DeviceFamily_CC26X0R2)
    /* Request access to the radio */
    rfHandle = RF_open(&rfObject, &EasyLink_RF_prop,
            (RF_RadioSetup*)&EasyLink_cmdPropRadioSetup.setup, &rfParams);
    // Setup the Proprietary Rx Advanced Command
    EasyLink_cmdPropRxAdv.status = 0x0000;
    EasyLink_cmdPropRxAdv.pNextOp = 0;
    EasyLink_cmdPropRxAdv.startTime = 0x00000000;
    EasyLink_cmdPropRxAdv.startTrigger.triggerType = 0x0;
    EasyLink_cmdPropRxAdv.startTrigger.bEnaCmd = 0x0;
    EasyLink_cmdPropRxAdv.startTrigger.triggerNo = 0x0;
    EasyLink_cmdPropRxAdv.startTrigger.pastTrig = 0x0;
    EasyLink_cmdPropRxAdv.condition.rule = 0x1;
    EasyLink_cmdPropRxAdv.condition.nSkip = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.bFsOff = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.bRepeatOk = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.bRepeatNok = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.bUseCrc = 0x1;
    EasyLink_cmdPropRxAdv.pktConf.bCrcIncSw = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.endType = 0x0;
    EasyLink_cmdPropRxAdv.pktConf.filterOp = !(EASYLINK_ENABLE_ADDR_FILTERING);
    EasyLink_cmdPropRxAdv.rxConf.bAutoFlushIgnored = 0x0;
    EasyLink_cmdPropRxAdv.rxConf.bAutoFlushCrcErr = 0x0;
    EasyLink_cmdPropRxAdv.rxConf.bIncludeHdr = 0x1;
    EasyLink_cmdPropRxAdv.rxConf.bIncludeCrc = 0x0;
    EasyLink_cmdPropRxAdv.rxConf.bAppendRssi = 0x0;
    EasyLink_cmdPropRxAdv.rxConf.bAppendTimestamp = 0x0;
    EasyLink_cmdPropRxAdv.rxConf.bAppendStatus = 0x0;
    EasyLink_cmdPropRxAdv.syncWord1 = 0;
    EasyLink_cmdPropRxAdv.maxPktLen = EASYLINK_MAX_DATA_LENGTH +
            EASYLINK_MAX_ADDR_SIZE;
    if(useIeeeHeader)
        EasyLink_cmdPropRxAdv.syncWord0 = EASYLINK_IEEE_TRX_SYNC_WORD;
        EasyLink_cmdPropRxAdv.hdrConf.numHdrBits = EASYLINK_IEEE_HDR_NBITS;
        EasyLink_cmdPropRxAdv.lenOffset = EASYLINK_IEEE_LEN_OFFSET;
        // Exclude the header from the CRC calculation
        EasyLink_cmdPropRxAdv.pktConf.bCrcIncHdr = 0U;
    else
        EasyLink_cmdPropRxAdv.syncWord0 = EASYLINK_PROP_TRX_SYNC_WORD;
        EasyLink_cmdPropRxAdv.hdrConf.numHdrBits = EASYLINK_PROP_HDR_NBITS;
        EasyLink_cmdPropRxAdv.lenOffset = EASYLINK_PROP_LEN_OFFSET;
        // Include the header in the CRC calculation - The header (length
        // byte) is considered to be the first byte of the payload
        EasyLink_cmdPropRxAdv.pktConf.bCrcIncHdr = 1U;
    EasyLink_cmdPropRxAdv.hdrConf.numLenBits = EASYLINK_HDR_LEN_NBITS;
    EasyLink_cmdPropRxAdv.hdrConf.lenPos = 0;
    EasyLink_cmdPropRxAdv.addrConf.addrType = 0;
    EasyLink_cmdPropRxAdv.addrConf.addrSize = addrSize;
    EasyLink_cmdPropRxAdv.addrConf.addrPos = 0;
    EasyLink_cmdPropRxAdv.addrConf.numAddr = EASYLINK_NUM_ADDR_FILTER;
    EasyLink_cmdPropRxAdv.endTrigger.triggerType = 0x1;
    EasyLink_cmdPropRxAdv.endTrigger.bEnaCmd = 0x0;
    EasyLink_cmdPropRxAdv.endTrigger.triggerNo = 0x0;
    EasyLink_cmdPropRxAdv.endTrigger.pastTrig = 0x0;
    EasyLink_cmdPropRxAdv.endTime = 0x00000000;
    EasyLink_cmdPropRxAdv.pAddr = addrFilterTable;
    EasyLink_cmdPropRxAdv.pQueue = &dataQueue;
    EasyLink_cmdPropRxAdv.pOutput = (uint8_t*)&rxStatistics;
    //Set the frequency
    RF_runCmd(rfHandle, (RF_Op*)&EasyLink_cmdFs, RF_PriorityNormal, 0, //asyncCmdCallback,
    //Create a semaphore for blocking commands
    Semaphore_Params semParams;
    Error_Block eb;
    // init params
    Semaphore_Params_init(&semParams);
    Error_init(&eb);
    // create semaphore instance if not already created
    if (busyMutex == NULL)
        busyMutex = Semaphore_create(0, &semParams, &eb);
            return EasyLink_Status_Mem_Error;
    else
        //already configured and taken busyMutex, so release it
    configured = 1;
    return EasyLink_Status_Success;
EasyLink_Status EasyLink_setFrequency(uint32_t ui32Frequency)
    uint16_t centerFreq, fractFreq;
    if ( (!configured) || suspended)
    /* Set the frequency */
    centerFreq = (uint16_t)(ui32Frequency / 1000000);
    fractFreq  = (uint16_t) (((uint64_t)ui32Frequency -
                             ((uint64_t)centerFreq * 1000000)) *
                             65536 / 1000000);
    EasyLink_cmdFs.frequency = centerFreq;
    EasyLink_cmdFs.fractFreq = fractFreq;
#if (!defined(DeviceFamily_CC26X0R2) && !defined(DeviceFamily_CC26X0))
    /* If the command type is CMD_PROP_RADIO_DIV_SETUP then set the center frequency
     * to the same band as the FS command
    if((EasyLink_cmdPropRadioSetup.divSetup.commandNo == CMD_PROP_RADIO_DIV_SETUP) &&
       (EasyLink_cmdPropRadioSetup.divSetup.centerFreq != centerFreq))
        EasyLink_cmdPropRadioSetup.divSetup.centerFreq = centerFreq;
        /* Run the Setup Command */
        (void)RF_runCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropRadioSetup,
                  RF_PriorityNormal, 0, EASYLINK_RF_EVENT_MASK);
#endif
    /* Run command */
    RF_EventMask result = RF_runCmd(rfHandle, (RF_Op*)&EasyLink_cmdFs,
    if((result & RF_EventLastCmdDone) && (EasyLink_cmdFs.status == DONE_OK))
    return status;
uint32_t EasyLink_getFrequency(void)
    uint32_t freq_khz;
    freq_khz = EasyLink_cmdFs.frequency * 1000000;
    freq_khz += ((((uint64_t)EasyLink_cmdFs.fractFreq * 1000000)) / 65536);
    return freq_khz;
EasyLink_Status EasyLink_setRfPower(int8_t i8TxPowerDbm)
#if (defined Board_CC1310_LAUNCHXL)    || (defined Board_CC1350_LAUNCHXL)     || \
    (defined Board_CC1350STK)          || (defined Board_CC1350_LAUNCHXL_433) || \
    (defined Board_CC1312R1_LAUNCHXL)  || (defined Board_CC1352R1_LAUNCHXL)   || \
    (defined Board_CC1352P_4_LAUNCHXL) || (defined Board_CC2640R2_LAUNCHXL)
    RF_TxPowerTable_Entry *rfPowerTable = NULL;
    RF_TxPowerTable_Value newValue;
    uint8_t rfPowerTableSize = 0;
    newValue = RF_TxPowerTable_findValue((RF_TxPowerTable_Entry *)rfSetting->RF_pTxPowerTable, i8TxPowerDbm);
    if(newValue.rawValue != RF_TxPowerTable_INVALID_VALUE)
        // Found a valid entry
        rfPowerTable = (RF_TxPowerTable_Entry *)rfSetting->RF_pTxPowerTable;
        rfPowerTableSize = rfSetting->RF_txPowerTableSize;
    else
        //Release the busyMutex
        // Desired power is too low to be supported on this device
    //if max power is requested then the CCFG_FORCE_VDDR_HH must be set in
    //the ccfg; this does not apply to 2.4GHz proprietary modes either
#if (CCFG_FORCE_VDDR_HH != 0x1)
    if((newValue.paType == RF_TxPowerTable_DefaultPA) &&
       (i8TxPowerDbm == rfPowerTable[rfPowerTableSize-2].power))
#if !(defined Board_CC2640R2_LAUNCHXL)
        // The desired power level is set to the maximum supported under the
        // default PA settings, but the boost mode (CCFG_FORCE_VDDR_HH) is not
        // turned on
#endif
#else
    // dummy read to avoid build warnings
    if(rfPowerTable[rfPowerTableSize-2].power){}
#endif
    RF_Stat rfStatus = RF_setTxPower(rfHandle, newValue);
    if(rfStatus == RF_StatSuccess)
    else
        status = EasyLink_Status_Config_Error;
#else
    rfc_CMD_SCH_IMM_t immOpCmd = {0};
    rfc_CMD_SET_TX_POWER_t cmdSetPower = {0};
    uint8_t txPowerIdx;
    immOpCmd.commandNo = CMD_SCH_IMM;
    immOpCmd.startTrigger.triggerType = TRIG_NOW;
    immOpCmd.startTrigger.pastTrig = 1;
    immOpCmd.startTime = 0;
    cmdSetPower.commandNo = CMD_SET_TX_POWER;
    if (i8TxPowerDbm < rfPowerTable[0].dbm)
        i8TxPowerDbm = rfPowerTable[0].dbm;
    else if (i8TxPowerDbm > rfPowerTable[rfPowerTableSize-1].dbm )
        i8TxPowerDbm = rfPowerTable[rfPowerTableSize-1].dbm;
    //the ccfg
    if (i8TxPowerDbm == rfPowerTable[rfPowerTableSize-1].dbm)
#endif
    for (txPowerIdx = 0; txPowerIdx < rfPowerTableSize; txPowerIdx++)
        if (i8TxPowerDbm >= rfPowerTable[txPowerIdx].dbm)
            cmdSetPower.txPower = rfPowerTable[txPowerIdx].txPower;
            EasyLink_cmdPropRadioSetup.setup.txPower = rfPowerTable[txPowerIdx].txPower;
    //point the Operational Command to the immediate set power command
    immOpCmd.cmdrVal = (uint32_t) &cmdSetPower;
    // Send command
    RF_CmdHandle cmd = RF_postCmd(rfHandle, (RF_Op*)&immOpCmd,
    RF_EventMask result = RF_pendCmd(rfHandle, cmd, RF_EventLastCmdDone);
    if (result & RF_EventLastCmdDone)
#endif
    return status;
EasyLink_Status EasyLink_getRfPower(int8_t *pi8TxPowerDbm)
    int8_t txPowerDbm = 0xff;
    RF_TxPowerTable_Value currValue = RF_getTxPower(rfHandle);
    if(currValue.rawValue == RF_TxPowerTable_INVALID_VALUE)
        // Value not valid
    else
        txPowerDbm = RF_TxPowerTable_findPowerLevel(rfPowerTable, currValue);
        //if CCFG_FORCE_VDDR_HH is not set max power cannot be achieved; this
        //does not apply to 2.4GHz proprietary modes either
        if((currValue.paType == RF_TxPowerTable_DefaultPA) &&
           (txPowerDbm == rfPowerTable[rfPowerTableSize-2].power))
            txPowerDbm = rfPowerTable[rfPowerTableSize-3].power;
#endif
#else
#endif
#else
    uint8_t txPowerIdx;
        if (rfPowerTable[txPowerIdx].txPower == EasyLink_cmdPropRadioSetup.setup.txPower)
            txPowerDbm = rfPowerTable[txPowerIdx].dbm;
            continue;
    if (txPowerDbm == rfPowerTable[rfPowerTableSize-1].dbm)
        txPowerDbm = rfPowerTable[rfPowerTableSize-2].dbm;
#endif
#endif
    *pi8TxPowerDbm = txPowerDbm;
EasyLink_Status EasyLink_getRssi(int8_t *pi8Rssi)
    *pi8Rssi = RF_getRssi(rfHandle);
EasyLink_Status EasyLink_getAbsTime(uint32_t *pui32AbsTime)
    *pui32AbsTime = RF_getCurrentTime();
EasyLink_Status EasyLink_transmit(EasyLink_TxPacket *txPacket)
    RF_CmdHandle cmdHdl;
    uint32_t cmdTime;
    if (txPacket->len > EASYLINK_MAX_DATA_LENGTH)
    if(useIeeeHeader)
        uint16_t ieeeHdr = EASYLINK_IEEE_HDR_CREATE(EASYLINK_IEEE_HDR_CRC_2BYTE, EASYLINK_IEEE_HDR_WHTNG_EN, (txPacket->len + addrSize + sizeof(ieeeHdr)));
        txBuffer[0] = (uint8_t)(ieeeHdr & 0x00FF);
        txBuffer[1] = (uint8_t)((ieeeHdr & 0xFF00) >> 8);
    else
        txBuffer[0] = txPacket->len + addrSize;
    memcpy(&txBuffer[hdrSize], txPacket->dstAddr, addrSize);
    memcpy(&txBuffer[addrSize + hdrSize], txPacket->payload, txPacket->len);
    //packet length to Tx includes address and length field
    EasyLink_cmdPropTxAdv.pktLen = txPacket->len + addrSize + hdrSize;
    EasyLink_cmdPropTxAdv.pPkt = txBuffer;
    if(EasyLink_params.ui32ModType == EasyLink_Phy_5kbpsSlLr)
        /* calculate the command time:
         * (len + preamble + phy len + address) * 8bits / 5kbps */
        cmdTime = ((EasyLink_cmdPropTxAdv.pktLen + 10 + addrSize) * 8) / 5;
    else //assume 50kbps
         * (len + preamble + syncword + len + address) * 8bits / 50kbps */
        cmdTime = ((EasyLink_cmdPropTxAdv.pktLen + 10 + addrSize) * 8) / 50;
    if (txPacket->absTime != 0)
        EasyLink_cmdPropTxAdv.startTrigger.triggerType = TRIG_ABSTIME;
        EasyLink_cmdPropTxAdv.startTrigger.pastTrig = 1;
        EasyLink_cmdPropTxAdv.startTime = txPacket->absTime;
        schParams_prop.endTime = EasyLink_cmdPropTxAdv.startTime + EasyLink_ms_To_RadioTime(cmdTime);
    else
        EasyLink_cmdPropTxAdv.startTrigger.triggerType = TRIG_NOW;
        EasyLink_cmdPropTxAdv.startTime = 0;
        schParams_prop.endTime = RF_getCurrentTime() + EasyLink_ms_To_RadioTime(cmdTime);
    PIN_setOutputValue(paPinHandle, Board_PALNA_PA,  1);
    // Send packet
        cmdHdl = RF_scheduleCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropTxAdv,
                    &schParams_prop, 0, EASYLINK_RF_EVENT_MASK);
    else
        cmdHdl = RF_postCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropTxAdv,
            RF_PriorityHigh, 0, EASYLINK_RF_EVENT_MASK);
    // Wait for Command to complete
    RF_EventMask result = RF_pendCmd(rfHandle, cmdHdl, EASYLINK_RF_EVENT_MASK);
    return status;
EasyLink_Status EasyLink_transmitAsync(EasyLink_TxPacket *txPacket, EasyLink_TxDoneCb cb)
    uint32_t cmdTime;
    //Check if not configure or already an Async command being performed
    //store application callback
    txCb = cb;
    if(useIeeeHeader)
    else
    else
    // Send packet
        asyncCmdHndl = RF_scheduleCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropTxAdv,
            &schParams_prop, txDoneCallback, EASYLINK_RF_EVENT_MASK);
    else
        asyncCmdHndl = RF_postCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropTxAdv,
            RF_PriorityHigh, txDoneCallback, EASYLINK_RF_EVENT_MASK);
    //busyMutex will be released by the callback
    return status;
EasyLink_Status EasyLink_transmitCcaAsync(EasyLink_TxPacket *txPacket, EasyLink_TxDoneCb cb)
    uint32_t cmdTime;
    //Check if not configure or already an Async command being performed, or
    //if a random number generator function is not provided
    if ( (!configured) || suspended || (!getRN))
    txCb = cb;
    if(useIeeeHeader)
    else
    // Set the Carrier Sense command attributes
    // Chain the TX command to run after the CS command
    EasyLink_cmdPropCs.pNextOp        = (rfc_radioOp_t *)&EasyLink_cmdPropTxAdv;
        EasyLink_cmdPropCs.startTrigger.triggerType = TRIG_ABSTIME;
        EasyLink_cmdPropCs.startTrigger.pastTrig = 1;
        EasyLink_cmdPropCs.startTime = txPacket->absTime;
        schParams_prop.endTime = EasyLink_cmdPropCs.startTime + EasyLink_ms_To_RadioTime(cmdTime);
    else
        EasyLink_cmdPropCs.startTime = 0;
    // Check for a clear channel (CCA) before sending a packet
    else
        asyncCmdHndl = RF_postCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropCs,
    return status;
EasyLink_Status EasyLink_receive(EasyLink_RxPacket *rxPacket)
    RF_EventMask result;
    RF_CmdHandle rx_cmd;
    //data entry rx buffer includes hdr (len-1Byte), addr (max 8Bytes) and data
    pDataEntry->length = 1 + EASYLINK_MAX_ADDR_SIZE + EASYLINK_MAX_DATA_LENGTH;
    pDataEntry->status = 0;
    dataQueue.pCurrEntry = (uint8_t*)pDataEntry;
    dataQueue.pLastEntry = NULL;
    EasyLink_cmdPropRxAdv.pQueue = &dataQueue;               /* Set the Data Entity queue for received data */
    if (rxPacket->absTime != 0)
        EasyLink_cmdPropRxAdv.startTrigger.triggerType = TRIG_ABSTIME;
        EasyLink_cmdPropRxAdv.startTrigger.pastTrig = 1;
        EasyLink_cmdPropRxAdv.startTime = rxPacket->absTime;
    else
        EasyLink_cmdPropRxAdv.startTrigger.triggerType = TRIG_NOW;
        EasyLink_cmdPropRxAdv.startTime = 0;
    if (rxPacket->rxTimeout != 0)
        EasyLink_cmdPropRxAdv.endTrigger.triggerType = TRIG_ABSTIME;
        EasyLink_cmdPropRxAdv.endTrigger.pastTrig = 1;
        EasyLink_cmdPropRxAdv.endTime = RF_getCurrentTime() + rxPacket->rxTimeout;
    else
        EasyLink_cmdPropRxAdv.endTrigger.triggerType = TRIG_NEVER;
        EasyLink_cmdPropRxAdv.endTime = 0;
    //Clear the Rx statistics structure
    memset(&rxStatistics, 0, sizeof(rfc_propRxOutput_t));
        /* assume high priority */
        schParams_prop.endTime = EasyLink_cmdPropRxAdv.endTime;
        rx_cmd = RF_scheduleCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropRxAdv,
    else
        rx_cmd = RF_postCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropRxAdv,
    /* Wait for Command to complete */
    result = RF_pendCmd(rfHandle, rx_cmd, RF_EventLastCmdDone);
            //check Rx Statistics
                //copy length from pDataEntry (- addrSize)
                rxPacket->len = *(uint8_t*)(&pDataEntry->data) - addrSize;
                if(useIeeeHeader)
                else
                //copy address
                memcpy(rxPacket->dstAddr, (&pDataEntry->data + hdrSize), addrSize);
                //copy payload
                memcpy(&rxPacket->payload, (&pDataEntry->data + hdrSize + addrSize), (rxPacket->len));
                rxPacket->rssi = rxStatistics.lastRssi;
                rxPacket->absTime = rxStatistics.timeStamp;
            else
        else
    return status;
EasyLink_Status EasyLink_receiveAsync(EasyLink_ReceiveCb cb, uint32_t absTime)
    //Check if not configure of already an Async command being performed
    rxCb = cb;
    if (absTime != 0)
        EasyLink_cmdPropRxAdv.startTime = absTime;
    else
    if (asyncRxTimeOut != 0)
        EasyLink_cmdPropRxAdv.endTime = RF_getCurrentTime() + asyncRxTimeOut;
    else
        asyncCmdHndl = RF_scheduleCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropRxAdv,
                    &schParams_prop, rxDoneCallback, EASYLINK_RF_EVENT_MASK);
    else
        asyncCmdHndl = RF_postCmd(rfHandle, (RF_Op*)&EasyLink_cmdPropRxAdv,
            RF_PriorityHigh, rxDoneCallback, EASYLINK_RF_EVENT_MASK);
    else
        //Callback will not be called, release the busyMutex
    //busyMutex will be released in callback
    return status;
EasyLink_Status EasyLink_abort(void)
    //check an Async command is running, if not return success
    if (!EasyLink_CmdHandle_isValid(asyncCmdHndl))
        return EasyLink_Status_Aborted;
    //force abort (gracefull param set to 0)
    if (RF_cancelCmd(rfHandle, asyncCmdHndl, 0) == RF_StatSuccess)
        /* If command is cancelled immediately, callback may have set the cmd handle to invalid.
         * In that case, no need to pend.
            RF_EventMask result = RF_pendCmd(rfHandle, asyncCmdHndl, (RF_EventLastCmdDone |
                    RF_EventCmdAborted | RF_EventCmdCancelled | RF_EventCmdStopped));
        else
            /* Command already cancelled */
    else
    return status;
EasyLink_Status EasyLink_enableRxAddrFilter(uint8_t* pui8AddrFilterTable, uint8_t ui8AddrSize, uint8_t ui8NumAddrs)
    EasyLink_Status status = EasyLink_Status_Param_Error;
    if (isAddrSizeValid(ui8AddrSize) == false)
    if ( Semaphore_pend(busyMutex, 0) == false )
    if ( (pui8AddrFilterTable != NULL) &&
         (ui8AddrSize != 0) && (ui8NumAddrs != 0) &&
         (ui8AddrSize == addrSize) &&
         (ui8NumAddrs <= EASYLINK_MAX_ADDR_FILTERS) )
        memcpy(addrFilterTable, pui8AddrFilterTable, ui8AddrSize * ui8NumAddrs);
        EasyLink_cmdPropRxAdv.addrConf.addrSize = ui8AddrSize;
        EasyLink_cmdPropRxAdv.addrConf.numAddr = ui8NumAddrs;
        EasyLink_cmdPropRxAdv.pktConf.filterOp = 0;
    else if (pui8AddrFilterTable == NULL)
        //disable filter
        EasyLink_cmdPropRxAdv.pktConf.filterOp = 1;
    return status;
EasyLink_Status EasyLink_setCtrl(EasyLink_CtrlOption Ctrl, uint32_t ui32Value)
    switch(Ctrl)
        case EasyLink_Ctrl_AddSize:
            if (isAddrSizeValid(ui32Value))
                addrSize = (uint8_t) ui32Value;
            break;
        case EasyLink_Ctrl_Idle_TimeOut:
            if(configured)
                // Client has already been configured, need to modify
                // the client configuration directly
                RF_control(rfHandle, RF_CTRL_SET_INACTIVITY_TIMEOUT, &ui32Value);
            else
                // RF_open() in EasyLink_init() has not been called yet so it
                // is safe to alter the rfParams
                inactivityTimeout = ui32Value;
            break;
        case EasyLink_Ctrl_MultiClient_Mode:
            rfModeMultiClient = (bool) ui32Value;
            break;
        case EasyLink_Ctrl_AsyncRx_TimeOut:
            asyncRxTimeOut = ui32Value;
            break;
        case EasyLink_Ctrl_Test_Tone:
            status = enableTestMode(EasyLink_Ctrl_Test_Tone);
            break;
        case EasyLink_Ctrl_Test_Signal:
            status = enableTestMode(EasyLink_Ctrl_Test_Signal);
            break;
        case EasyLink_Ctrl_Rx_Test_Tone:
            status = enableTestMode(EasyLink_Ctrl_Rx_Test_Tone);
            break;
    return status;
EasyLink_Status EasyLink_getCtrl(EasyLink_CtrlOption Ctrl, uint32_t* pui32Value)
    switch(Ctrl)
            *pui32Value = addrSize;
            break;
            *pui32Value = rfParams.nInactivityTimeout;
            break;
            *pui32Value = (uint32_t) rfModeMultiClient;
            break;
            *pui32Value = asyncRxTimeOut;
            break;
            *pui32Value = 0;
            break;
    return status;
EasyLink_Status EasyLink_getIeeeAddr(uint8_t *ieeeAddr)
    if (ieeeAddr != NULL)
        int i;
        //Reading from primary IEEE location...
        uint8_t *location = (uint8_t *)EASYLINK_PRIMARY_IEEE_ADDR_LOCATION;
         * ...unless we can find a byte != 0xFF in secondary
         * Intentionally checking all 8 bytes here instead of len, because we
         * are checking validity of the entire IEEE address irrespective of the
         * actual number of bytes the caller wants to copy over.
        for (i = 0; i < 8; i++) {
            if (((uint8_t *)EASYLINK_SECONDARY_IEEE_ADDR_LOCATION)[i] != 0xFF) {
                //A byte in the secondary location is not 0xFF. Use the
                //secondary
                location = (uint8_t *)EASYLINK_SECONDARY_IEEE_ADDR_LOCATION;
                break;
        //inverting byte order
            ieeeAddr[i] = location[8 - 1 - i];
    return status;
