LAUNCHXL-CC1312R1: IAR编译报错:[Su012]: Option --cpu does not match previous occurrence
Part Number: LAUNCHXL-CC1312R1
Other Parts Discussed in Thread: CC2650, SYSCONFIG, CC2652RB
使用IAR编译官方工程报错:
Fullscreen
1
[Su012]: Option --cpu does not match previous occurrence ·Hat line 1·h D:\110_Work_ProductsResearch\WorkSpace\abc\Debug\Exe\adcbufcontinuous_CC1312R1_LAUNCHXL_tirtos_iar.out.rsp 1
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
完整的错误代码为:
adcbufcontinuous_CC1312R1_LAUNCHXL_tirtos_iar - Debug
Reading project nodes...
Pre-build command
IAR Command Line Build Utility V9.1.1.9611
Copyright 2002-2022 IAR Systems AB.
tirtos_builds_CC1312R1_LAUNCHXL_release - Debug
Pre-build command
"cmd.exe /C" "cd c:\ti\simplelink_cc13x2_26x2_sdk_4_10_00_78\kernel\tirtos\builds\CC1312R1_LAUNCHXL\release\iar && "c:/ti/xdctools_3_61_00_16_core/xs" --xdcpath="c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/kernel/tirtos/packages;c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source" iar.tools.configuro -o c:\ti\simplelink_cc13x2_26x2_sdk_4_10_00_78\kernel\tirtos\builds\CC1312R1_LAUNCHXL\release\iar/../iar -c "E:\Tools\IARSystems\EmbeddedWorkbench91\arm" --cc "E:\Tools\IARSystems\EmbeddedWorkbench91\arm\bin\iccarm.exe" --device "CC1312R1F3" --compileOptions "-o c:\ti\simplelink_cc13x2_26x2_sdk_4_10_00_78\kernel\tirtos\builds\CC1312R1_LAUNCHXL\release\iar\Debug\Obj\ --no_cse --no_unroll --no_inline --no_code_motion --no_tbaa --no_clustering --no_scheduling --debug --endian=little --cpu=Cortex-M4 -DDeviceFamily_CC13X2 -e --fpu=VFPv4_sp --dlib_config E:\Tools\IARSystems\EmbeddedWorkbench91\arm\inc\c\DLib_Config_Normal.h -Ol" --linkOptions "--create -o c:\ti\simplelink_cc13x2_26x2_sdk_4_10_00_78\kernel\tirtos\builds\CC1312R1_LAUNCHXL\release\iar\Debug\Exe\tirtos_builds_CC1312R1_LAUNCHXL_release.a" --profile release --projFile "c:\ti\simplelink_cc13x2_26x2_sdk_4_10_00_78\kernel\tirtos\builds\CC1312R1_LAUNCHXL\release\iar\tirtos_builds_CC1312R1_LAUNCHXL_release.ewp""
Using RTSC configuration file: c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/kernel/tirtos/builds/CC1312R1_LAUNCHXL/release/iar/../release.cfg...
Total number of errors: 0
Total number of warnings: 0
Build succeeded
[Su012]: Option --cpu does not match previous occurrence Hat line 1h D:\110_Work_ProductsResearch\WorkSpace\abc\Debug\Exe\adcbufcontinuous_CC1312R1_LAUNCHXL_tirtos_iar.out.rsp 1
Total number of errors: 1
Build failed
IAR版本:
SDK版本:
  • 我发现出现了2个--cpu选项,两个值还不一样
    c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/kernel/tirtos/packages/ti/dpl/lib/dpl_cc26x2.arm4f --silent --cpu=Cortex-M4F --semihosting --entry __iar_program_start --vfe --text_out locale --cpu=Cortex-M4 --fpu=VFPv4_sp
    --cpu=Cortex-M4F
    --cpu=Cortex-M4
    为什么会出现这种情况,我能做什么操作解决它吗?
    D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\iCallBLE\ble_user_config.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\ble_user_config_stack.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\button_service.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\CC2652RB_LAUNCHXL_fxns.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Drivers\NV\crc.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\OAD\crc32.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\data_service.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\devinfoservice.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\OAD\flash_interface_ext_rtos_NVS.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\gatt_uuid.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\gattservapp_util.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\iCall\icall.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\iCallBLE\icall_api_lite.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\iCall\icall_cc2650.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\iCall\icall_user_config.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Profiles\led_service.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\main.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Drivers\NV\nvocmp.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\OAD\oad.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\OAD\oad_image_header_app.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\osal_icall_ble.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Application\project_zero.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\rom_init.o "D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\SysConfig Generated Files\ti_ble_config.o" "D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\SysConfig Generated Files\ti_drivers_config.o" "D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\SysConfig Generated Files\ti_radio_config.o" D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Startup\UartLog.o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Obj\project_zero\Application\util.o --no_out_extension -o D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\Exe\project_zero_CC2652RB_LAUNCHXL_tirtos_iar.out --map D:\110_Work_ProductsResearch\WorkSpace\zero\zero\Debug\List\project_zero_CC2652RB_LAUNCHXL_tirtos_iar.map --config c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/examples/rtos/CC2652RB_LAUNCHXL/ble5stack/project_zero/tirtos/iar/cc26xx_app_and_stack_agama.icf -f D:\110_Work_ProductsResearch\WorkSpace\zero\zero/configPkg/linker.cmd --keep __vector_table c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/ble5stack/libraries/cc26x2r1/OneLib.a c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/ble5stack/libraries/cc26x2r1/ble_r2.symbols c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/ble5stack/libraries/cc26x2r1/StackWrapper.a -fc:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/examples/rtos/CC2652RB_LAUNCHXL/ble5stack/project_zero/Tools/Defines/config_def.opt c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/devices/cc13x2_cc26x2/driverlib/bin/iar/driverlib.lib c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/drivers/lib/drivers_cc26x2.arm4f c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/drivers/rf/lib/rf_multiMode_cc26x2.arm4f c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/display/lib/display.arm4f c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/source/ti/grlib/lib/iar/m4f/grlib.a c:/ti/simplelink_cc13x2_26x2_sdk_4_10_00_78/kernel/tirtos/packages/ti/dpl/lib/dpl_cc26x2.arm4f --silent --cpu=Cortex-M4F --semihosting --entry __iar_program_start --vfe --text_out locale --cpu=Cortex-M4 --fpu=VFPv4_sp
  • 好了,问题解决了!
  • 这种方法不可行
  • 问题真的解决了,IAR版本过高导致的,降回到8.32就不会自动添加--cpu=Cortex-M4选项了。
