CC1310: cc1310
Part Number: CC1310
-l"D:/wendang-li/simplelink_cc13x0_sdk_4_20_01_03__macos/simplelink_cc13x0_sdk_4_20_01_03/examples/rtos/CC1310_LAUNCHXL/drivers/sdraw/tirtos/ccs/tirtos_builds_CC1310_LAUNCHXL_release_ccs/Debug/configPkg/linker.cmd"  -l"ti/devices/cc13x0/driverlib/bin/ccs/driverlib.lib" -llibc.a
<Linking>
 undefined       first referenced
  symbol             in file
 disk_register   D:/wendang-li/simplelink_cc13x0_sdk_4_20_01_03__macos/simplelink_cc13x0_sdk_4_20_01_03/source/ti/drivers/lib/drivers_cc13x0.aem3<SDFatFS.oem3>
 disk_unregister D:/wendang-li/simplelink_cc13x0_sdk_4_20_01_03__macos/simplelink_cc13x0_sdk_4_20_01_03/source/ti/drivers/lib/drivers_cc13x0.aem3<SDFatFS.oem3>
 f_mount         D:/wendang-li/simplelink_cc13x0_sdk_4_20_01_03__macos/simplelink_cc13x0_sdk_4_20_01_03/source/ti/drivers/lib/drivers_cc13x0.aem3<SDFatFS.oem3>
 ffcio_close     ./sdraw.obj
 ffcio_lseek     ./sdraw.obj
 ffcio_open      ./sdraw.obj
 ffcio_read      ./sdraw.obj
 ffcio_rename    ./sdraw.obj
 ffcio_unlink    ./sdraw.obj
 ffcio_write     ./sdraw.obj
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "sdraw_CC1310_LAUNCHXL_tirtos_ccs.out" not built
各位工程师好,在cc1310中使用sdfatds,从cc1312复制过来程序,报错,烦请工程师帮忙解答
  • CC1310 SDK没有提供sdfatds例程,CC1310和CC1312也是不同的器件,软件方面也有差异,直接复制过来不能使用
    我们没有移植这个程序的文档,需要自己移植,建议你先熟悉一下CC1312的例程然后再移植
