Part Number: LAUNCHXL-CC1310
Other Parts Discussed in Thread: CC1310
当COUNT数小于等于9时,CS信号会在每一个字节后拉高;大于9时,CS信号会在整个周期拉低,结束后拉高。
count=9:
SPI_init(); // Initialize the SPI driver
GPIO_init();
GPIO_setConfig(Board_SPI_SLAVE_READY, GPIO_CFG_IN_PD | GPIO_CFG_IN_INT_RISING);
/* install Button callback */
GPIO_setCallback(Board_SPI_SLAVE_READY, gpioButtonFxn0);
/* Enable interrupts */
GPIO_enableInt(Board_SPI_SLAVE_READY);
SPI_Params_init(&spiParams); // Initialize SPI parameters
spiParams.transferMode = SPI_MODE_BLOCKING; //
spiParams.dataSize = 8; // 8-bit data size
spiParams.mode = SPI_MASTER; //SPI MASTER
spiParams.frameFormat = SPI_POL0_PHA1; //SPI POL0 PHA0
spiParams.bitRate = 4000000; //4MHZ
spi = SPI_open(Board_SPI0, &spiParams);
if (spi == NULL) {
while (1); // SPI_open() failed
while(1)
spiTransaction.count = 9;
spiTransaction.txBuf = (void *)transmitBuffer;
spiTransaction.rxBuf = (void *)receiveBuffer1;
SPI_transfer(spi,&spiTransaction);
sleep(1);
count=10:
GPIO_init();
if (spi == NULL) {
while(1)
spiTransaction.count = 10;
sleep(1);
