CC3200作为TCP SOCKET server接收多个客户端连接
请问TI工程师,有哪些资料或例程可供参考啊,SDK库里的例程就算了吧,就是一对一连接,断开重连功能都没做,没有参考价值
  • 请参考如下:
    void TcpServerMultiClient(int usPort)
    int serverID, socketID[7] = {-1, -1, -1, -1, -1, -1, -1};
    long lNonBlocking = 1;
    SlSockAddrIn_t sAddr;
    SlSockAddrIn_t sLocalAddr;
    struct SlTimeval_t timeVal;
    int iAddrSize;
    int iStatus;
    int iNewSockID;
    int i, Ret;
    char buffer[1024];
    sLocalAddr.sin_family = SL_AF_INET;
    sLocalAddr.sin_port = sl_Htons((unsigned short)usPort);
    sLocalAddr.sin_addr.s_addr = 0;
    timeVal.tv_sec = 0;
    timeVal.tv_usec = 0;
    serverID = sl_Socket(SL_AF_INET,SL_SOCK_STREAM, 0);
    if(serverID < 0)
    printf("Create TCP server socket failed\r\n");
    return;
    iAddrSize = sizeof(SlSockAddrIn_t);
    // binding the TCP socket to the TCP server address
    iStatus = sl_Bind(serverID, (SlSockAddr_t *)&sLocalAddr, iAddrSize);
    if( iStatus < 0 )
    sl_Close(serverID);
    // error
    printf("Bind TCP server socket failed\r\n");
    return;
    // putting the socket for listening to the incoming TCP connection
    iStatus = sl_Listen(serverID, 0);
    if( iStatus < 0 )
    sl_Close(serverID);
    printf("Listen TCP server socket failed\r\n");
    return;
    printf("TCP Server Listening...\n\r");
    // setting socket option to make the socket as non blocking
    iStatus = sl_SetSockOpt(serverID, SL_SOL_SOCKET, SL_SO_NONBLOCKING,
    &lNonBlocking, sizeof(lNonBlocking));
    if( iStatus < 0 )
    printf("set socket TCP server socket failed\r\n");
    sl_Close(serverID);
    return;
    sl_SetSockOpt(serverID,SOL_SOCKET,SL_SO_RCVTIMEO, &timeVal, sizeof(timeVal));
    //serverID = SL_EAGAIN;
    while(1)
    for(i = 0; i < 7; i ++)
    if(socketID[i] < 0)
    if( (socketID[i] = sl_Accept(serverID, ( struct SlSockAddr_t *)&sAddr, (SlSocklen_t*)&iAddrSize)) >= 0)
    printf("Got a connection, socket id:%d\r\n", socketID[i]);
    iStatus = sl_SetSockOpt(socketID[i], SL_SOL_SOCKET, SL_SO_NONBLOCKING,
    sl_SetSockOpt(socketID[i],SOL_SOCKET,SL_SO_RCVTIMEO, &timeVal, sizeof(timeVal));
    //printf("socket id:%d\r\n", socketID[i]);
    if(socketID[i] > 0)
    //printf("socket id:%d--i:%d\r\n", socketID[i], i);
    Ret = sl_Recv(socketID[i], buffer, 1024, 0);
    if(Ret > 0)
    buffer[Ret] = '\0';
    printf("Received packets:%s\r\n", buffer);
    //else
    // printf("Returned value:%d\r\n", Ret);
