我在用iocc2640这款芯片做开发,下载了IAR for ARM 开发环境 写了很小的程序 添加了
#include "ioCC2640.h"
void main(void)
for(;;)
结果编译出现以下结果
main.c
iccarm.exe E:\ddss\main.c -o E:\ddss\Debug\Obj --no_cse --no_unroll --no_inline --no_code_motion --no_tbaa --no_clustering --no_scheduling --debug --endian=little
--cpu=Cortex-M3 -e --fpu=None --dlib_config C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm\INC\c\DLib_Config_Normal.h -I C:\Program Files (x86)\IAR
Systems\Embedded Workbench 7.2\arm\inc\ -Ol
IAR ANSI C/C++ Compiler V7.40.7.9843/W32 for ARM
Copyright 1999-2015 IAR Systems AB.
Fatal Error[Pe1696]: cannot open source file "ioCC2530.h" E:\ddss\main.c 1
searched: "E:\ddss\"
searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm\inc\"
searched: "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm\inc\c\"
Errors: 1
Warnings: none
Error while running C/C++ Compiler
Done. 1 error(s), 0 warning(s)
不知道这是怎么回事 我去打开路径 结果发现没有这个头文件,非常疑惑
