你好:
CC2531芯片,06mm的FR4,使用AN043天线,除去天线板子尺寸11*19mm。通信距离短,刚入门做zigbee节点, 能推荐一个更适合的天线或者,天线调整办法吗?
先用频谱仪分析下发射功率,频偏,用网络分析仪分析下阻抗匹配,TI的参考设计如果完全参照,距离还是不错的。距离短不是换换天线就能解决的。
如下是一些射频设计的考量:
Below is some additional notes when you are copying TI Reference design.
Understand the PCB board properties
– PCB stack-up
– PCB board dielectric properties (dielectric constant and loss tangent).
– TI reference designs include a document describing above properties Readme.txt
The checklist below provides important RF PCB design considerations to be followed
Important considerations for Antennas
