CC1101可变长数据包发送
Other Parts Discussed in Thread: CC1101
想请教个CC1101可变长数据包发送的问题,在接收端与发射端都已经设置了可变长发送,但是当发送端TxBuf长度大于62个字节时 接收端无法正确接收(显示错误数据),小于62时没任何问题。
 手册上说通过同步字后面的第一个字节来配置数据包的长度,也是就是要发送的TxBuf[0]数据吧,可是无论我设置TxBuf[0]与否 ,当大于62字节时接收端都不能正确接收,,想实现可变长发送该如何设置呢
  • CC1101规格书里面 15.6 章节 里面有专门讲如何处理长的数据包的。
    15.6 Packet Handling in Firmware
    When implementing a packet oriented radio
    protocol in firmware, the MCU needs to know
    when a packet has been received/transmitted.
    Additionally, for packets longer than 64 bytes,
    the RX FIFO needs to be read while in RX and
    the TX FIFO needs to be refilled while in TX.
    This means that the MCU needs to know the
    number of bytes that can be read from or
    written to the RX FIFO and TX FIFO
    respectively. There are two possible solutions
    to get the necessary status information:
