CC2540 timer3 timer4 的PWM怎么用?
你好
timer.h内的API貌似不能用,请问 timer3 timer4 的PWM怎么用?有没有例程参考?
  • www.ti.com/litv/zip/swrc257
    例子中有T4的PWM基本例子。现在timer都留给客户自己实现了,如果需要可以google下以前版本zigbee协议栈,有借鉴作用
    1. /**************************************************************************************************
    2.   Filename:       hal_timer.c
    3.   Revised:        $Date: 2007-11-01 08:44:53 -0700 (Thu, 01 Nov 2007) $
    4.   Revision:       $Revision: 15821 $
    5.
    6.   Description:   This file contains the interface to the Timer Service.
    7.
    8.
    9.   Copyright 2006-2007 Texas Instruments Incorporated. All rights reserved.
    10.
    11.   IMPORTANT: Your use of this Software is limited to those specific rights
    12.   granted under the terms of a software license agreement between the user
    13.   who downloaded the software, his/her employer (which must be your employer)
    14.   and Texas Instruments Incorporated (the "License").  You may not use this
    15.   Software unless you agree to abide by the terms of the License. The License
    16.   limits your use, and you acknowledge, that the Software may not be modified,
    17.   copied or distributed unless embedded on a Texas Instruments microcontroller
    18.   or used solely and exclusively in conjunction with a Texas Instruments radio
    19.   frequency transceiver, which is integrated into your product.  Other than for
    20.   the foregoing purpose, you may not use, reproduce, copy, prepare derivative
    21.   works of, modify, distribute, perform, display or sell this Software and/or
    22.   its documentation for any purpose.
    23.
    24.   YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
    25.   PROVIDED 揂S IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
    26.   INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
    27.   NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
    28.   TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
    29.   NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
    30.   LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
    31.   INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
    32.   OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
    33.   OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
    34.   (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
    35.
    36.   Should you have any questions regarding your right to use this Software,
    37.   contact Texas Instruments Incorporated at www.TI.com.
    38. **************************************************************************************************/
    39. /*********************************************************************
    40.  NOTE: The following mapping is done between the logical timer
    41.        names defined in HAL_TIMER.H and the physical HW timer.
    42.
    43.        HAL_TIMER_0 --> HW Timer 3  (8-bits)
    44.        HAL_TIMER_2 --> HW Timer 4  (8-bits)
    45.        HAL_TIMER_3 --> HW Timer 1  (16-bits)
    46.
    47.  NOTE: The timer code assumes only one channel, CHANNEL 0, is used
    48.        for each timer.  There is currently no support for other
    49.        channels.
    50.
    51.  NOTE: Only Output Compare Mode is supported.  There is no provision
    52.        to support Input Capture Mode.
    53.
    54.  NOTE: There is no support to map the output of the timers to a
    55.        physical I/O pin
    56.
    57. *********************************************************************/
    58. /*********************************************************************
    59.  * INCLUDES
    60.  */
    61. #include  "hal_mcu.h"
    62. #include  "hal_defs.h"
    63. #include  "hal_types.h"
    64. #include  "hal_timer.h"
    65.
    66. /*********************************************************************
    67.  * MACROS
    68.  */
    69.
    70. /*********************************************************************
    71.  * CONSTANTS
    72.  */
    73. #define HW_TIMER_1        0x00
    74. #define HW_TIMER_3        0x01
    75. #define HW_TIMER_4        0x02
    76. #define HW_TIMER_INVALID  0x03
    77. #define HW_TIMER_MAX      0x03
    78.
    79. #define IEN1_T1IE     0x02    /* Timer1 Interrupt Enable */
    80. #define IEN1_T3IE     0x08    /* Timer3 Interrupt Enable */
    81. #define IEN1_T4IE     0x10    /* Timer4 Interrupt Enable */
    82.
    83. #define T1CTL_CH2IF   0x80
    84. #define T1CTL_CH1IF   0x40
    85. #define T1CTL_CH0IF   0x20
    86. #define T1CTL_OVFIF   0x10
    87.
    88. #define TIMIF_T1OVFIM 0x40
    89. #define TIMIF_T4CH1IF 0x20
    90. #define TIMIF_T4CH0IF 0x10
    91. #define TIMIF_T4OVFIF 0x08
    92. #define TIMIF_T3CH1IF 0x04
    93. #define TIMIF_T3CH0IF 0x02
    94. #define TIMIF_T3OVFIF 0x01
    95.
    96. #define T34CTL_OVFIM  0x80
    97.
    98. #define T134CCTL_IM         0x40    /* Interrupt Mask */
    99. #define T134CCTL_CMP_BITS   0x38    /* Bits[5:3] == CMP[2:0] */
    100. #define T134CCTL_MODE       0x04    /* Capture(0)/Compare(1) mode */
    101. #define T134CCTL_CAP_BITS   0x03    /* Bits[1:0] == CAP[1:0] */
    102.
    103. #define T134CCTL_CMP_OC     0x18    /* Set output on compare, clear at 0 */
    104. #define T134CCTL_CAP_RE     0x01    /* Set input capture on rising edge */
    105.
    106. /* Timer clock pre-scaler definitions for 16bit timer1 */
    107. #define HAL_TIMER1_16_TC_DIV1     0x00  /* No clock pre-scaling */
    108. #define HAL_TIMER1_16_TC_DIV8     0x04  /* Clock pre-scaled by 8 */
    109. #define HAL_TIMER1_16_TC_DIV32    0x08  /* Clock pre-scaled by 32 */
    110. #define HAL_TIMER1_16_TC_DIV128   0x0c  /* Clock pre-scaled by 128 */
    111. #define HAL_TIMER1_16_TC_BITS     0x0c  /* Bits 3:2 */
    112.
    113. /* Timer clock pre-scaler definitions for 8bit timer3 and timer4 */
    114. #define HAL_TIMER34_8_TC_DIV1     0x00  /* No clock pre-scaling */
    115. #define HAL_TIMER34_8_TC_DIV2     0x20  /* Clock pre-scaled by 2 */
    116. #define HAL_TIMER34_8_TC_DIV4     0x40  /* Clock pre-scaled by 4 */
    117. #define HAL_TIMER34_8_TC_DIV8     0x60  /* Clock pre-scaled by 8 */
    118. #define HAL_TIMER34_8_TC_DIV16    0x80  /* Clock pre-scaled by 16 */
    119. #define HAL_TIMER34_8_TC_DIV32    0xA0  /* Clock pre-scaled by 32 */
    120. #define HAL_TIMER34_8_TC_DIV64    0xC0  /* Clock pre-scaled by 64 */
    121. #define HAL_TIMER34_8_TC_DIV128   0xE0  /* Clock pre-scaled by 128 */
    122. #define HAL_TIMER34_8_TC_BITS     0xE0  /* Bits 7:5 */
    123.
    124. /* Operation Mode definitions */
    125. #define HAL_TIMER1_OPMODE_STOP      0x00  /* Free Running Mode, Count from 0 to Max */
    126. #define HAL_TIMER1_OPMODE_FREERUN   0x01  /* Free Running Mode, Count from 0 to Max */
    127. #define HAL_TIMER1_OPMODE_MODULO    0x02  /* Modulo Mode, Count from 0 to CompareValue */
    128. #define HAL_TIMER1_OPMODE_BITS      0x03  /* Bits 1:0 */
    129.
    130. #define HAL_TIMER34_START           0x10  /* Timer3 and Timer4 have separate Start bit */
    131. #define HAL_TIMER34_OPMODE_FREERUN  0x00  /* Free Running Mode, Count from 0 to Max */
    132. #define HAL_TIMER34_OPMODE_MODULO   0x02  /* Modulo Mode, Count from 0 to CompareValue */
    133. #define HAL_TIMER34_OPMODE_BITS     0x03  /* Bits 1:0 */
    134.
    135. #define HAL_TIMER_MODE_STOP         0x03
    136.
    137. /* Prescale settings */
    138. #define HAL_TIMER1_16_PRESCALE      HAL_TIMER1_16_TC_DIV128
    139. #define HAL_TIMER1_16_PRESCALE_VAL  128
    140. #define HAL_TIMER3_8_PRESCALE       HAL_TIMER34_8_TC_DIV128
    141. #define HAL_TIMER3_8_PRESCALE_VAL   128
    142. #define HAL_TIMER4_8_PRESCALE       HAL_TIMER34_8_TC_DIV128
    143. #define HAL_TIMER4_8_PRESCALE_VAL   128
    144.
    145. /* Clock settings */
    146. #define HAL_TIMER_16MHZ           16
    147. #define HAL_TIMER_32MHZ           32
    148.
    149. /* Default all timers to use channel 0 */
    150. #define TCHN_T1CCTL   &(X_T1CCTL0)
    151. #define TCHN_T1CCL    &(X_T1CC0L)
    152. #define TCHN_T1CCH    &(X_T1CC0H)
    153. #define TCNH_T1OVF    &(X_TIMIF)
    154. #define TCHN_T1OVFBIT TIMIF_T1OVFIM
    155. #define TCHN_T1INTBIT IEN1_T1IE
    156.
    157. #define TCHN_T3CCTL   &(X_T3CCTL0)
    158. #define TCHN_T3CCL    &(X_T3CC0)
    159. #define TCHN_T3CCH    &(X_T3CC0)
    160. #define TCNH_T3OVF    &(X_T3CTL)
    161. #define TCHN_T3OVFBIT T34CTL_OVFIM
    162. #define TCHN_T3INTBIT IEN1_T3IE
    163.
    164. #define TCHN_T4CCTL   &(X_T4CCTL0)
    165. #define TCHN_T4CCL    &(X_T4CC0)
    166. #define TCHN_T4CCH    &(X_T4CC0)
    167. #define TCNH_T4OVF    &(X_T4CTL)
    168. #define TCHN_T4OVFBIT T34CTL_OVFIM
    169. #define TCHN_T4INTBIT IEN1_T4IE
    170.
    171. /*********************************************************************
    172.  * TYPEDEFS
    173.  */
    174. typedef struct
    175. {
    176.   bool configured;
    177.   bool intEnable;
    178.   uint8 opMode;
    179.   uint8 channel;
    180.   uint8 channelMode;
    181.   uint8 prescale;
    182.   uint8 prescaleVal;
    183.   uint8 clock;
    184.   halTimerCBack_t callBackFunc;
    185. } halTimerSettings_t;
    186.
    187. typedef struct
    188. {
    189.   uint8 volatile XDATA *TxCCTL;
    190.   uint8 volatile XDATA *TxCCH;
    191.   uint8 volatile XDATA *TxCCL;
    192.   uint8 volatile XDATA *TxOVF;
    193.   uint8 ovfbit;
    194.   uint8 intbit;
    195. } halTimerChannel_t;
    196.
    197. /*********************************************************************
    198.  * GLOBAL VARIABLES
    199.  */
    200. static halTimerSettings_t halTimerRecord[HW_TIMER_MAX];
    201. static halTimerChannel_t  halTimerChannel[HW_TIMER_MAX];
    202.
    203. /*********************************************************************
    204.  * FUNCTIONS - External
    205.  */
    206.
    207. /*********************************************************************
    208.  * FUNCTIONS - Local
    209.  */
    210. uint8 halTimerSetCount (uint8 cc2430id, uint32 timePerTick);
    211. uint8 halTimerSetPrescale (uint8 cc2430id, uint8 prescale);
    212. uint8 halTimerSetOpMode (uint8 cc2430id, uint8 opMode);
    213. uint8 halTimerSetChannelMode (uint8 cc2430id, uint8 channelMode);
    214. void halTimerSendCallBack (uint8 timerId, uint8 channel, uint8 channelMode);
    215. uint8 halTimerRemap (uint8 timerId);
    216. void halProcessTimer1 (void);
    217. void halProcessTimer3 (void);
    218. void halProcessTimer4 (void);
    219.
    220.
    221. /*********************************************************************
    222.  * FUNCTIONS - API
    223.  */
    224.
    225. /*********************************************************************
    226.  * @fn      HalTimerInit
    227.  *
    228.  * @brief   Initialize Timer Service
    229.  *
    230.  * @param   None
    231.  *
    232.  * @return  None
    233.  */
    234. void HalTimerInit (void)
    235. {
    236.   T1CCTL0 = 0;    /* Make sure interrupts are disabled */
    237.   T1CCTL1 = 0;    /* Make sure interrupts are disabled */
    238.   T1CCTL2 = 0;    /* Make sure interrupts are disabled */
    239.   T3CCTL0 = 0;    /* Make sure interrupts are disabled */
    240.   T3CCTL1 = 0;    /* Make sure interrupts are disabled */
    241.   T4CCTL0 = 0;    /* Make sure interrupts are disabled */
    242.   T4CCTL1 = 0;    /* Make sure interrupts are disabled */
    243.
    244.   /* Setup prescale & clock for timer0 */
    245.   halTimerRecord[HW_TIMER_1].prescale    = HAL_TIMER1_16_PRESCALE;
    246.   halTimerRecord[HW_TIMER_1].clock       = HAL_TIMER_32MHZ;
    247.   halTimerRecord[HW_TIMER_1].prescaleVal = HAL_TIMER1_16_PRESCALE_VAL;
    248.
    249.   /* Setup prescale & clock for timer2 */
    250.   halTimerRecord[HW_TIMER_3].prescale    = HAL_TIMER3_8_PRESCALE;
    251.   halTimerRecord[HW_TIMER_3].clock       = HAL_TIMER_32MHZ;
    252.   halTimerRecord[HW_TIMER_3].prescaleVal = HAL_TIMER3_8_PRESCALE_VAL;
    253.
    254.   /* Setup prescale & clock for timer3 */
    255.   halTimerRecord[HW_TIMER_4].prescale    = HAL_TIMER4_8_PRESCALE;
    256.   halTimerRecord[HW_TIMER_4].clock       = HAL_TIMER_32MHZ;
    257.   halTimerRecord[HW_TIMER_4].prescaleVal = HAL_TIMER4_8_PRESCALE_VAL;
    258.
    259.   /* Setup Timer1 Channel structure */
    260.   halTimerChannel[HW_TIMER_1].TxCCTL =  TCHN_T1CCTL;
    261.   halTimerChannel[HW_TIMER_1].TxCCL =   TCHN_T1CCL;
    262.   halTimerChannel[HW_TIMER_1].TxCCH =   TCHN_T1CCH;
    263.   halTimerChannel[HW_TIMER_1].TxOVF =   TCNH_T1OVF;
    264.   halTimerChannel[HW_TIMER_1].ovfbit =  TCHN_T1OVFBIT;
    265.   halTimerChannel[HW_TIMER_1].intbit =  TCHN_T1INTBIT;
    266.
    267.   /* Setup Timer3 Channel structure */
    268.   halTimerChannel[HW_TIMER_3].TxCCTL =  TCHN_T3CCTL;
    269.   halTimerChannel[HW_TIMER_3].TxCCL =   TCHN_T3CCL;
    270.   halTimerChannel[HW_TIMER_3].TxCCH =   TCHN_T3CCH;
    271.   halTimerChannel[HW_TIMER_3].TxOVF =   TCNH_T3OVF;
    272.   halTimerChannel[HW_TIMER_3].ovfbit =  TCHN_T3OVFBIT;
    273.   halTimerChannel[HW_TIMER_3].intbit =  TCHN_T3INTBIT;
    274.
    275.   /* Setup Timer4 Channel structure */
    276.   halTimerChannel[HW_TIMER_4].TxCCTL =  TCHN_T4CCTL;
    277.   halTimerChannel[HW_TIMER_4].TxCCL =   TCHN_T4CCL;
    278.   halTimerChannel[HW_TIMER_4].TxCCH =   TCHN_T4CCH;
    279.   halTimerChannel[HW_TIMER_4].TxOVF =   TCNH_T4OVF;
    280.   halTimerChannel[HW_TIMER_4].ovfbit =  TCHN_T4OVFBIT;
    281.   halTimerChannel[HW_TIMER_4].intbit =  TCHN_T4INTBIT;
    282. }
    283.
    284. /***************************************************************************************************
    285.  * @fn      HalTimerConfig
    286.  *
    287.  * @brief   Configure the Timer Serivce
    288.  *
    289.  * @param   timerId - Id of the timer
    290.  *          opMode  - Operation mode
    291.  *          channel - Channel where the counter operates on
    292.  *          channelMode - Mode of that channel
    293.  *          prescale - Prescale of the clock
    294.  *          cBack - Pointer to the callback function
    295.  *
    296.  * @return  Status of the configuration
    297.  ***************************************************************************************************/
    298. uint8 HalTimerConfig (uint8 timerId, uint8 opMode, uint8 channel, uint8 channelMode,
    299.                       bool intEnable, halTimerCBack_t cBack)
    300. {
    301.   uint8 hwtimerid;
    302.
    303.   hwtimerid = halTimerRemap (timerId);
    304.
    305.   if ((opMode & HAL_TIMER_MODE_MASK) && (timerId < HAL_TIMER_MAX) &&
    306.       (channelMode & HAL_TIMER_CHANNEL_MASK) && (channel & HAL_TIMER_CHANNEL_MASK))
    307.   {
    308.     halTimerRecord[hwtimerid].configured    = TRUE;
    309.     halTimerRecord[hwtimerid].opMode        = opMode;
    310.     halTimerRecord[hwtimerid].channel       = channel;
    311.     halTimerRecord[hwtimerid].channelMode   = channelMode;
    312.     halTimerRecord[hwtimerid].intEnable     = intEnable;
    313.     halTimerRecord[hwtimerid].callBackFunc  = cBack;
    314.   }
    315.   else
    316.   {
    317.     return HAL_TIMER_PARAMS_ERROR;
    318.   }
    319.   return HAL_TIMER_OK;
    320. }
    321.
    322.
    323. /***************************************************************************************************
    324.  * @fn      HalTimerStart
    325.  *
    326.  * @brief   Start the Timer Service
    327.  *
    328.  * @param   timerId      - ID of the timer
    329.  *          timerPerTick - number of micro sec per tick, (ticks x prescale) / clock = usec/tick
    330.  *
    331.  * @return  Status - OK or Not OK
    332.  ***************************************************************************************************/
    333. uint8 HalTimerStart (uint8 timerId, uint32 timePerTick)
    334. {
    335.   uint8 hwtimerid;
    336.
    337.   hwtimerid = halTimerRemap (timerId);
    338.
    339.   if (halTimerRecord[hwtimerid].configured)
    340.   {
    341.     halTimerSetCount (hwtimerid, timePerTick);
    342.     halTimerSetPrescale (hwtimerid, halTimerRecord[hwtimerid].prescale);
    343.     halTimerSetOpMode (hwtimerid, halTimerRecord[hwtimerid].opMode);
    344.     halTimerSetChannelMode (hwtimerid, halTimerRecord[hwtimerid].channelMode);
    345.
    346.     if (hwtimerid == HW_TIMER_3)
    347.     {
    348.       T3CTL |= HAL_TIMER34_START;
    349.     }
    350.     if (hwtimerid == HW_TIMER_4)
    351.     {
    352.       T4CTL |= HAL_TIMER34_START;
    353.     }
    354.     HalTimerInterruptEnable (hwtimerid, halTimerRecord[hwtimerid].channelMode,
    355.                              halTimerRecord[hwtimerid].intEnable);
    356.   }
    357.   else
    358.   {
    359.     return HAL_TIMER_NOT_CONFIGURED;
    360.   }
    361.   return HAL_TIMER_OK;
    362. }
    363.
    364. /***************************************************************************************************
    365.  * @fn      HalTimerTick
    366.  *
    367.  * @brief   Check the counter for expired counter.
    368.  *
    369.  * @param   None
    370.  *
    371.  * @return  None
    372.  ***************************************************************************************************/
    373. void HalTimerTick (void)
    374. {
    375.   if (!halTimerRecord[HW_TIMER_1].intEnable)
    376.   {
    377.     halProcessTimer1 ();
    378.   }
    379.
    380.   if (!halTimerRecord[HW_TIMER_3].intEnable)
    381.   {
    382.     halProcessTimer3 ();
    383.   }
    384.
    385.   if (!halTimerRecord[HW_TIMER_4].intEnable)
    386.   {
    387.     halProcessTimer4 ();
    388.   }
    389. }
    390.
    391. /***************************************************************************************************
    392.  * @fn      HalTimerStop
    393.  *
    394.  * @brief   Stop the Timer Service
    395.  *
    396.  * @param   timerId - ID of the timer
    397.  *
    398.  * @return  Status - OK or Not OK
    399.  ***************************************************************************************************/
    400. uint8 HalTimerStop (uint8 timerId)
    401. {
    402.   uint8 hwtimerid;
    403.
    404.   hwtimerid = halTimerRemap (timerId);
    405.
    406.   switch (hwtimerid)
    407.   {
    408.     case HW_TIMER_1:
    409.       halTimerSetOpMode(HW_TIMER_1, HAL_TIMER_MODE_STOP);
    410.       break;
    411.     case HW_TIMER_3:
    412.       T3CTL &= ~(HAL_TIMER34_START);
    413.       break;
    414.     case HW_TIMER_4:
    415.       T4CTL &= ~(HAL_TIMER34_START);
    416.       break;
    417.     default:
    418.       return HAL_TIMER_INVALID_ID;
    419.   }
    420.   return HAL_TIMER_OK;
    421. }
    422.
    423. /***************************************************************************************************
    424.  * @fn      halTimerSetCount
    425.  *
    426.  * @brief   Stop the Timer Service
    427.  *
    428.  * @param   hwtimerid - ID of the timer
    429.  *          timerPerTick - Number micro sec per ticks
    430.  *
    431.  * @return  Status - OK or Not OK
    432.  ***************************************************************************************************/
    433. uint8 halTimerSetCount (uint8 hwtimerid, uint32 timePerTick)
    434. {
    435.   uint16  count;
    436.   uint8   high, low;
    437.
    438.   /* Load count = ((sec/tick) x clock) / prescale */
    439.   count = (uint16)((timePerTick * halTimerRecord[hwtimerid].clock) / halTimerRecord[hwtimerid].prescaleVal);
    440.   high = (uint8) (count >> 8);
    441.   low = (uint8) count;
    442.
    443.   *(halTimerChannel[hwtimerid].TxCCH) = high;
    444.   *(halTimerChannel[hwtimerid].TxCCL) = low;
    445.
    446.   return HAL_TIMER_OK;
    447. }
    448.
    449. /***************************************************************************************************
    450.  * @fn      halTimerSetPrescale
    451.  *
    452.  * @brief   Stop the Timer Service
    453.  *
    454.  * @param   hwtimerid - ID of the timer
    455.  *          prescale - Prescale of the clock
    456.  *
    457.  * @return  Status - OK or Not OK
    458.  ***************************************************************************************************/
    459. uint8 halTimerSetPrescale (uint8 hwtimerid, uint8 prescale)
    460. {
    461.   switch (hwtimerid)
    462.   {
    463.     case HW_TIMER_1:
    464.       T1CTL &= ~(HAL_TIMER1_16_TC_BITS);
    465.       T1CTL |= prescale;
    466.       break;
    467.     case HW_TIMER_3:
    468.       T3CTL &= ~(HAL_TIMER34_8_TC_BITS);
    469.       T3CTL |= prescale;
    470.       break;
    471.     case HW_TIMER_4:
    472.       T4CTL &= ~(HAL_TIMER34_8_TC_BITS);
    473.       T4CTL |= prescale;
    474.       break;
    475.     default:
    476.       return HAL_TIMER_INVALID_ID;
    477.   }
    478.   return HAL_TIMER_OK;
    479. }
    480.
    481. /***************************************************************************************************
    482.  * @fn      halTimerSetOpMode
    483.  *
    484.  * @brief   Setup operate modes
    485.  *
    486.  * @param   hwtimerid - ID of the timer
    487.  *          opMode - operation mode of the timer
    488.  *
    489.  * @return  Status - OK or Not OK
    490.  ***************************************************************************************************/
    491. uint8 halTimerSetOpMode (uint8 hwtimerid, uint8 opMode)
    492. {
    493.   /* Load Waveform Generation Mode */
    494.   switch (opMode)
    495.   {
    496.     case HAL_TIMER_MODE_NORMAL:
    497.       switch (hwtimerid)
    498.       {
    499.         case HW_TIMER_1:
    500.           T1CTL &= ~(HAL_TIMER1_OPMODE_BITS);
    501.           T1CTL |= HAL_TIMER1_OPMODE_FREERUN;
    502.           break;
    503.         case HW_TIMER_3:
    504.           T3CTL &= ~(HAL_TIMER34_OPMODE_BITS);
    505.           T3CTL |= HAL_TIMER34_OPMODE_FREERUN;
    506.           break;
    507.         case HW_TIMER_4:
    508.           T4CTL &= ~(HAL_TIMER34_OPMODE_BITS);
    509.           T4CTL |= HAL_TIMER34_OPMODE_FREERUN;
    510.           break;
    511.         default:
    512.           return HAL_TIMER_INVALID_ID;
    513.       }
    514.       break;
    515.
    516.     case HAL_TIMER_MODE_CTC:
    517.       switch (hwtimerid)
    518.       {
    519.         case HW_TIMER_1:
    520.           T1CTL &= ~(HAL_TIMER1_OPMODE_BITS);
    521.           T1CTL |= HAL_TIMER1_OPMODE_MODULO;
    522.           break;
    523.         case HW_TIMER_3:
    524.           T3CTL &= ~(HAL_TIMER34_OPMODE_BITS);
    525.           T3CTL |= HAL_TIMER34_OPMODE_MODULO;
    526.           break;
    527.         case HW_TIMER_4:
    528.           T4CTL &= ~(HAL_TIMER34_OPMODE_BITS);
    529.           T4CTL |= HAL_TIMER34_OPMODE_MODULO;
    530.           break;
    531.         default:
    532.           return HAL_TIMER_INVALID_ID;
    533.       }
    534.       break;
    535.
    536.     case HAL_TIMER_MODE_STOP:
    537.       if (hwtimerid == HW_TIMER_1)
    538.       {
    539.         T1CTL &= ~(HAL_TIMER1_OPMODE_BITS);
    540.         T1CTL |= HAL_TIMER1_OPMODE_STOP;
    541.       }
    542.       break;
    543.
    544.     default:
    545.       return HAL_TIMER_INVALID_OP_MODE;
    546.   }
    547.   return HAL_TIMER_OK;
    548. }
    549.
    550. /***************************************************************************************************
    551.  * @fn      halTimerSetChannelMode
    552.  *
    553.  * @brief   Setup channel modes.  Currently, only output compare mode is supported.  Input capture
    554.  *          mode is NOT supported.  Additionally, mapping timer channel inputs/outputs to I/O pins
    555.  *          is NOT supported.
    556.  *
    557.  * @param   hwtimerid - ID of the timer
    558.  *          channelMode - channel mode of the timer
    559.  *
    560.  * @return  Status - OK or Not OK
    561.  ***************************************************************************************************/
    562. uint8 halTimerSetChannelMode (uint8 hwtimerid, uint8 channelMode)
    563. {
    564.   switch (channelMode)
    565.   {
    566.     case HAL_TIMER_CH_MODE_OUTPUT_COMPARE:
    567.       *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_CMP_BITS);
    568.       *(halTimerChannel[hwtimerid].TxCCTL) |= (T134CCTL_CMP_OC | T134CCTL_MODE);
    569.       break;
    570.
    571.     case HAL_TIMER_CH_MODE_INPUT_CAPTURE:       /* Not Supported */
    572. /*
    573.       *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_CAP_BITS | T134CCTL_MODE);
    574.       *(halTimerChannel[hwtimerid].TxCCTL) |= T134CCTL_CAP_RE;
    575. */
    576.       break;
    577.
    578.     default:
    579.       return HAL_TIMER_INVALID_CH_MODE;
    580.   }
    581.   return HAL_TIMER_OK;
    582. }
    583.
    584. /***************************************************************************************************
    585.  * @fn      HalTimerInterruptEnable
    586.  *
    587.  * @brief   Setup operate modes
    588.  *
    589.  * @param   hwtimerid - ID of the timer
    590.  *          channelMode - channel mode
    591.  *          enable - TRUE or FALSE
    592.  *
    593.  * @return  Status - OK or Not OK
    594.  ***************************************************************************************************/
    595. uint8 HalTimerInterruptEnable (uint8 hwtimerid, uint8 channelMode, bool enable)
    596. {
    597.   switch (channelMode)
    598.   {
    599.     case HAL_TIMER_CH_MODE_OVERFLOW:
    600.
    601.       if (enable)
    602.       {
    603.         *(halTimerChannel[hwtimerid].TxOVF) |= halTimerChannel[hwtimerid].ovfbit;
    604.       }
    605.       else
    606.       {
    607.         *(halTimerChannel[hwtimerid].TxOVF) &= ~(halTimerChannel[hwtimerid].ovfbit);
    608.       }
    609.       break;
    610.
    611.     case HAL_TIMER_CH_MODE_OUTPUT_COMPARE:
    612.     case HAL_TIMER_CH_MODE_INPUT_CAPTURE:
    613.
    614.       if (enable)
    615.       {
    616.         *(halTimerChannel[hwtimerid].TxCCTL) |= T134CCTL_IM;
    617.       }
    618.       else
    619.       {
    620.         *(halTimerChannel[hwtimerid].TxCCTL) &= ~(T134CCTL_IM);
    621.       }
    622.       break;
    623.
    624.     default:
    625.       return HAL_TIMER_INVALID_CH_MODE;
    626.   }
    627.
    628.   if (halTimerRecord[hwtimerid].intEnable)
    629.   {
    630.     IEN1 |= halTimerChannel[hwtimerid].intbit;
    631.   }
    632.   else
    633.   {
    634.     IEN1 &= ~(halTimerChannel[hwtimerid].intbit);
    635.   }
    636.   return HAL_TIMER_OK;
    637. }
    638.
    639. /***************************************************************************************************
    640.  * @fn      halTimerSendCallBack
    641.  *
    642.  * @brief   Send Callback back to the caller
    643.  *
    644.  * @param   timerId - ID of the timer
    645.  *          channel - channel where the interrupt occurs
    646.  *          channelMode - channel mode
    647.  *
    648.  *
    649.  * @return  None
    650.  ***************************************************************************************************/
    651. void halTimerSendCallBack (uint8 timerId, uint8 channel, uint8 channelMode)
    652. {
    653.   uint8 hwtimerid;
    654.
    655.   hwtimerid = halTimerRemap (timerId);
    656.
    657.   if (halTimerRecord[hwtimerid].callBackFunc)
    658.     (halTimerRecord[hwtimerid].callBackFunc) (timerId, channel, channelMode);
    659. }
    660.
    661. /***************************************************************************************************
    662.  * @fn      halTimerRemap
    663.  *
    664.  * @brief   Maps API HAL_TIMER_ID to HW Timer ID.
    665.  *          HAL_TIMER_0 --> HW Timer 3
    666.  *          HAL_TIMER_2 --> HW Timer 4
    667.  *          HAL_TIMER_3 --> HW Timer 1
    668.  *
    669.  * @param   timerId - ID of the timer
    670.  *
    671.  * @return  HW timer ID
    672.  ***************************************************************************************************/
    673. uint8 halTimerRemap (uint8 timerId)
    674. {
    675.   switch (timerId)
    676.   {
    677.     case HAL_TIMER_0:
    678.       return HW_TIMER_3;
    679.     case HAL_TIMER_2:
    680.       return HW_TIMER_4;
    681.     case HAL_TIMER_3:
    682.       return HW_TIMER_1;
    683.     default:
    684.       return HW_TIMER_INVALID;
    685.   }
    686. }
    687.
    688. /***************************************************************************************************
    689.  * @fn      halProcessTimer1
    690.  *
    691.  * @brief   Processes Timer 1 Events.
    692.  *
    693.  * @param
    694.  *
    695.  * @return
    696.  ***************************************************************************************************/
    697. void halProcessTimer1 (void)
    698. {
    699.   if (halTimerRecord[halTimerRemap(HAL_TIMER_3)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
    700.   {
    701.     if (T1CTL & T1CTL_CH0IF)
    702.     {
    703.       T1CTL &= ~(T1CTL_CH0IF);
    704.       halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    705.     }
    706.     if (T1CTL & T1CTL_CH1IF)
    707.     {
    708.       T1CTL &= ~(T1CTL_CH1IF);
    709.       halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    710.     }
    711.     if (T1CTL & T1CTL_CH2IF)
    712.     {
    713.       T1CTL &= ~(T1CTL_CH2IF);
    714.       halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_C, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    715.     }
    716.   }
    717.   else if (halTimerRecord[halTimerRemap(HAL_TIMER_3)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
    718.   {
    719.     if (T1CTL & T1CTL_OVFIF)
    720.     {
    721.       T1CTL &= ~(T1CTL_OVFIF);
    722.       halTimerSendCallBack (HAL_TIMER_3, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
    723.     }
    724.   }
    725. }
    726.
    727. /***************************************************************************************************
    728.  * @fn      halProcessTimer3
    729.  *
    730.  * @brief   Processes Timer 3 Events.
    731.  *
    732.  * @param
    733.  *
    734.  * @return
    735.  ***************************************************************************************************/
    736. void halProcessTimer3 (void)
    737. {
    738.   if (halTimerRecord[halTimerRemap(HAL_TIMER_0)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
    739.   {
    740.     if (TIMIF & TIMIF_T3CH0IF)
    741.     {
    742.       TIMIF &= ~(TIMIF_T3CH0IF);
    743.       halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    744.     }
    745.     if (TIMIF & TIMIF_T3CH1IF)
    746.     {
    747.       TIMIF &= ~(TIMIF_T3CH1IF);
    748.       halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    749.     }
    750.   }
    751.   else if (halTimerRecord[halTimerRemap(HAL_TIMER_0)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
    752.   {
    753.     if (TIMIF & TIMIF_T3OVFIF)
    754.     {
    755.       TIMIF &= ~(TIMIF_T3OVFIF);
    756.       halTimerSendCallBack (HAL_TIMER_0, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
    757.     }
    758.   }
    759. }
    760.
    761. /***************************************************************************************************
    762.  * @fn      halProcessTimer4
    763.  *
    764.  * @brief   Processes Timer 4 Events.
    765.  *
    766.  * @param
    767.  *
    768.  * @return
    769.  ***************************************************************************************************/
    770. void halProcessTimer4 (void)
    771. {
    772.   if (halTimerRecord[halTimerRemap(HAL_TIMER_2)].channelMode == HAL_TIMER_CH_MODE_OUTPUT_COMPARE)
    773.   {
    774.     if (TIMIF & TIMIF_T4CH0IF)
    775.     {
    776.       TIMIF &= ~(TIMIF_T4CH0IF);
    777.       halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_A, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    778.     }
    779.     if (TIMIF & TIMIF_T4CH1IF)
    780.     {
    781.       TIMIF &= ~(TIMIF_T4CH1IF);
    782.       halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_B, HAL_TIMER_CH_MODE_OUTPUT_COMPARE);
    783.     }
    784.   }
    785.   else if (halTimerRecord[halTimerRemap(HAL_TIMER_2)].channelMode == HAL_TIMER_CH_MODE_OVERFLOW)
    786.   if (TIMIF & TIMIF_T4OVFIF)
    787.   {
    788.     TIMIF &= ~(TIMIF_T4OVFIF);
    789.     halTimerSendCallBack (HAL_TIMER_2, HAL_TIMER_CHANNEL_SINGLE, HAL_TIMER_CH_MODE_OVERFLOW);
    790.   }
    791. }
    792.
    793. /***************************************************************************************************
    794.  *                                    INTERRUPT SERVICE ROUTINE
    795.  ***************************************************************************************************/
    796.
    797. /**************************************************************************************************
    798.  * @fn      halTimer1Isr
    799.  *
    800.  * @brief   Timer 1 ISR
    801.  *
    802.  * @param
    803.  *
    804.  * @return
    805.  **************************************************************************************************/
    806. HAL_ISR_FUNCTION( halTimer1Isr, T1_VECTOR )
    807. {
    808.   halProcessTimer1 ();
    809. }
    810.
    811. /**************************************************************************************************
    812.  * @fn      halTimer3Isr
    813.  *
    814.  * @brief   Timer 3 ISR
    815.  *
    816.  * @param
    817.  *
    818.  * @return
    819.  **************************************************************************************************/
    820. HAL_ISR_FUNCTION( halTimer3Isr, T3_VECTOR )
    821. {
    822.   halProcessTimer3 ();
    823. }
    824.
    825. /**************************************************************************************************
    826.  * @fn      halTimer4Isr
    827.  *
    828.  * @brief   Timer 4 ISR
    829.  *
    830.  * @param
    831.  *
    832.  * @return
    833.  **************************************************************************************************/
    834. HAL_ISR_FUNCTION( halTimer4Isr, T4_VECTOR )
    835. {
    836.   halProcessTimer4 ();
    837. }
    838.
    839. /***************************************************************************************************
    840. ***************************************************************************************************/
