请问回调函数的内容只是翻转了LED电平而已啊,没看到用清中断啊?
An array of @ref GPIO_CallbackFxn elements that is used to store * callback function pointers for GPIO pins configured with interrupts. * The indexes for these array elements correspond to the pins defined * in the GPIO_pinConfig array. These function pointers can be defined * statically by referencing the callback function name in the array * element, or dynamically, by setting the array element to NULL and using * GPIO_setCallback() at runtime to plug the callback entry. * Pins not used for interrupts can be omitted from the callback array to * reduce memory usage (if they are placed at the end of GPIO_pinConfig * array). The callback function syntax should match the following: * @code * void (*GPIO_CallbackFxn)(uint_least8_t index); * @endcode * The index parameter is the same index that was passed to * GPIO_setCallback(). This allows the same callback function to be used * for multiple GPIO interrupts, by using the index to identify the GPIO * that caused the interrupt. * Keep in mind that the callback functions will be called in the context of * an interrupt service routine and should be designed accordingly. When an * interrupt is triggered, the interrupt status of all (interrupt enabled) pins * on a port will be read, cleared, and the respective callbacks will be * executed. Callbacks will be called in order from least significant bit to * most significant bit. * Below is an MSP432 device specific example of the GPIO_CallbackFxn array: * @code * // * // Array of callback function pointers * // NOTE: The order of the pin configurations must coincide with what was * // defined in MSP_EXP432P401R.h * // NOTE: Pins not used for interrupts can be omitted from callbacks array * // to reduce memory usage (if placed at end of gpioPinConfigs * // array). * // * GPIO_CallbackFxn gpioCallbackFunctions[] = { * // MSP_EXP432P401R_GPIO_S1 * NULL, * // MSP_EXP432P401R_GPIO_S2 * NULL * }; * @endcode *
看下上面的说明:
