Variable expansion failed for custom build command line.
Offending text: "$SYSCONFIG_ROOT$/sysconfig_cli.bat -o $PROJ_DIR$ -s "$SIMPLELINK_CC13XX_CC26XX_SDK_INSTALL_DIR$/.metadata/product.json" --compiler iar $FILE_PATH$"
