Part Number: LAUNCHXL-CC1310
Other Parts Discussed in Thread: CC1310
想使用下CC1310的定时器实现1ms的定时功能,有没有相关的例程?
您好,这里为您提供了定时器相关api函数说明,另外我这边为您提供了demo
您这边可以参考sdk目录下 ti drivers 里面的pwm工程参考定时器
* Copyright (c) 2015-2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== pwmled2.c ========
/* For usleep() */
#include <unistd.h>
#include <stddef.h>
/* Driver Header files */
#include <ti/drivers/PWM.h>
/* Example/Board Header files */
#include "Board.h"
* ======== mainThread ========
* Task periodically increments the PWM duty for the on board LED.
void *mainThread(void *arg0)
/* Period and duty in microseconds */
uint16_t pwmPeriod = 3000;
uint16_t duty = 0;
uint16_t dutyInc = 100;
/* Sleep time in microseconds */
uint32_t time = 50000;
PWM_Handle pwm1 = NULL;
PWM_Handle pwm2 = NULL;
PWM_Params params;
/* Call driver init functions. */
PWM_init();
PWM_Params_init(¶ms);
params.dutyUnits = PWM_DUTY_US;
params.dutyValue = 0;
params.periodUnits = PWM_PERIOD_US;
params.periodValue = pwmPeriod;
pwm1 = PWM_open(Board_PWM0, ¶ms);
if (pwm1 == NULL) {
/* Board_PWM0 did not open */
while (1);
PWM_start(pwm1);
pwm2 = PWM_open(Board_PWM1, ¶ms);
if (pwm2 == NULL) {
while (1);
PWM_start(pwm2);
/* Loop forever incrementing the PWM duty */
while (1) {
PWM_setDuty(pwm1, duty);
PWM_setDuty(pwm2, duty);
duty = (duty + dutyInc);
if (duty == pwmPeriod || (!duty)) {
dutyInc = - dutyInc;
usleep(time);
您好,目前没有定时器的例程
您可以参考以上api函数文档以及以下代码
#include <unistd.h>
#include <stdint.h>
#include <stddef.h>
#include <ti/drivers/GPIO.h>
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26XX.h>
#include <ti/drivers/timer/GPTimerCC26XX.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <xdc/runtime/Types.h>
/* Board Header file */
#include "Board.h"
GPTimerCC26XX_Handle hTimer0A;
void timerCallback0A(GPTimerCC26XX_Handle handle, GPTimerCC26XX_IntMask interruptMask)
GPIO_toggle(Board_GPIO_LED0);
GPIO_init();
GPIO_setConfig(Board_GPIO_LED0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW);
GPTimerCC26XX_Params params0A;
GPTimerCC26XX_Params_init(¶ms0A);
params0A.width = GPT_CONFIG_16BIT;
params0A.mode = GPT_MODE_PERIODIC;
params0A.direction = GPTimerCC26XX_DIRECTION_UP;
params0A.debugStallMode = GPTimerCC26XX_DEBUG_STALL_OFF;
hTimer0A = GPTimerCC26XX_open(CC1310_LAUNCHXL_GPTIMER0A, ¶ms0A);
if(hTimer0A == NULL)
while(1);
Power_setDependency(PowerCC26XX_XOSC_HF);
Types_FreqHz freq;
BIOS_getCpuFreq(&freq);
GPTimerCC26XX_Value loadVal = (freq.lo / 1000)*348 - 1;
GPTimerCC26XX_setLoadValue(hTimer0A, loadVal);
GPTimerCC26XX_registerInterrupt(hTimer0A, timerCallback0A, GPT_INT_TIMEOUT);
GPTimerCC26XX_start(hTimer0A);
while(1)
Task_sleep(BIOS_WAIT_FOREVER);
您可以测试一下以上内容,它每 348 毫秒发出一次中断:
