CC2540 1.3协议栈中,使用UART问题
Other Parts Discussed in Thread: CC2540
CC2540  1.3  如果加HAL_UART=TRUE  编译会出现警告Warning[w52]: More than one definition for the byte at address 0x6b in common segment INTVEC. It is defined in module "hal_uart" as well as in module "hal_key"    然后应该简单KEY不能用了如何解决  使用SerialApp2改过LIB库,问题是一样的
