Other Parts Discussed in Thread: CC1310
我们需要CC1310+SKY66122的硬件设计参考图
为您找到关于CC1310的硬件设计参考链接:CC13xx/CC26xx 硬件配置和 PCB 设计注意事项
SKY66122模块的官方认证平台链接和原理图:https://www.skyworksinc.com/en/Products/Front-end-Modules/SKY66122-11
这是CC1xxx 器件的硬件设计审查途径的链接,希望对您有帮助:https://www.ti.com.cn/tool/cn/SIMPLELINK-SUB1GHZ-DESIGN-REVIEWS?_ticdt=MTY5OTk2MDExM3wwMThhZDllY2Q5OTgwMDkwMmY3NzM5ZjI1OWI4MDUwNmYwMDEzMDY3MDA3ZTh8R0ExLjEuMjIyMDA2NDE0LjE2OTU4ODk1NDI
Hi yibing,
您需要将其设计基于 LAUNCHXL-CC1310-CC1190 (SWRC338):https://www.ti.com/lit/zip/swrc338 ,并使用推荐的 SKY66122 修改从 SKY66122 到天线的 RF 路径网络。
Skyworks 网站表明 SKY66122 部件处于预发布状态,因此您需要直接联系 Skyworks 以获取有关推荐 SKY66122 网络/BOM 的更多信息。
The customer would need to base their design on the LAUNCHXL-CC1310-CC1190 (SWRC338): https://www.ti.com/lit/zip/swrc338 and modify the RF path going from the SKY66122 to the antenna with the recommended SKY66122 network.
The Skyworks website indicates that the SKY66122 part is in pre-release, so the customer would need to contact Skyworks directly for more information on the recommended SKY66122 network(s)/BOM.
Best regards,
Yolande
