Other Parts Discussed in Thread: CC2541
关于TI CC1310遇到一个问题,就是会出现长时间掉线的情况,我这边初步判定是程序跑死看门狗没起作用,测试发现,看门狗没起作用,不知道是我这边配置有问题还是有什么限制
如果是低功耗的话使用PM3模式下,内外部的32k晶振不起作用是无法使用看门狗的。
建议您这边先使用TI提供的例程去跑看门狗程序,没问题之后,再去进行您这边的项目移植。
* @file Watchdog.h
* @brief Watchdog driver interface
* @anchor ti_drivers_Watchdog_Overview
* # Overview #
* A watchdog timer can be used to generate a reset signal if a system has
* become unresponsive. The Watchdog driver simplifies configuring and
* starting the watchdog peripherals. The watchdog peripheral can be
* configured with resets either on or off and a user-specified timeout
* period.
* When the watchdog peripheral is configured not to generate a reset, it
* can be used to cause a hardware interrupt at a programmable interval.
* The driver provides the ability to specify a user-provided callback
* function that is called when the watchdog causes an interrupt.
* The Watchdog driver simplifies configuring and starting the Watchdog
* peripherals. The Watchdog can be set up to produce a reset signal after a
* timeout, or simply cause a hardware interrupt at a programmable interval.
* The driver provides the ability to specify a callback function that is
* called when the Watchdog causes an interrupt.
* When resets are turned on, it is the user application's responsibility to
* call Watchdog_clear() in order to clear the Watchdog and prevent a reset.
* Watchdog_clear() can be called at any time.
* @anchor ti_drivers_Watchdog_Usage
* # Usage #
* This section will cover driver usage.
* @anchor ti_drivers_Watchdog_Synopsis
* ## Synopsis #
* Open the driver with default settings:
* @code
* Watchdog_Handle watchdogHandle;
* Watchdog_init();
* watchdogHandle = Watchdog_open(WATCHDOG_INDEX, NULL);
* if (watchdogHandle == NULL) {
* // Spin forever
* while(1);
* @endcode
* The Watchdog driver must be initialized by calling Watchdog_init(),
* before any other Watchdog APIs can be called.
* Once the watchdog is initialized, a Watchdog object can be created
* through the following steps:
* - Create and initialize the #Watchdog_Params structure.
* - Assign desired values to parameters.
* - Call Watchdog_open().
* - Save the Watchdog_Handle returned by Watchdog_open(). This will be
* used to interact with the Watchdog object just created.
* To have a user-defined function run at the hardware interrupt caused by
* a watchdog timer timeout, define a function of the following type:
* @code
* typedef void (*Watchdog_Callback)(uintptr_t);
* @endcode
* Then pass the function to Watchdog_open() through the #Watchdog_Params
* structure.
* An example of the Watchdog creation process that uses a callback
* function:
* @anchor ti_drivers_Watchdog_example_callback
* @code
* void UserCallbackFxn(Watchdog_Handle handle)
* printf("Watchdog timer triggered!\n");
* releaseResources();
* Watchdog_Params params;
* Watchdog_init();
* Watchdog_Params_init(¶ms);
* params.resetMode = Watchdog_RESET_ON;
* params.callbackFxn = (Watchdog_Callback) UserCallbackFxn;
* watchdogHandle = Watchdog_open(Board_WATCHDOG0, ¶ms);
* // Error opening Watchdog
* while (1);
* @endcode
* If no #Watchdog_Params structure is passed to Watchdog_open(), the
* default values are used. By default, the Watchdog driver has resets
* turned on, no callback function specified, and stalls the timer at
* breakpoints during debugging.
* Options for the resetMode parameter are #Watchdog_RESET_ON and
* #Watchdog_RESET_OFF. The latter allows the watchdog to be used like
* another timer interrupt. When resetMode is #Watchdog_RESET_ON, it is up
* to the application to call Watchdog_clear() to clear the Watchdog
* interrupt flag to prevent a reset. Watchdog_clear() can be called at
* any time.
* @anchor ti_drivers_Watchdog_Examples
* # Examples
* - @ref ti_drivers_Watchdog_Synopsis "Default Example"
* - @ref ti_drivers_Watchdog_example_callback "Callback Function before watchdog reset"
* @anchor ti_drivers_Watchdog_Configuration
* # Configuration
* Refer to the @ref driver_configuration "Driver's Configuration" section
* for more information.
在TI提供的watchdog.h中也进行了看门狗的说明
cc1310看门狗的复位时间是多少? - 低于 1GHz 论坛 - 低于 1GHz - E2E 设计支持 (ti.com)
这边给您找到了相关问题的帖子,希望能帮助到您
