1. 板子上没有接iic设备时,调用iic接口会卡死,在调试模式是正常的,断开调试器,直接上电会卡死!rfPacketTx_CC1310_LAUNCHXL_nortos_ccs.zip
2.
/* * Copyright (c) 2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /***** Includes *****/ /* Standard C Libraries */ #include <stdlib.h> #include <unistd.h> /* TI Drivers */ #include <ti/drivers/rf/RF.h> #include <ti/drivers/PIN.h> #include <ti/drivers/I2C.h> #include <ti/drivers/pin/PINCC26XX.h> /* Driverlib Header files */ #include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h) /* Board Header files */ #include "Board.h" #include "CC1310_LAUNCHXL.h" #include "smartrf_settings/smartrf_settings.h" #include <ti/drivers/ADCBuf.h> #include <ti/drivers/adcbuf/ADCBufCC26XX.h> /***** Defines *****/ /* Do power measurement */ //#define POWER_MEASUREMENT #define M117_ENABLE 1 /* Packet TX Configuration */ #define PAYLOAD_LENGTH 10 #ifdef POWER_MEASUREMENT #define PACKET_INTERVAL 5 /* For power measurement set packet interval to 5s */ #else #define PACKET_INTERVAL 500000 /* Set packet interval to 500000us or 500ms */ #endif /***** Prototypes *****/ /***** Variable declarations *****/ static RF_Object rfObject; static RF_Handle rfHandle; /* Pin driver handle */ static PIN_Handle ledPinHandle; static PIN_State ledPinState; static uint8_t packet[PAYLOAD_LENGTH]; static uint16_t seqNumber; /* * Application LED pin configuration table: * - All LEDs board LEDs are off. */ PIN_Config pinTable[] = { Board_PIN_LED1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, #ifdef POWER_MEASUREMENT #if defined(Board_CC1350_LAUNCHXL) Board_DIO30_SWPWR | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, #endif #endif PIN_TERMINATE }; /***** Function definitions *****/ extern void iic_map(uint8_t sclPin,uint8_t sdaPin); void *mainThread(void *arg0) { #if M117_ENABLE // One-time init of I2C driver I2C_init(); // initialize optional I2C bus parameters I2C_Params params; I2C_Params_init(¶ms); params.bitRate = I2C_100kHz; params.transferMode = I2C_MODE_BLOCKING; // Open I2C bus for usage //I2C_Handle i2cHandle = I2C_open(0, ¶ms); // Initialize slave address of transaction I2C_Transaction transaction = {0}; transaction.slaveAddress = 0x44; I2C_Handle i2cHandle; I2C_Handle i2cHandle2; i2cHandle = I2C_open(0, ¶ms); #endif RF_Params rfParams; RF_Params_init(&rfParams); /* Open LED pins */ ledPinHandle = PIN_open(&ledPinState, pinTable); if (ledPinHandle == NULL) { while(1); } #ifdef POWER_MEASUREMENT #if defined(Board_CC1350_LAUNCHXL) /* Route out PA active pin to Board_DIO30_SWPWR */ PINCC26XX_setMux(ledPinHandle, Board_DIO30_SWPWR, PINCC26XX_MUX_RFC_GPO1); #endif #endif RF_cmdPropTx.pktLen = PAYLOAD_LENGTH; RF_cmdPropTx.pPkt = packet; RF_cmdPropTx.startTrigger.triggerType = TRIG_NOW; /* Request access to the radio */ #if defined(DeviceFamily_CC26X0R2) rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams); #else rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams); #endif// DeviceFamily_CC26X0R2 /* Set the frequency */ RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0); while(1) { #if M117_ENABLE //i2cHandle = I2C_open(0, ¶ms); uint8_t iic_write_data[] = {0xCC,0x44}; uint8_t iic_read_data[3]; // Write to I2C slave device transaction.writeBuf = iic_write_data; transaction.writeCount = sizeof(iic_write_data); transaction.readCount = 0; I2C_transfer(i2cHandle, &transaction); //I2C_close(i2cHandle); usleep(10000); //i2cHandle = I2C_open(0, ¶ms); // Read from I2C slave device transaction.readBuf = iic_read_data; transaction.readCount = sizeof(iic_read_data); transaction.writeCount = 0; I2C_transfer(i2cHandle, &transaction); packet[2] = iic_read_data[0]; packet[3] = iic_read_data[1]; packet[4] = iic_read_data[2]; //I2C_close(i2cHandle); //usleep(5000);//屏蔽这行会死机 //I2C_cancel(i2cHandle); #if 1 //iic_map(IOID_20,IOID_21); //i2cHandle = I2C_open(0, ¶ms); // Write to I2C slave device transaction.writeBuf = iic_write_data; transaction.writeCount = sizeof(iic_write_data); transaction.readCount = 0; I2C_transfer(i2cHandle, &transaction); //I2C_close(i2cHandle); usleep(10000); //i2cHandle = I2C_open(0, ¶ms); // Read from I2C slave device transaction.readBuf = iic_read_data; transaction.readCount = sizeof(iic_read_data); transaction.writeCount = 0; I2C_transfer(i2cHandle, &transaction); packet[2] = iic_read_data[0]; packet[3] = iic_read_data[1]; packet[4] = iic_read_data[2]; //I2C_close(i2cHandle); //iic_map(IOID_4,IOID_5); #endif #if 0 //iiC_map(IOID_20,IOID_21); i2cHandle2 = I2C_open(1, ¶ms); // Write to I2C slave device transaction.writeBuf = iic_write_data; transaction.writeCount = sizeof(iic_write_data); transaction.readCount = 0; I2C_transfer(i2cHandle2, &transaction); //I2C_close(i2cHandle2); usleep(10000); //i2cHandle2 = I2C_open(0, ¶ms); // Read from I2C slave device transaction.readBuf = iic_read_data; transaction.readCount = sizeof(iic_read_data); transaction.writeCount = 0; I2C_transfer(i2cHandle2, &transaction); packet[2] = iic_read_data[0]; packet[3] = iic_read_data[1]; packet[4] = iic_read_data[2]; I2C_close(i2cHandle2); //iiC_map(IOID_4,IOID_5); #endif #endif /* Create packet with incrementing sequence number and random payload */ packet[0] = (uint8_t)(seqNumber >> 8); packet[1] = (uint8_t)(seqNumber++); //uint8_t i; //for (i = 2; i < PAYLOAD_LENGTH; i++) //{ // packet[i] = rand(); //} packet[2] = 2; packet[3] = 3; packet[4] = 4; /* Send packet */ RF_EventMask terminationReason = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx, RF_PriorityNormal, NULL, 0); switch(terminationReason) { case RF_EventLastCmdDone: // A stand-alone radio operation command or the last radio // operation command in a chain finished. break; case RF_EventCmdCancelled: // Command cancelled before it was started; it can be caused // by RF_cancelCmd() or RF_flushCmd(). break; case RF_EventCmdAborted: // Abrupt command termination caused by RF_cancelCmd() or // RF_flushCmd(). break; case RF_EventCmdStopped: // Graceful command termination caused by RF_cancelCmd() or // RF_flushCmd(). break; default: // Uncaught error event while(1); } uint32_t cmdStatus = ((volatile RF_Op*)&RF_cmdPropTx)->status; switch(cmdStatus) { case PROP_DONE_OK: // Packet transmitted successfully break; case PROP_DONE_STOPPED: // received CMD_STOP while transmitting packet and finished // transmitting packet break; case PROP_DONE_ABORT: // Received CMD_ABORT while transmitting packet break; case PROP_ERROR_PAR: // Observed illegal parameter break; case PROP_ERROR_NO_SETUP: // Command sent without setting up the radio in a supported // mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP break; case PROP_ERROR_NO_FS: // Command sent without the synthesizer being programmed break; case PROP_ERROR_TXUNF: // TX underflow observed during operation break; default: // Uncaught error event - these could come from the // pool of states defined in rf_mailbox.h while(1); } #ifndef POWER_MEASUREMENT PIN_setOutputValue(ledPinHandle, Board_PIN_LED1,!PIN_getOutputValue(Board_PIN_LED1)); #endif /* Power down the radio */ RF_yield(rfHandle); #ifdef POWER_MEASUREMENT /* Sleep for PACKET_INTERVAL s */ sleep(PACKET_INTERVAL); #else /* Sleep for PACKET_INTERVAL us */ usleep(PACKET_INTERVAL); #endif } }
您好,您的代码中rfPacket.c文件中,第156行代码开始至189行,
#if M117_ENABLE //i2cHandle = I2C_open(0, ¶ms); uint8_t iic_write_data[] = {0xCC,0x44}; uint8_t iic_read_data[3]; // Write to I2C slave device transaction.writeBuf = iic_write_data; transaction.writeCount = sizeof(iic_write_data); transaction.readCount = 0; I2C_transfer(i2cHandle, &transaction); //I2C_close(i2cHandle); usleep(10000); //i2cHandle = I2C_open(0, ¶ms); // Read from I2C slave device transaction.readBuf = iic_read_data; transaction.readCount = sizeof(iic_read_data); transaction.writeCount = 0; I2C_transfer(i2cHandle, &transaction); packet[2] = iic_read_data[0]; packet[3] = iic_read_data[1]; packet[4] = iic_read_data[2]; //I2C_close(i2cHandle); //usleep(5000);//ÆÁ±ÎÕâÐлáËÀ»ú //I2C_cancel(i2cHandle); #if 1 //iic_map(IOID_20,IOID_21); //i2cHandle = I2C_open(0, ¶ms); // Write to I2C slave device transaction.writeBuf = iic_write_data; transaction.writeCount = sizeof(iic_write_data); transaction.readCount = 0; I2C_transfer(i2cHandle, &transaction);
我看到您的#define M117_ENABLE 1 也是1
这段代码是什么意思,我不太明白。
还有就是 我现在开发板状态是 闪烁,这个状态是 您这边说的 “锁死” 状态吗?
表明那段代码也要执行,实际代码就是运行那段代码就出问题了。发现iic读失败后,继续读写就会错
iic在读取数据时,如果某一个时序在通信过程中,没有接收到反馈或者是您这边说的没有接入外设,可能会使引脚电平跳变引起通信错误,导致iic通信死锁。
另外:
IIC的SDA和SCL在空闲时都处于高电平状态。
在实际使用中,IIC比较容易出现一个问题就是死锁,主要表现是:SCL为高,SDA一直为低。
在IIC主设备进行读写操作的过程中,主设备在开始信号后控制SCL生产8个时钟脉冲,然后拉低SCL信号为低电平,在这个时候,从设备输出应答信号,将SDA信号拉为低电平。
如果这个时候主设备异常复位,SCL就会被释放为高电平。此时,如果从设备没有复位,就会继续IIC的应答,将SDA一直拉为低电平,直到SCL变为低电平,才会结束应答信号。而对于IIC主设备来说,复位后检测SCL和SDA信号,如果发现SDA信号为低电平,则会认为IIC总线被占用,会一直等待SCL和SDA信号变为高电平。
这样,IIC主设备等待从设备释放SDA信号,而同时IIC从设备又在等待主设备将SCL信号拉低以释放应答信号,两者相互等待,IIC总线进入一种死锁状态。
同样的,当IIC进行读操作,从设备应答后输出数据,如果在这个时候IIC主设备异常复位而此时从设备输出的数据正好为0,也会导致IIC总线进入死锁状态。
在下面我为您这边解决死锁问题提供了一些思路:
1. 主设备在检测到SDA被拉低超过一段时间后,主动复位从设备从而使之释放SDA。这种方法的前提是主设备连接了从设备的复位引脚,主设备就可以控制从设备的复位管脚使之复位。
2. 主设备在检测到SDA被拉低超过一段时间后,推送9个Clock到时钟总线上,取走从设备的ACK位,从而使从设备释放SDA为高电平。
3. 在主从设备之间串联一个IIC缓冲器,该缓冲器可以自动检测死锁状态。当检测到死锁时会主动断开与主设备的连接,并发送9个Clock给从设备,等从设备释放SDA线后重新与主设备建立连接。
IIC的死锁问题无法从根本上避免,除了主设备的异常复位导致IIC死锁,从设备在正常通信过程中也有可能异常拉低SDA导致死锁。所以软件在设计时要考虑当死锁发生时能够从死锁中恢复,使得IIC通信可以继续进行。
解决这个bug的一种方法,就是在读后面加延时就可以恢复正常,我觉得这有可能是潜在一个大bug.
出现bug的现象是有条件的,把中间的写操作去掉,bug就消失了
还是我在上面提到的这个内容,您可以尝试使用上述思路解决问题。但是我仍然好奇我的编译器去编译您的工程进行烧录,为什么是正常的。
您好,您这边使用您的开发板去跑sdk中的例程,有问题吗?
因为我看到我们的开发板同样是cc1310 pad但是仔细看版本是有区别的,我的是Rev 1.4.1 PG2.1 FW Rev 1.0
您好,很抱歉我这边没有revA版本的开发板所以没办法进行测试
您这边如果使用ti的例程烧录进您的revA版本的开发板中,可以实现示例代码中的实验现象吗?
