如题
The Secondary IEEE address location is found on the last page of the CC2530 flash memory, at
an offset of 0x0018 bytes from the last memory address. For a 256-Kbyte device, the IEEE
address can be commissioned at 0x3FFE8-0x3FFEF. This address location is provided for the
user to override the TI pre-programmed Primary address “at the factory”. Device programming
tools that work with Z-Stack are set up to preserve IEEE addresses stored at this location.
请参看D:\Texas Instruments\ZStack-CC2530-2.5.0\Documents\CC2530\Z-Stack User's Guide - CC2530DB.pdf
