LAUNCHXL-CC1310: CC1310例程开发板死在到RF_runCmd()上面
Part Number: LAUNCHXL-CC1310
simplelink_cc13x0_sdk_4_20_02_07      CCS和IAR都停在RF_runCmd()上面,是哪些配置不对么?
  • Hi,
    您的问题我们需要升级到英文论坛寻求帮助,由于这一周为感恩节假期,工程师给到答复的时间可能会有所延迟,给您带来的不便敬请谅解。
    Thanks
  • Hi,
    请看以下答复:
    Can you post some more detail about your issue?
    1) Which example project are you basing your project on?
    2) Which command are you sending when the device is stuck?
    3) Can you pause the program when this happens and post your call stack?
    4) Can you give more context for what you are trying to achieve?
    Thanks
