用cc2540 如何接受notification or indication类型的数据?
根据蓝牙协议的规定, CC2540作为slave的话只能发送notification 或者indication.
除非cc2540作为master, 请参考simpleBLECentral的代码, 其中simpleBLECentral.c文件中,
simpleBLECentralProcessGATTMsg()函数里面,
else if ( pMsg->method == ATT_HANDLE_VALUE_IND )
// received notification, display the value
uint8 receivedNotiHandl = pMsg->msg.handleValueInd.handle;
if( receivedNotiHandl == tempCharHdl )
tempCharVal = pMsg->msg.handleValueInd.value[0];
LCD_WRITE_STRING_VALUE( "Temp value:", tempCharVal, 10, HAL_LCD_LINE_1 );
else if ( receivedNotiHandl == humidCharHdl )
humidCharVal = pMsg->msg.handleValueInd.value[0];
LCD_WRITE_STRING_VALUE( "Humid value:", humidCharVal, 10, HAL_LCD_LINE_1 );
ATT_HandleValueCfm( pMsg->connHandle );
